First post, by Acorns
I just got done "repairing" an unreliable 4865, and thought I would post here in the off chance this helps someone else in the future.
I bought the drive on ebay as "untested". I used to think this really meant "tested, didn't work, want to sell it" - but after buying a lot of retro hardware and having most of it work I wasn't incredibly surprised when the drive arrived and read the first disk I tossed in it. "Untested" really does mean they don't know a lot of the time.
After a day or so the drive became unreliable, sometimes reading, sometimes not. After a week, it became physically difficult to insert a disk. I had to manipulate the disk by pushing upwards and then downwards. From this point on it stopped reading entirely with Not Ready errors.
After disassembling the drive I found that the head was visibly not contacting the disk. Pressing the head down lightly would result in the drive being able to read the disk.
There was a small padded square in the corner, over the screw - which for all the world looked like it belonged there. I figured it had puffed up or come slightly out of place, but after some testing found it was just loosely floating. I think it was originally glued to near the front of the drive - if anyone can confirm that I would love to know.
If you have a drive you cannot insert a disk into, or if the head is being pressed up and away from the disk, this might be one thing to check for.
A picture of the piece and a video of the non-contacting head are attached. Unfortunately my pictures of the piece where it was floating at did not turn out and I didn't notice.
Reply 1 of 1, by DaveDDS
I too found that "untested" mostly means "doesn't work", but I agree that more recently with "retro" gear, some sellers don't have the gear/knowlege to perform an actual test. I'm sure they would if they could "tested working" is much more sellable than "untested (likely doeasn't work)"
The bit you found could just be some debris that got into the drive when a disk was inserted. As the disks themselves are soft/insulated, it's fairrly uncommon to see a small stand-off like that.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
