First post, by wbahnassi
- Oldbie
Hi. I got this Tatung CM-1365 CGA monitor. I've connected it to an EGA card.. but noticed that its colors aren't quite right.
The dark gray is coming out black no matter how high I turn the brightness and contrast knobs.
The monitor has a switch that reinterprets the colors in several ways.. one of which is "invert". Under that mode, I can see that the inverse of dark gray will appear on the screen (see the second screenshot).
I also noticed that brown isn't quite bright amd is very close to red.. and red is very close to light red.
Is this a recap job or something more difficult involved?
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
