First post, by DustyShinigami
Like the question asks... I just got my Pentium II and I was under the impression it was unlocked based on its model name, but was very disappointed to learn that all the CPU throttlers I have say multiplier adjustment isn't supported. 🙁 Is multiplier unlocking with these older CPUs just down to luck? I'd read that the PIII's are generally locked, but was under the impression the II's weren't...?
This is the model I have: https://www.cpu-world.com/sspec/SL/SL2HE.html
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 5, by paradigital
Only some of the earliest PII steppings were unlocked, most are locked.
Reply 2 of 5, by RetroPCCupboard
I dont think the multipliers on the PII can be changed in software. It would be either jumpers on motherboard or a BIOS setting.
If yours is Klamath core, as per your link, then I think it is not hardware locked multiplier
Reply 3 of 5, by DustyShinigami
RetroPCCupboard wrote on 2026-01-19, 20:04:
Hmm. So, do the jumpers need to be set a certain way on the motherboard for it to be unlocked? Or can it only be adjusted via the jumpers and that's it? The multiplier can be adjusted in the BIOS, but the lowest is 3.
OS: Windows 98 SE
Reply 4 of 5, by gerwin
you are correct on both points.
The multiplier can only be requested at bootup (BIOS or Jumpers). After that brief time window, the request channel is closed.
Reply 5 of 5, by DustyShinigami
Thanks for clarifying. 😀
OS: Windows 98 SE
