Fastvid Help
First post, by DustyShinigami
I'm having a bit of trouble getting Fastvid to work, specifically, every boot. I also have a few questions too, so I imagine this is where Phil will chime in. 😀
Okay, everything else has gone smoothly so far. I've run each of the benchmarks, from the DOS Benchmark tools, in turn. My first question/suggestion is - is it possible to get it to automatically run through all the benchmarks one after the other? A bit like 3DMark does? Second question: can you get it to record the results after each test? It would make it super useful for comparing before and after. 😀 I've written them down so far. These results are with my 16MB Riva TNT and default CPU clock speed, so I've yet to test things with my Geforce 4 and overclocked CPU. As they are, there is still a huge improvement after applying Fastvid.
I've been reading through the readme file and tried to replicate what it suggests. I added the necessary files to a boot disk and ran the tests before and after. It does say my motherboard isn't supported though...? Says it's 82440. I didn't apply the patch either.
This is before:
The attachment IMG_5223.JPG is no longer available
The attachment IMG_5222.JPG is no longer available
And after:
The attachment IMG_5221.JPG is no longer available
And if I try to add FASTVID to my autoexec.bat file - FASTVID 111 4 D6000000 - I get this:
The attachment IMG_5224.JPG is no longer available
If I try to add DOS4GW FASTVID 111 4 D6000000 I get this:
The attachment IMG_5220.JPG is no longer available
Which makes no sense as all the files are together in C:\DOSPRO\FASTVID
My final question is: I take it this tool only works in DOS? That it doesn't affect games in Windows too? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 14, by bakemono
Change to the directory that contains fastvid and dos4gw before trying to run fastvid. It's either that or put dos4gw somewhere in your PATH.
You might try logging vspeed results to a text file by doing vspeed > result.txt
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 2 of 14, by DustyShinigami
bakemono wrote on 2026-01-11, 17:22:
Okay, thanks. You mean to load into the directory first as a command and then load fastvid as the next command?
And sorry, I should have clarified, I was actually referring to the DOS Benchmark tools, which come bundled with fastvid as well. I'll edit the initial post. Unless the same command can be done for those as well...?
EDIT: No, I can't get that to work either. It just says bad command or filename. 🙁
OS: Windows 98 SE
Reply 3 of 14, by DustyShinigami
Just to make sure I've understood correctly, I put in my autoexec.bat file:
C:\DOSPRO\FASTVID
C:\DOSPRO\FASTVID\FASTVID 111 4 D6000000
Also did:
SET FASTVID=C:\DOSPRO\FASTVID
%FASTVID%\FASTVID 111 4 D6000000
OS: Windows 98 SE
Reply 4 of 14, by Tiido
The SET FASTVID+line afterwards is unnecessary, the program doesn't need an environment variable for itself and this will simply waste some of your 640KB.
CD C:\DOSPRO\FASTVID
CD\
This should be all you need. The CD\ is a shorthand for going back to the root of the drive.
Also you should set the Brightness control of your monitor to a level where the background of the text stops glowing, it'll make whatever graphics you'll be seeing much less washed out looking.
Reply 5 of 14, by DustyShinigami
Tiido wrote on 2026-01-11, 20:00:
The SET FASTVID+line afterwards is unnecessary, the program doesn't need an environment variable for itself and this will simply […]
CD\
Ah, okay. I may have set up an environment variable in other BATs unnecessarily. 😅 Doesn’t it need one if you’re calling a path on more than one occasion? So you can just use %FASTVID% rather than type the whole thing out?
To be honest, I didn’t even think of using ‘CD’. I’ll give it a try a bit later and report back. Thanks.
OS: Windows 98 SE
Reply 6 of 14, by Tiido
Ah, if you have many locations then environment variable makes some sense. In that case you should have "SET FASTVID=" somewhere near the exit of a batch route, which deletes the variable and frees up a small amount of memory.
Reply 7 of 14, by DustyShinigami
Tiido wrote on 2026-01-11, 21:43:
I really need to get myself that DOS for Dummies book. ^^; So, don't you have things like SET NAME= at the beginning/top? What's considered a batch route exit?
OS: Windows 98 SE
Reply 8 of 14, by Tiido
Batch file just does all the stuff in a sequence as if you entered all that text manually in DOS prompt, except it adds few extra things like GOTO and labels, and exit route would be wherever the batch file finishes things. You can have things GOTO all over the place and exit in multiple locations so such a clearing of an unused environment variable will need the statement at every such exit. Alternatively you GOTO a fixed exit location which would be the cleaner way to do things.
I only SET specific environment variables that games etc. want, such as BLASTER, ULTRASND and ULTRA16 but also some special ones such as DIRCMD
Reply 9 of 14, by DustyShinigami
Tiido wrote on 2026-01-11, 22:23:
Hmm. I see. This is an example of a BAT file for a game I might set up:
SET UNISOUND=C:\DOSPRO\UNISOUND SET SHSUCD=C:\DOSPRO\SHSUCD SET THROTTLE=C:\DOSPRO\THROTTLE SET GAME=D:\DOS\GAME […]
%UNISOUND%\UNISOUND /V50 /VW50 /VL50
%SHSUCD%\SHSUCD\SHSUCDHD /F:E:\DOS\GAME\DISK1.ISO
%SHSUCD%\SHSUCDX D:SHSU-CDH,E
%THROTTLE%\THROTTLE 5
CALL %GAME%\GAME.EXE
%SHSUCD%\SHSUCDX /D1
%SHSUCD%\SHSUCDHD /U
I'm not quite sure how you, or it, clear environment variables exactly. Would I be better having containers/functions (similar to in coding) that contain a block of commands, and have one for exiting the BAT file, and have GOTO at the end of one block?
OS: Windows 98 SE
Reply 10 of 14, by DustyShinigami
I think it might just be my phone. On some occasions everything looks blurry and I capture scanlines running up and down the screen. And then other times I’ll take a pic and everything’s fine. Like this:
The attachment IMG_5225.jpeg is no longer available
OS: Windows 98 SE
Reply 11 of 14, by DustyShinigami
At any rate, your suggestion worked, Tiido. Thank you! 😀
Now I'm going to look at orderng that book...
OS: Windows 98 SE
Reply 12 of 14, by y2k se
You need to be careful as EMM386 (or similar) will interfere with FASTVID's ability to improve LFB performance. For this reason I create unique configurations for DOS games on in Windows 98 PC (using customized PIF shortcuts).
On my P3 1.4S and Ti 4200:
VESA mode 0x0101 available, display offset y = 0.
VESA mode 0x4101 available, display offset y = 0.
VESA mode 0x0101 reports LFB address: F0000000
VESA mode 0x4101 reports LFB address: F0000000
PCI config10 reports possible LFB address: EC000000
PCI config14 reports possible LFB address: F0000000
User (command line) reports no LFB address:
VSPEED will use VESA mode 0x4101 and F0000000 as the LFB address.
32bit protected mode video benchmark version 1.10. (640x480x8bit)
No FASTVID and with EMM386 loaded
Copy DRAM to banked VGA: 60.83 million bytes per second
Copy DRAM to linear framebuffer: 67.09 million bytes per second
FASTVID X11 64 F0000000 with EMM386 loaded
Copy DRAM to banked VGA: 95.48 million bytes per second
No FASTVID and without EMM386 loaded
FASTVID X11 64 F0000000 without EMM386 loaded
Copy DRAM to banked VGA: 95.85 million bytes per second
Copy DRAM to linear framebuffer: 183.58 million bytes per second
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 13 of 14, by DustyShinigami
y2k se wrote on 2026-01-12, 02:33:
You need to be careful as EMM386 (or similar) will interfere with FASTVID's ability to improve LFB performance. For this reason […]
Cool. Thanks for the heads-up. I had no idea that affected performance, too. I have actually got it set up with my first DOS environment using HIMEM and EMM386. ^^; I'll have to do another test and compare the results.
OS: Windows 98 SE
Reply 14 of 14, by DustyShinigami
Just tried the benchmarks with EMM disabled and the results are identical to the ones I've recorded with EMM enabled.
OS: Windows 98 SE
