80486 BIOS image collection
Reply 180 of 188, by PC@LIVE
I have some 486 motherboards, about four or five are working, all VLB, but I have as many to test (and repair), I don't know if you're interested, I'll put a couple of images, of the last two, which I should test soon (if they work) Unfortunately, at the moment I don't have a BIOS screen, nor can I make a copy of the BIOS (stored in the chip), but if you want I can make a list with the manufacturers and models of 486 that I have.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 181 of 188, by PC@LIVE
PC@LIVE wrote on 2023-12-26, 08:59:
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 182 of 188, by tomaszdko
Manufacturer/Identifier: SOYO 025K0
Chipset: 85C407 , 85C471
BIOS/Version: AWARD
BIOS ID : 09/26/94-SIS-85C471B/E/G-2C4I9S23-00
The attachment 20231226_131147.jpg is no longer available
The attachment AA.jpg is no longer available
Images : W27C512
The attachment W27C512@DIP28.rar is no longer available
Reply 183 of 188, by tomaszdko
Manufacturer/Identifier: UM4981AIO V1.3
Chipset: UM8498F , UM8672F , UM8496F , FDC37C665GT , UM82C865F
BIOS/Version: PHOENIX
BIOS ID : ???
The attachment 20231226_131209.jpg is no longer available
Images : W27C512
Reply 185 of 188, by Timpa83
Zalog wrote on 2021-04-07, 13:01:
Yes unfortunately it requires a fair degree of disassembly - fortunately I took one in the middle of an upgrade so if you don't […]
evasive wrote on 2021-04-07, 12:36:
@Zalog: Could you make a picture without the metal support in the middle? Or does that require full disassembly?
Yes unfortunately it requires a fair degree of disassembly - fortunately I took one in the middle of an upgrade so if you don't mind shots of it that are slightly less clear (a bit harder to read the chips at the VGA end of the board) and in non-original condition (added cache chips, overdrive + extra ram) - find attached
Edit: BIOS String is: 40-0100-001131-00111111-111192-UMC480
Hi.
does your L2 cache work with the Pentium OD cpu ?
cant get mine to work with L2 with a 486DX2 cpu it works perfect.
Reply 186 of 188, by Schule04
Manufacturer/Identifier: Shuttle HOT-419 VLB
Chipset: OPTi 82C895
BIOS/Version: AMI Winbios
BIOS chip: ST M27C512
https://theretroweb.com/motherboards/s/shuttle-hot-419
The attachment HOT-419.jpg is no longer available
The attachment Shuttle-HOT-419-VLB(M27C512@DIP28).zip is no longer available
Reply 187 of 188, by analog_programmer
Manufacturer/Identifier: PCChips M912 Ver. 1.4 (this one is with real cache chips)
Chipset: UMC UM8498/8496 (486 VL Chipset "Super Energy Star Green") (CHIP16/CHIP18)
BIOS/Version: AMI + Award BIOS (combined into one 1 Mbit (128 kB) EEPROM*)
AMI BIOS ID: 40-E300-001437-00111111-121593-GREEN-H
AMI BIOS Sign-on: Release 07/08/1994
Award BIOS ID: 07/13/94--2C4X6H01-00
Award BIOS Sign-on: Release 07/15/94'
The attachment M912 1_4.jpg is no longer available
AMI BIOS:
The attachment M912 1_4 AMI BIOS.zip is no longer available
Award BIOS:
The attachment M912 1_4 Award BIOS.zip is no longer available
AMI + Award BIOS combined into one 128 kB image*:
The attachment M912 1_4 AMI + Award BIOS.zip is no longer available
*- AMI or Award BIOS is selected by jumper JP2: 1-2 or 2-3 pins shorted. Short 3-4 pins of JP1 (ext. batt. connector) to clears CMOS when switching BIOSes through JP2!
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 188 of 188, by FlynnTinkers
EFA 4M50HL3, there wasn't a copy on Retroweb so submitted on Discord as well.
