Reply 1020 of 1146, by PC@LIVE
- Oldbie
Well maybe today it went a little better, at least I spotted where the problem is!!!
We always talk about the SMT-486 Terminator motherboard, what I suspected, was not wrong at all, and having seen codes sometimes, made me think that somehow the board was ready to start, but something prevented it.
I had a doubt that some jumpers were not correct, there are really many, and it is not well explained what they do (?), but they can be considered correct, even if strangely between a DX-33 CPU is a DX4-100, the only different thing looks like the Voltage, I don't know maybe this card has an automatic recognition of the multi, or are the CPUs that are able to select it by default, I didn't look for info about it, so I keep the selections found in the manual for good, and I hope they didn't get confused before going to print.
The points that are most suspicious for me are the RAM banks and the CPU Socket, I tried to move the RAM from one bench to another, and I got nothing, no start sign, so I decide to try to remove and put the CPU back, here there is something positive, sometimes I see the code C0 —, this means that something started, but it failed to continue.
After several attempts, it gets to display a couple of 0b 0A codes, at that point I don't know, I was trying to understand if it was blocked, but shortly after surprise !!!
In the video there is the BIOS screen, which asks to press F1 or Delete (or F2?), I press F1 and it continues, of course without any drive connected, I can't do anything!
I restart and enter the BIOS, it's quite simple, but I would say adequate compared to other 486, and it's not essential, obviously its limits, are largely due to the type of PC, but from what I see, you can optimize some items to make it a little faster, in this regard, only after turning it off, I realized that the L2 cache is 0 KB, while on board there are 4 chips for a total of 256 KB, unfortunately I couldn't do much else, because after a few minutes of operation, it crashed, and not It was possible to restart it, I'll try again ️ as soon as it cools down, and for the record, the CPU was an Intel 80486 DX33, and the VGA was ISA Cirrus Logic.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
