First post, by ChrisK
As the title may suggest I'm having a system running Windows XP for testing new old hardware.
I've set it up and activated Windows with an official license by phone may be two years ago and could use it when needed. So far so good.
As I'm not using it very often it only now struck me that Windows wants to be activated again due to changed hardware (or whatever the reason is).
However, if I click the button "Activate Now" it keeps telling me that Windows is already activated and logs me off again just to repeat the game and show the "Windows needs to be activated" screen again at the next login attempt, effectively hindering me to login at all. So yeah, this is that.
Seems I'll have to reinstall it and then...
As rumors say MS did end the possibility for activation by phone entirely at the end of 2025, at least as long as you don't have an account at MS and can do it over some webpage, what's the options left?
I must say I haven't tried the classical way by phone yet again to see if that's correct, though, but imagining there are more poeple out there having the same "problem" I wonder what their solution is? For (legal) activation itself as well as the "WinXP as testing system screeming for regular re-activation" thing.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
