First post, by bionicsa
Desperately looking for this, any version.
I've found one here https://www.retrospace.net/download/Drivers/T … ios_upgrade.htm but its a dead link, i have emailed the owner to see if he can send it for me.
Reply 1 of 7, by bionicsa
I have tried with the 50CT BIOS file i have but i cannot get past the 'Ready for BIOS update' screen, exactly the same issue as this guy had https://youtu.be/kMCHB-ajdJo?t=499
The floppy drive just keep spinning. He fixed it by using another Libretto mainboard 🤣, i dont have one of them 😀
Reply 4 of 7, by bionicsa
Sad to say the same thing, GHGBIOSA and BIOFCE6T written to a 720k disk, power on Libretto with F12, update BIOS screen displays, 1 beep, insert disc into PCMCIA floppy drive, press any key, disc drive makes a read noise, but then just whirs, another beep, screen goes black, waited 5+mins.
I've attached the Toshiba PCMCIA floppy drive to my windows XP machine, and although it shows as a 5 1/4 inch floppy, and takes an age, it does read the disk and whats on it, so i'd say the drive it operational.
Reply 5 of 7, by bionicsa
Does anyone have a video of whats supposed to happen when updating the BIOS of a Libretto when using the F12 method?
Reply 6 of 7, by Pave99
Have you tried making a floppy using the 1030d640.exe from the same self-extracting file? It needs a 1.44 MB floppy and you run it with '1030d640.exe a:'. It seems to create a bootable floppy with those two files in it, which could be critical for the BIOS update. After that I'm really out of ideas.
Reply 7 of 7, by bionicsa
Pave99 wrote on 2026-01-18, 11:51:
Yep, you run that, it put the files onto a 1.44mb floppy, you then have to take CHGBIOSA and BIOFCE6T and put them onto a 720kb floppy.
