As a serious collector of vintage systems, and the author of ImageDisk, I have seen and used a LOT of different 5.25" drives.
I like TEACs and have had very good luck with them.
I also like (and use) a fair number of Panasonics, in particular the "JU-475" a 5.25" HD drive.
The reason may not matter to you if you are only interested in PC oriented media...
DD drives rotate at 300rpm and transfer data at 250kbps. HD is much more like traditional 8" drives and rotate at 360rpm and transfer data at 500kbps.
To make HD drives able to access DD media at the "wrong" speed, data is transferred at 300kbps instead of 250kbps.
This is essentially transparent for most DD formats (incl. those used on the PC), however there are some vintage formats that many PC FDCs/data-seperators can't do at 300kbps but can at 250kbps.
I like the JU-475 because it is dead easy to add a switch at the front bezel to change it to 300rpm and therefore be able to access media written in these vintage formats.
I have a note of my site about this and how to modify the drive. Look under "Software/Images" near the bottom of the main page.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
