Reply 180 of 190, by DustyShinigami
Quick question regarding SB Pro 2 cards. I noticed on the list of best to worst that N/A is listed for the MPU-401 hanging note bug and slowdown. Does this mean those cards, and earlier, don't support MPU-401 via the gameport?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 181 of 190, by Tiido
SBpro and earlier only have SB-MIDI support, which games generally do not support. MPU-401 support came with SB16 and is subject to a variety of bugs. Most can be fixed by replacing the "DSP" chip with a new one that has one of the recently made fixed firmwares.
Reply 182 of 190, by DustyShinigami
Tiido wrote on 2026-01-21, 15:27:
Ahh, I see. Thanks for clarifying. Yeah, unfortunately, I wouldn't know where to begin with replacing chips. I guess I would have to aim for one with the least problems, if any.
OS: Windows 98 SE
Reply 183 of 190, by DustyShinigami
I suppose, actually, if I were to get another card with true SB/DOS support, I should consider getting an AWE32/64.
OS: Windows 98 SE
Reply 184 of 190, by DustyShinigami
I need a little refresher on something. I've actually forgotten a little detail concerning digital audio/redbook audio and was going through it in my head on the way to work. ^^ Obviously, I have the CD audio cable plugged from the sound card (Yamaha) to the CD-ROM drive, I'm able to play game CDs with redbook audio (both in Windows and DOS), however I'm a bit confused as to how it works with a virtual CD drive and CD image. It makes sense for a physical CD to work due to the audio cable, but how exactly does it work with a virtual one? Whether with a digital audio cable, WDM drivers, or S/PDIF?
I'm pretty sure I did a test with Quake 2, where I just had my Yamaha connected and didn't daisy-chain to the SB, or select it as the primary audio device, and I still received music whilst playing. I'll need to do another test to make sure I'm not dreaming.
On another topic...
Someone informed me of a PCI sound card alternative. It supposedly has the best DOS compatibility and only works with motherboards like mine via an SB-Link header. With the cable, selecting SB, SB Pro or SB16 audio in DOS games just works. Cards such as the YMF724, YMF744 or YMF754. Though I need a CD drive that allows for digital audio and for the Enable Digital CD Audio checkbox to not be greyed out. With my current one though, it is. I was informed the 2-pin cable to the CD drive is essentially the same as coaxial S/PDIF digital, which can be converted to optical TOSLINK using just an LED across the wires, allowing me to use better DACs in the sound card or receiver.
View: https://www.youtube.com/watch?v=_hg_wUcdC4s
Curious what other's thoughts are on this? Or if it's even worth it? Thanks.
EDIT: Yeah, Quake 2’s music plays with the CD image and only the Yamaha connected up. Despite the SB being the one that’s hooked to the CD drive via S/PDIF cable. So I’m curious how a virtual drive and image, along with a sound card that isn’t hooked to the CD drive, can output the redbook audio?
OS: Windows 98 SE
Reply 185 of 190, by NeoG_
Optical drive emulation software plays audio CDs like a wav file, the same as if you were playing an MP3 file in a media player. It would work the same even if your physical CD drive was completely removed from the computer. It also means that the "CD Audio" volume slider doesn't work with virtual CD drives, it's controlled with the wave volume slider.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 186 of 190, by DustyShinigami
NeoG_ wrote on 2026-02-07, 22:45:
Ahhh, I see. Thanks. 😀
OS: Windows 98 SE
Reply 187 of 190, by DustyShinigami
I have managed to find a Sound Blaster 16 CT1600 with the original box, manuals, and disks for about £146.
OS: Windows 98 SE
Reply 188 of 190, by DustyShinigami
Whoop whoop! Just won myself a Roland MT-32 off eBay for about £130! That's a pretty good price considering most have sold around £200+!
OS: Windows 98 SE
Reply 190 of 190, by DustyShinigami
Shponglefan wrote on Yesterday, 16:51:
Nice! Enjoy the MT-33, it's one of the best pieces of audio hardware for retro PCs.
Thanks. Can’t wait to go through the Monkey Island games with it. The first two definitely sound better with the MT-32. ^^
OS: Windows 98 SE
