First post, by McBierle
Hi, i wanted to share this little story of a 386 motherboard (and me).
A few months ago i got this 386 motherboard with a ram-extender card. I diddn't find any info on stason or th99. If anyone has more on this one please tell me.
I started my retrolife around 1,5y ago and have some 386 motherboards (among other). This motherboard was somehow special because i never have seen a board without ram sockets.
Sadly i forgot to make pics in its original state. The cache sockets, 2 isa slots and most parts in the topleft corner showed corrosion, also some traces of the top layer. First i cleaned it the usual way but i decided it wouldn't be enough, also it wouldn't post.
So as someone once said i decided to remove everything from that corner and replace it with new parts, not because it is easy but because it is hard... 😁
Here you see it in mid removing. And the corroded top layer of the traces.
Hooray i removed everything.
Cleaning the corrosion from the traces.
Midway resoldering. Three extra sockets for logic chips, sadly no room under the keyboard bios.
Aaaand finished.
I braced myself for the case that it still wouldn't life. First power on i was the first time lucky that i wear glases, because one tantalum exploded and hit my glases. After replacing the corpse of that tantalum i was lucky the second time because my wife haddn't her mobile at hand because the board posted and i did a probably stupid looking dance...
Some pics of the setup:
Sooo now i have this board with 16mb ram and an XCMOS i never had before and don't know whta to do with. Who needed 16mb ram back then. What is this xcmos, new things to learn....
Backgroundinfo:
As i stated earlier i started this "retrolife" roughly 1,5y ago. Before i just had some floppy bigbox games i had from back then. To whomever asks i always say maybe it's my midlife crisis, but i wanted to remake the first pc i had. Well now i have tons of "old" stuff. I have a soldering iron i never did anything with before. And i'm still working on my ongoing special project which involves working with wood, also new to me.
It all takes loads of time, which i asume you know from your own experience. Between my family and work everything takes sooooo long.
Disclaimer: Sorry for bad grammar and stuff. Firstly I'm not a native speaker and secondly i had some drinks 😀
Greetings!
Reply 1 of 17, by quicknick
That's an interesting board. Congratulations for your patience, it's always nice to see such an extensive (and succesful) repair!
Reply 2 of 17, by Predator99
Incredibly good work you made there....! And the board is also very nice. How many hours did you spend on this..?
Reply 3 of 17, by Caluser2000
Well done. You can't have enough ram.
Reply 4 of 17, by pipmastah
Dusting off this topic 😀
That's a very nice rebuild indeed, McBierle! A friend of mine gave me an old big tower with a similar but slightly older C386 mainboard. This one is the 25Mhz flavour 😉
Mine is also completely destroyed by the evil Varta and there are a few parts missing like the CPU, the cache controller and the 32-bit external memorycard.
This memorycard seems to be unobtainium so I was wondering what type/brand this unit is... Looks to be an "ISA130" card but I have no idea what search term to put in the old googly box to find even a single picture of one.. The only picture I found was your giant card with 16 SIMM sockets but I have no idea what brand/model number/FCC ID this thing has. Could you help me with that? Very much appreciated! 😀
Reply 5 of 17, by ChrisXF
My 386 board has a similar bonkers '32 bit RAM slot':
https://stason.org/TULARC/pc/motherboards/D/D … BACK-CACHE.html
I also have no idea what's meant to go in there, or why it would be useful when the board has SIMM space for the full compliment of RAM possible? Maybe to allow you to upgrade without spending on new RAM?
Reply 6 of 17, by pipmastah
McBierle wrote on 2019-06-01, 21:05:
Hi McBierle,
Could you please post some pictures of the 32-bit memory expansion card that came with your C386 mainboard? I would appreciate this very much as I got one of these mainboard from a friend.. Mine is a C386-25 and it does POST but it lacks the memory board which seems unobtainium rendering this thing of beauty entirely useless as far as I know.. I've been searching for weeks for boards like these but the only info I could find is your post.. I wonder if that memory card is somehow standardized or has a type / brand badge on it.. It's also unclear who manufactured these mainboards. Mine only has a label "Celem" on it which appears to be a reseller from Belgium (I'm in the Netherlands). It also has no FCC id so it's next to impossible to determine what this alien board even is 😉 The only thing printed on the board itself is "C386-25" and "Made in Taiwan R.O.C." which is about as generic and useful as "This is a thing" 😉
Thanks in advance for any extra pictures of this memory board you may want to share if you're still active here on Vogons!
Cheers!
Reply 7 of 17, by rasz_pl
+1 please post pictures of the memory card back and front.
Its interesting to see its not just SIMM slots but has logic chips onboard, thankfully they all look standard 74 series and not custom programmed PAL/GAL so reproduction is entirely doable.
Reply 8 of 17, by McBierle
pipmastah wrote on 2023-09-27, 22:25:
Hi McBierle, […]
Hi McBierle,
Cheers!
Sorry was a long time not here. Somehow i forgot to set email notofications. Some Pics...
Reply 9 of 17, by rasz_pl
Thank you!
So the memory board is called "386RC-16". Indeed only 244, 240 (why inverters?), and bunch of 32 OR gates. Easy to replicate.
Your motherboard looks related to MODULAR CIRCUIT TECHNOLOGY MCT-C386-33/40
https://stason.org/TULARC/pc/motherboards/M/M … C386-33-40.html https://arvutimuuseum.ee/th99/m/M-O/32479.htm
ChrisXF wrote on 2023-07-30, 11:51:
different slot, another MODULAR CIRCUIT TECHNOLOGY mobo uses same slot https://theretroweb.com/motherboards/s/modula … -mct-m386-20-25
Reply 10 of 17, by Disruptor
McBierle wrote on 2024-10-23, 17:45:
If that machine still exists:
Can you run ctcm from heise?
I'd like to see whether you have a problem with cacheable area 😀
Reply 11 of 17, by rasz_pl
Disruptor wrote on 2024-10-24, 08:24:
cachechk shows whole 16MB cached?
Reply 12 of 17, by rasz_pl
pipmastah how motivated are you about that ram board?
I was bored and checked if it would be possible
The attachment 386RC-16.jpg is no longer available
only routed few lines, but it all makes sense. Still might only be possible with some more extensive McBierle help (more pictures with no simms, at better angle/lighting, and crucially some continuity measurements on the finish line) + you tracking slot pins to nearby chips.
Reply 13 of 17, by McBierle
Bad news. I took the board from "cold Storage" and tried to do as you requested but there seems to be a short somewhere with the 12v lane. I'll try to find the cause, but as always problem with to few time.
rasz_pl wrote on 2024-10-30, 11:58:
pipmastah how motivated are you about that ram board? I was bored and checked if it would be possible […]
I would certainly help where and if i can. I would even send the board per mail.
Reply 14 of 17, by rasz_pl
McBierle wrote on 2024-10-30, 20:11:
Surprising considering you replaced tantalums sitting near the AT power connecter. I hope its nothing major.
That would be fantastic. Im still in the very early stages of assessing feasibility of this endeavor. PCB this size + parts + shipping is going to end up around $100, and so far You and pipmastah are the only people to ever have one.
I hope to b able to get it up to ~70-80% completion before needing more help by logic deduction alone. Im interested if I can guess what the chips are doing by just solving it like a puzzle 😀
The attachment 386RC-16 about 10%.jpg is no longer available
The attachment 386RC-16 about 10%b.jpg is no longer available
Reply 15 of 17, by rasz_pl
Hello Police? I would like to report a crime. An Asian gentleman murdered signal integrity on several tracks 35 years ago!
Yes, I have witnessed the whole thing. Data bus on the power layer with address bus right above it. Address bits 0 and 1 right over data bits 6 and 7.
Yes, exactly, no ground whatsoever at ~30MHz.
I agree, manslaughter charges would be appropriate.
The attachment crime.jpg is no longer available
In other news its done 😁 and boy was it fun!
The attachment 386RC-16 90%.jpg is no longer available
The attachment 386RC-16 90% b.jpg is no longer available
90% done to be precise 😜
- slot placement is hard from picture alone
- dimensions are slightly off and needs measuring clearances
- hard to guess which pins are 5V or ground on the connector. Half of them has tantalums with painted ground pin, but the other half doesn. Better to verify.
- I didnt bother with capacitors before confirming dimensions
- most importantly whole CAS situation needs few more pictures or measurements because previous pictures had dust bunnies 😁 Too many tracks run under 74F32 chips to attempt an educated guess 🙁 82C302 generates 4 CAS signals but this board takes 8, very possibly pairs of pins are joined on the motherboard. solved, would only need sanity check in continuity mode.
The attachment 386RC-16 diagram 90% WTF CAS.png is no longer available
McBierle could I bother you for a few more pictures? It doesnt look like pipmastah will be back so that would be strictly to satisfy my curiosity. Front of the board with simms removed concentrating on
- gaps between simms so I can confirm/compare against my work. That was a fun and challenging part to route.
- center of the board on U7 U7 U8 U9, Im interested in pictures at an angle with good lighting/flash. Maybe with any luck I could peek under the chips a little 😀
- picture of motherboard lower right corner, slot and three C%T chips
- picture of the motherboard memory slot from the back
Messy diagram, too big to upload as png
The attachment 386RC-16.pdf is no longer available
I think I found another motherboard sharing same Chips & Technologies CS8230 chipset, bios (EC&T-1331-040990-K8 while OP one is EC&T-1190-040990-K8) and maybe ram board pinout https://theretroweb.com/motherboards/s/ecs-386a, minus the cache.
Reply 16 of 17, by rasz_pl
Good sleep and 17 hours later I understood the CAS driving mechanism in just few minutes of staring at it 😁
Whoever designed this memory card made sure its flexible enough to be able to work with different memory controllers (or interleaving configurations). One set of 4 CAS pins drive consecutive SIMM sockets in a Bank, the other set drives whole banks per CAS line. Brilliant. Tracks under chips line up perfectly.
The attachment correct_CAS diagram.png is no longer available
The attachment CAS_slot_pinout.png is no longer available
EDIT: uploaded whole RE job to github https://github.com/raszpl/386RC-16
I also found predecessor to McBierle C386-33, Modular Circuit Technology MCT-386-M. Date on a sticker 1.9.87. 386DX 20 and IIT FPU 387 20Mhz.
The attachment MCT-386-M.jpg is no longer available
and earlier version of proprietary memory card, pre SIMM!
The attachment MCT-386-M RAM CARD.jpg is no longer available
matze79 uploaded those pictures to https://dosreloaded.de/forum/thread/330-modul … ze-at-mainboard in 2017
Reply 17 of 17, by pipmastah
Wow! Excellent work rasz_pl!
It has been a while since I visited this topic. My board is now an exhibit piece on a shelf in one of my man caves 😉
I would still be very interested to build/order one of these boards though!
