What I also remember is that the default NTFS settings do cause a lot of writes.
Things like timestamps about when a file was last time accessed and so on.
There are registry settings to change that behavior, though.
https://www.forensicfocus.com/forums/general/ … tfs-timestamps/
But still, NTFS does at least support creating an alignment that matches the flash cells.
FAT32, the default for USB pen drives or CF cards was worse here.
It wrote data all over the place and was hard to align in any consistant way.
I guess it was mainly used because many outdated OSes had FAT32 support (Win 9x, MacOS 9, Linux).
Edit: The Windows Explorer does cache previews in thumbs.db by default.
It's possible to disable this feature in the Windows Explorer options.
If disabled, Windows will examine each file for an icon or a picture preview, which causes lots of read access.
Bad for HDDs which are mechanically stressed in that situation here,
but that's no problem for SSD and other flash media, afterall.
Edit: Also useful, maybe:
How to kill CF cards ?
https://www.pcengines.ch/cfwear.htm
Microsoft about SSDs vs swap file (Windows 7):
Should the pagefile be placed on SSDs?
Yes. Most pagefile operations are small random reads or larger sequential writes, both of […]
Yes. Most pagefile operations are small random reads or larger sequential writes, both of which are types of operations that SSDs handle well.
In looking at telemetry data from thousands of traces and focusing on pagefile reads and writes, we find that
Pagefile.sys reads outnumber pagefile.sys writes by about 40 to 1,
Pagefile.sys read sizes are typically quite small, with 67% less than or equal to 4 KB, and 88% less than 16 KB.
Pagefile.sys writes are relatively large, with 62% greater than or equal to 128 KB and 45% being exactly 1 MB in size.
In fact, given typical pagefile reference patterns and the favorable performance characteristics SSDs have on those patterns,
there are few files better than the pagefile to place on an SSD.
https://learn.microsoft.com/de-de/archive/blo … id-state-drives
