Comparing Video Players
First post, by BEEN_Nath_58
I had started with the Windows Media Player, and then I realised that my PC manufacturer installed 2 more players: KMPllayer and VLC. I was 8 so I didn't know how they were different because different files opened in different players.
Quite some time has passed, and I have only tried two things extra: Media Player Classic and QuickTime. The latter came in included with games and I didn't have any extra necessity for that program. I have heard good things about PotPlayer but never bothered to try it. I also can't remember why I moved to MPC from VLC.
MPC runs fine for anything I have, but I still have that extra curiosity of what other players do.
Reply 1 of 6, by zyga64
Last time I checked best choices for Windows 9x were MediaPlayerClassic 6.4.9.1 https://sourceforge.net/projects/guliverkli2/ … lassic/6.4.9.1/) and PotPlayer for Windows XP (MPC-HC was also good https://github.com/mpc-hc/mpc-hc). But I'm no longer interested in watching movies on vintage computers, so I may not be up to date...
I remember that in the past I switched to PotPlayer because it supported DXVA offered by graphics cards (and was more handy - everything I needed was in the context menu).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 6, by UCyborg
Of things that come to mind to point out, PotPlayer has its own codecs and supports loading external codecs, can add similar named files to playlist automatically, can open YouTube links and allows selection of codec for videos from YouTube, can use madVR video renderer, a thumbnail popup of video at specific time can be enabled when hovering over navigation bar, the thumbnail can show the chapter if available, has a dialog for configuring decoders for different codecs (you could use CUDA on NVIDIA hardware instead of DXVA), its D3D renderers support exclusive mode.
The part handling YouTube is external programmable Lua module, can be edited and it's possible to add support for some other site if you find a third party module.
Personally I don't consider PotPlayer great with just vintage PCs and you'll have to look for old version if you want to run it on Windows XP. CUDA is useful there, at least I couldn't combine DXVA with madVR, but that's XP.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 3 of 6, by st31276a
Mplayer has windows builds too. It’s a huge statically linked exe onto which you can drag any video file and it plays. You can also invoke the usual command line options like skiploopfilter etc to speed up decoding on slow stuff.
Reply 4 of 6, by UCyborg
I updated PotPlayer after about 4 years and...what have they done with Window Frame theme? Now it's almost the same as Default other than it still has normal border. So flat, custom rendered controls, no normal menu, just menu button. I was relieved to see that putting WindowFrame.dsf file from the old version in its place restored the familiar appearance.
Reply 5 of 6, by BinaryDemon
Most of my reason for using VLC in the retro era was playing DVDs. But I would suspect that the latest version of VLC that runs on XP might also be the best all around Media Player.
Reply 6 of 6, by marxveix
Anybody have used winvidix (vidix) with mplayer and Win9x? mapdev.vxd and mach64_vid.so i have. Wanted to try mach64 (rage pro) with it. Directx and GL video output works, winvidix not at the moment.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
