First post, by marooned_on_mars
- Member
I get this problem using the Munt Win32 driver. In several games I get sometimes those inconsistent tempo (recorded from LSL3) in the music while using DosBox`s midi feature with it set on "intelligent" (I tried to set it on uart but it didn`t fix my problem and it sounded strange and some instruments are muted. I tried to capture the midi commands, but that midi had the normal tempo, tho it didn`t play like in DosBox (yes, I`ve set the output to Munt in Winamp). The other problem is that some crackles appear in some cases (recorded from LSL2). I`ve also attached the recordings, no other programs/processes were running when I recorded those, other than the recorder, other midis from games play at normal tempo when recording with the exact recorder.
My system specifications:
CPU - Intel P4 Celeron D at 2.26GHz
384MB RAM
DosBox 0.71
Munt Win32 Driver 0.1.3
Is there any solution (besides using the Munt CVS?)
