Reply 30640 of 30652, by BitWrangler
Ozzuneoj wrote on 2026-01-08, 18:38:
And yes, I'm aware that it incorrectly says that it is S-video. They seem to be producing cables without even knowing what they are used for.
I think they were maybe used in some early S-video applications, like for transfer off camcorders that were as big as a stinger launcher or had a separate minitower sized handbag for the deck.
Reply 30641 of 30652, by Ozzuneoj
BitWrangler wrote on 2026-01-09, 04:49:
All I could find are cables that break out from that to a set of component cables. I'm thinking that's probably what they were most commonly used for.
In other news, the floppy drive on the 1040STf was not happy, and some quick googling told me that these are known to have bad caps. Sure enough, it has some of those evil way-too-early-for-their-own-good surface mount aluminum electrolytic caps. Not the ones used in the 90s, but the ones that usually have a little yellow label wrapped around them. Anyway, everything on the PCB had a bit of a corroded look to it, so I figured they were toast.
It ended up being a surprisingly time consuming repair (because the motor absorbs SO MUCH heat from the board and the solder had so much corrosion on it that nothing would melt), but I eventually got all of the electrolytics replaced. I did basically the same thing as this post:
https://www.exxosforum.co.uk/forum/viewtopic.php?t=3147
Now, I'm happy to say that it works perfectly! The system boots up in seconds thanks to the OS being on ROM, and these STs are so stinking awesome that they read standard 720K IBM formatted floppies AND text files with nothing but the ROM loaded. I just popped an old 720K floppy into a Dell USB drive connected to my Windows 10 system, put some text files on it, put it into the ST, double "clicked" (I had to use alt+arrow keys and alt+insert) the floppy drive and there everything was...
The attachment 20260109_021028.jpg is no longer available
The attachment 20260109_021008.jpg is no longer available
I think I'm going to like tinkering with this machine.
Also, I had a friend 3D print a replacement key stem for one that was broken. I had to sand that down a bit, but it also works perfectly. It feels good to give a machine like this a new lease on life. I will post more pictures (and maybe a thread) once I am done reassembling it. After working on the floppy drive waaay too late and then cleaning up my work desk, I'm done for the day. 😌
EDIT: Forgot to mention, the monochrome VGA adapter cable it came with allows it to work on any of my CRTs as well as my Dell Ultrasharp 2001FP, as pictured. It is a little wobbly and has some lines on the LCD but looks perfect on a CRT.
... also, it turns out this 2001FP I was given a few years back is one of the unicorns that was made before they broke 15Khz horizontal refresh support... so I can either get a different adapter or rewire this one to use the ST's color video modes and it should work. 🙂
Reply 30642 of 30652, by BitWrangler
Woohoo good going.
One of the things I would be curious about if I had ST hardware, would be how much interoperability I could get going between the ST and Gem running on a PC. Might just be a limited set of file types and data and ancillary files that will cross. I guess if I get too curious I can find an ST emulator. The most tantalizing prospect would be getting familiar enough with the sameness and differences to be able to cross compile suitable open source stuff from the Atari side and have more than like 6 apps to run on Gem.
Reply 30643 of 30652, by Ozzuneoj
BitWrangler wrote on 2026-01-09, 14:40:
Woohoo good going.
Arghh...
Well, things were going well... I was easily writing disk images to floppies on my Windows 10 PC, and then testing them on the ST. So far everything seemed to be okay other than the fact that most things expect low\med res color mode, which I cannot use currently. I accidentally left the disk for Another World in the drive when I turned the machine on and it started trying to load it. I didn't want to wait for that so I powered the system off... aaaandd... that was apparently a mistake. Now, the floppy makes normal pc-like "brrrnnn-brrnnnn" motor sounds at startup, which it wasn't doing before, and when TOS loads there are no floppy drives visible. 🤦
So, let me guess, I just toasted the floppy drive controller or something?
EDIT: Oh! I fixed it! The drive's head carriage was stuck! I looked in the drive and didn't see any movement when it was making the seek-test noises. I took the cover off and saw that the carriage was all the way forward. When I pushed it back it was kind of hung up at the front but came free easily. Now, the drive does a simple "blip" of the carriage motor and then proceeds to start right up. The floppy icons are back on the desktop.
Whew!
EDIT2: Bleh... after struggling to find a game to run on this in monochrome, I finally got Battlezone working and I find out that there is no way to get sound out of a 1040STf without a different video adapter that has an audio jack. I don't know why I was expecting it to have an internal speaker. I have had it apart multiple times and never seen one. -_-
The adapters are plentiful but only available from Europe... and now that I do some more research it sounds like the image quality on most of them will be bad and have lines on it. Some people have developed adapters with buffers to alleviate this (seems not always successfully without yet more mods), but those projects seem to all be long dead. Man, I was really hoping I could just wire up an adapter and use this thing.
Reply 30644 of 30652, by GigAHerZ
Fixed the stand/base lock of Compaq S710 CRT screen. The clip had broken off, so I went and created a quick 3d model and printed it out.
Works perfectly!
I now need to go to find some things to weld back all other plastic clips that have broken off - the back case has nothing to hold on to. Thankfully i have all the broken pieces. Found some local products with the help of AI to actually weld and recreate ABS plastic. I hope i don't have to just glue the backside onto the monitor somehow...
BTW, this CRT is beautiful. 80 contrast, 80 brightness, beautiful bright picture.
EDIT: Put it up in thingiverse: https://www.thingiverse.com/thing:7267325
Reply 30645 of 30652, by PD2JK
I thought all SECC2 coolers were interchangeable. But it seems there is a difference between Katmai and Coppermine. There is too much headroom when I installed the big heatsink on to the Coppermine, so bad contact. 🙁
The attachment 20260109_163037863.JPG is no longer available
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 30646 of 30652, by PcBytes
GigAHerZ wrote on Yesterday, 15:02:
Fixed the stand/base lock of Compaq S710 CRT screen. The clip had broken off, so I went and created a quick 3d model and printed […]
Works perfectly!
Neat, that reminds me I have to do some work on my Philips 109B5.
Among other things:
- test whether the rounded type 107P4 stand works on it or not (as in, if they're interchangable)
- recap it
- consolidate the flyback with a bit of hotglue since it sometimes lets out a bit of slight arcing - not huge but just slightly noticeable during standard use.
Reply 30647 of 30652, by kinetix
Joseph_Joestar wrote on 2026-01-04, 11:38:
I just watched this episode of The Computer Chronicles from 1993 where they talk about the Pentium processor in detail.
About 13 minutes in, they show a server which had 64MB RAM, and could host up to 1GB at maximum. Didn't realize that was even a thing back then. When asked who is buying these systems, the salesman answers: people who are working on neural networks and AI. I had to do a double take on that.
well, some Silicon Graphics workstations (or deskside "supercomputers") from that year could be expanded to 16 GB
Reply 30648 of 30652, by nali
A few month ago, I've been given a pc with a KT7 Pro2 and a Duron 600, with 320 Mo ram and a TNT2 M64.
It worked for a few days, then stopped booting.
I removed the caps, usuals suspects, tested them, and they seemed fine.
But I noticed the VRM controler was very hot. It's a SC1155CSW, and seems to be a weak part on this board.
So I ordered 2 for 3.50 $ each on AlieExpress, and replaced it.
Quick test, and now it works 😀
Let's says I'm quite happy with this.
The Duron 600 is not the best cpu, but it seems this board can use Athlon XP up to 1.2 GHz or maybe more.
And I read the Duron can be overclocked easily up to 1 GHz.
Playing with old electronic can be frustrating, it's nice when things go well so easily 😀
Reply 30649 of 30652, by BitWrangler
Interesting, I might have to revisit a similar part on a KT133 board I shelved with similar symptoms, caps tested okay but I wanted to dig into ripple etc suspecting that more. The chip does get hot though and I could get partial boots with freeze spray until it got too hot.
Reply 30650 of 30652, by nali
BitWrangler wrote on Yesterday, 23:23:
Those chips are just Mosfet drivers.
Even if they are able to deliver a bit of current, they are supposed to stay cool.
Now the PC has been working for hours, and it's barelly about 40 C. I can touch it with no problem, it's not hot.
Reply 30651 of 30652, by henk717
Did my first clean install of Windows 98 in a while for the retro timemachine PC, I did record it but the footage was so shakey that I decided not to publish any footage as it negated the point of the installation slow content.
It was to fix a bug I was having with the virtual modem as it stopped working. the reinstall didn't solve it. Turns out the K56Flex modem driver is just not liking this very specific setup, if I downgrade the script it works, if I do it in a VM it works, but 1.7 vmodem + my hardware + K56Flex is a no go. But, turns out the modem above it in the driver list doesn't have that quirk and works fine with no downsides. So instead of debugging a script that appears to work fine otherwise and actually behaves more authentic than the old version does, I figured switching the driver on Windows 98 was more appropriate.
I did upload a new VM version but the only change is in which modem driver is recommended.
Reply 30652 of 30652, by H3nrik V!
PD2JK wrote on Yesterday, 15:48:
That's bad. However, I would've sworn, that I'm using the same cooler for my Katmais as well as my Coppermines. But maybe I'm using Coppermine coolers, which may then be just pursuing a little more on the Katmais? That could give other issues probably ...
