DDLINK: Easily move files between/To/From DOS systems
Reply 100 of 126, by DaveDDS
Exactly. Dual-pane file managers modeled after Norton Commander, e.g., Volkov Commander, are used widely on many systems and all […]
Volkov Commander, are used widely on many systems and all have this set
of shortcuts, from Midnight Commander and Krusader over Double Commander
and FAR Manager to Total Commander. So, a lot of people already know
these shortcuts by heart. In contrast, we need to learn DDLINK keys,
which don't "make obvious sense", when you already know dual-pane file
managers for decades.
I don't know "Norton Commander", "Volkov Commander", "Midnight Commander",
"Krusader", "Double Commander", "FAR Manager", "Total Commander" or most
of the myriad of commercial tools that some people "just love". ** I've
heard of only a couple of these, and most certainly don't know their users
interfaces "off by heart".
DDLINK was something I created for myself (initially a way to move disk
images to/from a DOS booted from floppy to run my ImageDisk tool), and as
I find it very useful, I decided to give it away for others - It was never
a product, I never made money at it - it's just something I needed.
And I simply see no reason to bloat my code with "features" that I don't
want and will never use...
If you so much prefer the user interface from a different tool....
by all means - use THAT tool!
** I differ from many users in that if I need a tool to perform some
specific task, I almost always *write it* - I don't generally use much
"off the shelf" commercial software, because it never does exactly what
I want and/or efficiently.
That's true for the English language, but not for many others.
Always true - but in my experience many foreign users using English language
software know "a little"/"enough" English to be able to use that software.
Sure, perhaps in your preferred language the word for "copy" begins with
{F5} but I don't know what sound F5 makes or how to represent it's character
in prompts on the screen - In other words, regardless of language, I don't
see remembering 'C' for copy any harder than remembering F5 (unless
of course every piece of software in the world is made to resemble your
favorite tool that does copy operations with F5)
Okay, here is a DDLINK.KEY file for your KEYSUB.
Can be loaded as a TSR using KEYSUB.COM DDLINK.KEY -T before running
DDLINK.
I designed KEYSUB to be able to perform "any keys" on keyboard which
didn't have those keys ... but you can certainly use it for things like
this too...
Note: I excluded Alt+F2 (Change Drive), because it would be in conflict
with the global 'Run application' shortcut on my Linux Mint system.
But... are you telling me that there is a version of Linux that uses keys
NOT compatible with your favorite tools? - shouldn't someone be complaining.
.. Another reason to avoid Fkeys where possible. There will always be
something that uses the Fkeys you choose in an incompatible way... Standard
typewriter keys ('A'-'Z', '0'-'9' etc.) are almost always available for
applications to use as they wish.
(we're sorry, but we decided to use 'x' as a overriding system control key
- we've sure our users won't mind not being able to enter 'x' when entering
text)
Sorry - I guess this turned into a bit of a "rant" - touchy subject!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 101 of 126, by DaveDDS
I did some "speed tests" using a test file of random binary bytes
exactly 1 megabyte (binary = 1024x1024 = 1048576 bytes) in size.
Test systems were both running DOS 5.0:
- P3 with NE2000 (compatile) PCI NIC using NE2000.COM packet driver
- P4 with on-board SIS900 NIC using SIS900.COM packet driver
They were connected with:
-10mbps ethernet HUB
-Parallel transfer cable (see DDLINK ?L ) LPT1<>LPT1
-Serial null modem cable (see DDLINK ?C ) COM1<>COM1
Times were measured with a stopwatch.. Pressed START and 'Y' in response to
'C'opy prompt exactly the same time - pressed STOP as soon as the transfer
finished. (so not digitally precise but pretty close)
        P= : <2 sec
L=1 : 24 sec
C=1 : 93 sec {default speed 115200}
C=1,57600 : 185 sec
C=1,19200 : 556 sec
C=1,9600 : 1117 sec
I didn't take the time to measure other/lower serial rates, but it's
pretty close to the theoretical maximum - you can calculate "close enough"
if you want lower speeds.
1048576 is 1024 transfers of 1024 bytes each.
Each transfer is: 1(func)+2(handle)+2(length)+1024(data)+2(crc) = 1031 bytes
+ response: 1(func)+2(bytes read/written)+2(error-code} = 5 + 1031 = 1036
1024*1036 = 1060864 bytes in packets
Serial is 1(start)+8(data)+1(stop) = 10 bits/char, bytes = speed/10
115200 / 10 = 11520 bytes/sec : 1060864 / 11520 =   92 sec
57600 / 10 = 5760 bytes/sec : 1050864 / 5760 = 184 sec
19200 / 10 = 1920 bytes/sec : 1050864 / 1920 = 556 sec
9600 / 10 = 960 bytes/sec : 1050864 / 960 = 1105 sec
There's a bit of extra time to receive packet (RX has to be fully
received (uart empty) before TX response can start, plus read/write
data/OS delays etc.
But as it shows, network is WAY faster - and since DDLINK uses "raw"
packets, you don't need to have a network that works under DOS, the
only other software you need is a "packet driver" (available for LOTs
of cards) - I keep "loose" ISA and PCI network cards that I can just
stuff into a system when I need!
LPT is next up - still a lot faster than serial.
Reply 102 of 126, by DaveDDS
bttr wrote on 2025-03-16, 14:09:
Note: I excluded Alt+F2 (Change Drive), because it would be in conflict with the global 'Run application' shortcut on my Linux Mint system.
I've made a couple enhancements to KEYSUB which may be able to work
around this...
Namely, when run without a .KEY file specification, it shows the status
of KEYSUB - now it also sets ERRORLEVEL :
  10 = Not Installed
11 = Installed/Disabled
12 = Installed/Enabled
I also added a -Quiet option, which prevents it from displaying "stuff"
so you could make a .BAT file to run DDLINK with your KEYSUBs enabled,
but disable them otherwise:
   @echo OFF
keysub -q
if errorlevel 12 goto ok
if errorlevel 11 goto en
keysub keys -tq
goto ok
:en
keysub -eq
:ok
C:\cmds\DDLINK %1 %2 %3 %4 %5
keysub -dq
Update available: KEYSUB.ZIP in download area of my site.
Reply 103 of 126, by DaveDDS
Actually, I just looked at doing a "special version" which I could include
for those who really want the "Commander" keys and don't care that it would
make DDLINK bigger...
I could have done this fairly easily with something like:
#define Case(a) //case a :
Case(_F5)
case 'C':
Then I would just have to remove the "//" from: #define Case(a) case a :
To enable these extra cases .... but I ran into a problem with Alt+F2
My Micro-C text windowing library doesn't support ALT+Fkey
I wrote this library in 1989, and my vague recollection was that
Alt+('A'-'Z') were clearly defined by IBM/MS and commonly used,
but other Alts much less so - as I rarely used Alt, never Alt+
(anything other than 'A'-'Z') I decided to only support Alt+('A'-'Z')
KEYSUB works because
A) I wrote it much laster (within the last year or two)
(and I had 35+ year more experience with BIOS/DOS/PC)
B) It hooks in at a much lower level where it sees "all" keys
C) User interactively create the translation table so I don't have
to make assumptions about what the key will represent.
This means I'd have to redo my text-windowing library, and since this is something that in 35+ years, I've
never had a problem with, or received requests to support ... it's really not something I want do do at this
point!
So.. sorry, it looks like KEYSUB is the best solution for you!
Reply 104 of 126, by bttr
Thanks for your efforts. I was already fine with the KEYSUB solution. 👍
Reply 105 of 126, by DaveDDS
bttr wrote on 2025-03-17, 19:51:
Good to know - I hope the additions I made so you can tell what state its in
to enable/disable it in a batch file helped. (I guess it depends on how "system" the Alt+F2 is
whether or not you can use it in an application - at least you can disable it outside DDLINK now!)
Someday, I might modify KEYSUB to be able to fully unload - but being a TSR I don't want to
make it bigger - it's currently TINY (51 byte of code) - but it basically has to unload itself.
Perhaps I can patch it on the fly to upload... just haven't gotten "a round tuit" yet!
** My wife did get me one a few years back - I guess I was saying "I need to get a round tuit"
too much! (It's on a bar-fridge downstairs, but hasn't helped get things done at all!!)
Reply 106 of 126, by bttr
I'm unable to reproduce your 'off-standard' .zip files. I tried in DOSBox and on a physical machine with PKZIP 2.04g & 2.50 shareware and with PKZIP 2.50 registered.
I used the command 'path_to_pkzip\pkzip -a -ex ..\test.zip' in a directory with some test data. All files in that test data directory just have the archive attribute set, so the 'external file attributes' dword for each .zip file member became 20 00 00 00.
I was able to reproduce your 'off-standard' .zip files using PKZIP 2.50 registered version. Firstly, I ran PUTAV.EXE to enable signing .zip files. Then I ran 'path_to_pkzip\pkzip -! -a -ex ..\test.zip' in a directory with some test data and, voilà, the 'external file attributes' dword became, e.g., 20 D7 82 E5.
So, these strange 'external file attributes' come from signing.
Reply 107 of 126, by DaveDDS
bttr wrote on 2025-03-23, 11:02:
... So, these strange 'external file attributes' come from signing.1
Thanks, I kinda though it might be related - Most "modern" .ZIP managers don't mention if a .ZIP is signed!
I think this is a problem with the affected UNZIP tools - PKWARE basically defined the .ZIP format, and
signing was a "thing" from very early on. Anything that claims to support .ZIP should be able to handle
signed ZIP files!
I don't really want to to NOT sign my files - this has been one of the ways I try to allow users to validate that
the stuff they have is actually from me!
I'll add a note on my download page warning that some UNZIP have this problem!
Reply 108 of 126, by DaveDDS
I've made some improvements to my DOSBOX distribution as well as my
DDCM (DaveD Command Menu) which can make it a lot easier to install
DosBox and use DDLINK on a modern Windows system:
All files are available on my site:
Install WinPcap or W10Pcap (this gives DosBox access to you network)
Unpack DOSBOX.ZIP to a suitable location - I use C:\DOSBOX
Go there and double-click: _DBSETUP.BAT
Follow the on-screen instructions to configure DosBox
Be sure to setup the ETHERNET NIC to the same device you attached
WinPcap/W10Pcap to.
Configure a Mount for a suitable Windows folder to be able to remotely
access - You could also just use the premounted:
- C: = DosBox\C
- R: = DosBox\Temp
Exit
enter 'Y' to "Resave DOSBOX.INI?"
enter 'Y' to "Autorun DDLINK function menu?"
You should now be able to double-click DOSBOX.EXE to run DosBox where
you will be presented with options to run DDLINK, View files etc.
Select: DDLINK Server (NETWORK)
On a DOS side:
Install a packet driver TSR: eg: NE2000 0x60
Run DDLINK as client: DDLINK p=
You can now "see" the Windows folders you configured on DosBox, and
move files to/from them.
[Always welcome feedback to improve my DOS "stuff" ]😀
Reply 109 of 126, by igully
Hi DaveDDS,
I wanted to know if there is an assembler detection routine I can implement to find out if DDLINK is active.
For example, LapLink offers this:
laplink_test:
mov ax,0c000h
int 2fh
cmp al,0ffh
jz Laplnk_found
Do you have, or can you implement something alike?
Thanks in advance.
Reply 110 of 126, by DaveDDS
igully wrote on 2026-01-11, 21:13:
Hi.
DDLINK is not a TSR ... it's very simple you run it on one end as a server, and access it by running it on another system as a client.
It does not run in background to provide constant network access. It is just an easy way to copy files from system to system over serial, parallel or network.
It is "active" only when it is the foreground program running.
Reply 111 of 126, by igully
DaveDDS wrote on 2026-01-12, 00:57:
Hi. […]
Hi.
I understand that it is not a TSR, however it would be nice to be able to use it under a DOS multitasking environment by having some sort of flag to know it is there running and taking a resource, so that others might be aware and don't take it if they implementing the proper check.
Blame it on me for still using DOS multitaskers for network/communications purposes, simultaneously to other duties such as BBS, gaming, audio playback, etc.
Reply 112 of 126, by chronoreverse
Why not just start it using a batch file and set an environment variable first and then set it to something else when done?
Reply 113 of 126, by DaveDDS
I designed DDLINK in the 1980s-90s as a way to easily move stuff to/from DOS systems that were not setup tp do so... most often DOS booted from floppy which could be as little as 360k).
So... I wanted it small - it doesn't interact with any other local programs, does not "take over" it's own software interrupt etc... and I don't want to bloat with code to do that to support host environments it was never intended for.
On "modern" systems, being a DOS progam, it will most likely have to be run "virtualized" under things like DosBox, VirtualBox, VMware, PCem etc... so: What to do to enable cross-platform checking? (DDLINK already has a means of remotely causing it to exit with a specified "exit code" - you can setup an environment to remotely test for it)
And.. there are ligimate resons you might want more than one instance running on one host: Serial and Network, different packet types for differently sandboxed envornmnts etc.)
There are better ways to guard againts double launching stuff.
One of my servers runs a backgtound tool to launch verious things do to things like:
- Messsges over network
- Time of day
It kepps track of what it has started and what has ended.
Reply 114 of 126, by DaveDDS
it is a "someday" project for me: I'd like to write a Winblows background service to suppurt DDLINK network server side allowing multiple simultanious connections.
I've done this for embedded hosts (running my own OS), but so far haven't gotten a "Round Tuit" for a win32 edition...
But the protocol is documented, and sample C source has be publishe to impliment it.
If anyone else wants to implement it for Win32 ,,, please do so! - I'd welcome such a contribution.
Reply 115 of 126, by igully
I understand, it is out of the scope of your design.
I am not personally interested in Win32/64 multitasking, but more on legacy DOS multitasking like Caldera/Novell's TaskMax, Software Carrousel 6.x/7.x, Quarterdeck DesqView, IBM TopView, etc., and even a few more modern and esoteric DOS multitaskers that even dare to include a proper GUI.
Another example, from Ralfs's Brown Interrupt List, from a comms program that came bundled with MS-DOS:
Int 2F, 5600 - Sewell Development Corporation Interlnk/FASTLYNX - Installation Check
AX = 5600h
DX = magic value FFFFh
BL = instance number (00h = any, 01h = first loaded, etc.)
(BH = 00h and CX = 0000h, see note)
Return: AL = FFh if installed
CX = version number (CL = major, CH = minor)
DX = resident CS of driver, DX:0000h
Anyway, Dave, thank you for your patience and responses.
And also thanks to all of you that are trying to help.
Brutman (mTCP) already rejected a request to implement such an interface, but I managed to be able to at least successfully detect any resident packet driver, which at least is something positive in that direction, though not as specific as I hoped for.
I just wanted to explain myself better in my request. For this purpose, see the attached program I am developing where I would have liked to include DDLINK. Be aware that it still needs a lot of testing and refinement. I plan to add other network/comm programs, many vintage ones like Alloy NTNX and friends, POWERLan, StarLAN, 10NET Communications/DCA 10NET, and hopefully be able to include other rarities such as Igor Bujanovic NeOS, etc. Ambitions are high (perhaps too high), and my x86 assembler skill is still, hopefully improving along the way. Why implement such a beast? Because it is a challenge that feeds the inner nerd in me. 😀
LANCHECK - Detects and displays an active LAN type, setting an errorlevel.
Version 1.01 (05 January 2026) - Copyright (C) 2026 by Ignacio F. Gully
Possible errorlevels:
01 = Novell IPX 02 = 3Com BAPI
03 = Banyan VINES 04 = Microsoft LAN Manager
05 = Artisoft LANtastic 06 = Western Digital ViaNet
07 = EasyNet Systems 08 = Traveling Software LapLink
200 = Unknown LAN 255 = No LAN
Reply 116 of 126, by DaveDDS
Fair enough, here are my thoughts...
I still run a few DOS systems, but for reasone many would consider unusual...
To me, DOS is just a program loader with a simple file system. I've never tried (or wanted) DOS multitasking. I can control exactly what is running and have nothing else running/interfereing in background. It is also a good means of accessing hardware directly (no OS protections or special drivers needed).
This is why I rcomment much of my "special purpose" stuff is under a clean DOS booted from floppy; Insure no TSRs or complex drivers which can "activate" at any moment. (also often done because so many people don't have native DOS systems anymore)
A good example of this is my ImageDisk tool, which can archive/restore pretty much ANY floppy disk that the PC FDC hardware can physically work with. It does some fairly time sensitive analysis and could be "thrown off" by other "tasks" running, or background activity, or the need to invoke indeterminate OS drivers to access the hardware.
I'm pretty "old school", I mostly run MS-DOS 5, sometimes PCDOS 7. I never think of DOS as a reasonable potential multitasking environment, and to be honest: I can think of *LOTS* of DOS applications that would NOT "happily co-exist".
And DDLINK is NOT a "LAN".. It's just a file-transfer tool which runs on both ends communicating directly "over a wire". This can be a direct serial connection, a direct parallel connection, or a direct network connection**
Serial and parallel are pretty obvious, but **although network seems like and is thought of as "many<->many", DDLINK uses the lowest level "packet"s, and aside from the initial broadcast by the client to find the server, all DDLINK communication is by directed packets passed only between client<->server (Yes, the network can be "sniffed" to see DDLINK traffic, but in "standard" networking modes, only the two endpoints see messages from the other - effectively like a wire).
Reply 117 of 126, by igully
It is absolutely understandable your position.
Many current DOS developers only envision their software to be ran in exclusivity, which is a totally reasonable approach given the monotasking design of DOS, and as a route to a safer environment. It is my thought though (and everyone now seems to happily disagree with it), that flexibility is always a good trait to have whenever it is affordable, as you never know/can predict what sort of use your program may be subject to.
But, like the say goes. "Opinions are like..." 😀
Thank you very much for your replies Dave. I appreciate both your thoughts and the vast amount of programs you've made.
Reply 118 of 126, by mbbrutman
If you want a feature like that, why don't you build it? With a minimal amount of assembler code you can create a TSR that you load before DDLINK, mTCP, or any other program, and have it hook the 2F interrupt vector. You can give the TSR command line parameters so it can be used to indicate the presence of *any* arbitrary program.
That's a general purpose solution that meets your requirements and keeps everybody else from having to add a feature that is not going to be used very often.
Reply 119 of 126, by igully
mbbrutman wrote on 2026-01-12, 22:49:
It is funny, after Dave's response, I was already exploring that exact solution you make reference to, even already using that same interrupt vector. I still need to test it properly and clean a few rough edges around the implementation.
Thank you for chiming in.
