First post, by FullYes
Greetings
I’ve been doing some o/c experiments with an MS-5158 based 430TX board
https://theretroweb.com/motherboards/s/msi-ms-5158-tx5
It has the clockgen I mentioned in the heading. I found a datasheet for this model on TRW:
https://theretroweb.com/chips/6011
My actual chip
The attachment IMG_8595.jpeg is no longer available
Like a lot of other TX boards. It will run at 83MHz without much trouble. I am a bit hobbled by my CPU (a k6-3 400AHX, 2.4V) the CPU doesn’t seem to want to go over 458MHz (83x5.5)
I have discovered, moreorless by accident, that this clockgen will output 100MHz, and the system boots at 100x4.5 and I can run benchmarks in DOS, but, a 50MHz PCI bus is creating problems for the IDE controller(!)
I’m running a voodoo3 2000 PCI
My benchmark table
The attachment IMG_8615.jpeg is no longer available
My hope is that someone on here can suggest a way to enable a 5/2 divider. The clockgen appears to support it and I believe the setting at 83MHz in the dataset is the one that’s outputting the 100MHz setting on my board, but instead of running the PCI at 40 MHz, as the datasheet implies, it’s running it at 50MHz
I assume the datasheet is the wrong version for my clockgen. There doesn’t seem to be a lot of info about this chip online. I found only 1 other board with the same chip. An MS-6117 slot 1. No mention on that of any FSB support above 75Mhz
Anyone got any ideas?
Thanks in advance folks!
System 1: K6-3 400, MS-5158 (430TX), 256MB SDRAM, Voodoo3 2000 PCI, AWE64 (Dos/95-early 98)
System 2: Athlon XP 2000+, SL-75KAV (KT133A), 512MB SDRAM, FX5900XT, Audigy 2 ZS (late 98)
System 3: i7-2600k, P8P67-M, 2x4GB DDR3-1866, GTX 460 (XP)
Reply 1 of 11, by rmay635703
If you could disable the ide controller and use one that was used with both pci and pci/66 you could then possibly live with 50mhz pci which boosts performance if you have parts that run that fast.
Worth noting sometimes it isn’t the controller itself causing all the issues.
Using a uide 66 hard drive with an 80 conductor cable made one of my systems with unstable ide on an overclocked bus work fine.
430tx from what I remember has problems with async pci bus clocks, so even if your clockgen creates a different divider I don’t think it solves the problem.
Reply 2 of 11, by FullYes
Thanks for the quick reply. I’m tempted to try that route. I have been looking and Found a few Promise Ultra 100 (and 133) TX2 cards which seem to support 66MHz PCI fairly cheap. Perhaps someone on here will have a recommendation for such a device?
I’m pretty sure it’s the controller but I’ll try an 80 conductor cable. Good suggestion. I’ll need one anyway if I do get one of these add-in cards
Reply 3 of 11, by bakemono
On my Shuttle HOT-433, the onboard IDE would stop working at 60MHz PCI, BUT it would work with XT-IDE BIOS installed. So installing an ISA card with an XT-IDE BIOS EPROM, or inserting it as an option ROM into the main BIOS, might be worth a try.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 4 of 11, by FullYes
That must have taken some detective work!
I would still need a suitable card to add XT-IDE functionality. I don’t think I have a suitable network card or bios chip I could use but thanks for the suggestion! Was the XT on the ISA bus?
Reply 5 of 11, by rmay635703
FullYes wrote on 2026-01-17, 16:49:
Get an isa Ethernet for XTIDE
If that doesn’t work moving vio up from 3.3 volt to 3.6ish may help if your just on the edge.
Reply 6 of 11, by FullYes
Thanks. I'm not sure I can set VIO independently of the CPU voltage. There are only two options in the manual for VIO, 3.3V and 3.52V and 3.52V only seems to be available when setting up the voltage for a single voltage CPU. I could do with perhaps getting a Pentium P54C CPU for this board so I can test undocumented voltage settings
Reply 7 of 11, by rmay635703
FullYes wrote on 2026-01-19, 13:27:
What’s strange is that at least 1 cpu required a 3.52vio but was a split core chip.
Back in the day I had one board that allowed that but it always was perplexing how most folks could actually use said chip.
The Infamous PCCHIPS m590 used a 3.8 volt vio so they could overclock the chipset.
My guess is if you found no other option you could manually break out the vio so the regulator for that always sends a higher voltage, no guarantees that it’s even enough to get stable pc100 on the built in ide though
Reply 8 of 11, by FullYes
Looks like it’s about the same cost for an isa network card and one of those promise IDE controllers. Buying the IDE controller seems more straightforward, as I don’t have a chip programmer or a chip I can use. The only issue with the IDE controller option, is they apparently don’t support CD-ROM detection in DOS.
I’ll lose some Upper memory to bios shadowing, but I guess I will have that with XTIDE as well
My other issue is I don’t yet have a chip that can take full advantage of 100MHz FSB. Having tried to push a bit further - my k6-3 won’t do more than 450MHz at 2.5V. (There is nothing on my board between 2.5V and 2.8v according to the manual) I haven’t yet tried my K6-2 but I doubt I will get it to do more than 500. I need a k6-2+ or a 3+
So i may have to revisit this when ive found a suitable CPU. The prices are quite steep right now here in the UK for the + CPUs
Thanks for your help so far all those that replied!
Reply 9 of 11, by FullYes
I’ve sat on this for a long time but I’m finally getting somewhere
The attachment IMG_9801.jpeg is no longer available
The attachment IMG_9804.jpeg is no longer available
The attachment IMG_9805.jpeg is no longer available
I currently don’t have a cpu that can do more than 450Mhz. This will hopefully change soon 😬
Reply 10 of 11, by Marco
gratulations!
Seems like various TX boards supported 100MHz bus. I owned a Tyan Titan Tiger (2??) board which also supported 100MHz. But it was damn unstable. Maybe due to my memory back in the days.
Good help here from the forum as well!
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 11 of 11, by FullYes
Thank you. Yes indeed I forgot to say thanks in my last post - thanks to everyone that’s helped.
I thought i saw something else in this thread that has helped me, but Ive also been able to keep the onboard IDE working for CD-ROM use, it’s set to PIO mode 2 and it seems to be reading discs fine.
Still waiting on a replacement CPU at the moment to aim for 600MHz
