First post, by Kotu Koylu
Kotu Koylu
Offline
I want to run MIDI emulation with an AWE64 CT4520 on MS-DOS 6.22.
On several motherboards, the drivers did not work properly due to NMI issues.
Eventually, it started working on Socket 7 motherboards with the 430TX chipset.
However, this time Doom reboots the system, and Lotus 3 causes the PC to freeze.
Only a few games work correctly.
Is there any solution or method to fix this?
