DOS Questions
Reply 160 of 258, by DustyShinigami
NeoG_ wrote on 2026-01-25, 21:23:
And somewhere in your autoexec.bat to avoid unexepcted behaviour […]
SET EK1MLOAD=FALSE
Regarding this though, wouldn’t there need to be a reference to EK1MLOAD from a game’s BAT file within autoexec.bat? At the moment it’s only in one game’s BAT file.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 161 of 258, by DustyShinigami
REM Skip executing SB commands if already loaded
IF %EK1MLOAD% == TRUE GOTO SKIPEK1M
It’s telling me there’s a syntax error here.
EDIT: Ah. I think I needed to have no spaces between % and T for True. 😅
Although the game is failing to load due to not enough memory. Seems plenty though. Will have to try XMS mode.
EDIT 2: No, it’s still saying there’s a syntax error. 😕
EDIT 3. Bugger. Of course… It has to be in EMS mode in order for SB16 Emulation to work. 😖
EDIT 4: Not sure then if the likes of MPXPLAY and EK1M are eating up a certain amount of memory needed for the game to function…? Though like I say, there’s plenty of it still. Especially as a number of things are loaded into the UMB. But it just tells me DOS/4GW fatal error (1307): not enough memory.
OS: Windows 98 SE
Reply 162 of 258, by NeoG_
DustyShinigami wrote on 2026-01-26, 00:02:
It will give a syntax error if the variable has not yet been declared, hence why I said to put SET %EK1MLOAD%=FALSE into your autoexec.bat file
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 163 of 258, by DustyShinigami
NeoG_ wrote on 2026-01-26, 12:02:
Ahh, okay. But is it written like...?
SET EK1MLOAD=FALSE
Or...?
I'm still struggling to understand how autoexec.bat would see/know that variable/command in a game's BAT file exists. I've only added the line to call my new SBLOAD.BAT file, but there's no reference in the game's BAT about autoexec and vice versa.
OS: Windows 98 SE
Reply 164 of 258, by NeoG_
Apologies, it is SET EK1MLOAD=FALSE
There doesn't need to be any reference between SBLOAD.BAT and autoexec or vice versa. If declare a variable in autoexec it's global and it's available from any batch file in the future
Reply 165 of 258, by DustyShinigami
NeoG_ wrote on 2026-01-26, 12:23:
Oh right. Very convenient of DOS. I only have a bit of experience with coding in C#, though that was ages ago now, and I was under the impression something needed to be referenced in order for another script to see it. 😀
OS: Windows 98 SE
Reply 166 of 258, by wierd_w
Things defined with SET become global envirionment variables. DOS (the OS) does not have private variables outside of batch scripting.
Reply 167 of 258, by DustyShinigami
wierd_w wrote on 2026-01-26, 14:24:
I see. That's good then.
OS: Windows 98 SE
Reply 168 of 258, by chronoreverse
Are you still seeing this? Check the output of mem /c to see if it's really a low memory issue because some games have problems when there's _too much_ memory.
Reply 169 of 258, by DustyShinigami
chronoreverse wrote on 2026-01-26, 15:53:
Once I've corrected the IF command statement, I'll see if it still does. I believe it's the latter option as you say. When I checked last night, there was plenty of memory left over. Ordinarily, I would use XMS mode instead, but as I mentioned, I need EMS for the SB16 emulation and redbook audio.
OS: Windows 98 SE
Reply 170 of 258, by DustyShinigami
Yeah, so even with the corrected syntax, it still comes up with the error. This is how the memory is looking:
The attachment IMG_5302.JPG is no longer available
The attachment IMG_5303.JPG is no longer available
OS: Windows 98 SE
Reply 171 of 258, by wierd_w
That is *very good* conventional free.
It's in the side of 'too much free' in fact.
Try running your program with loadfix.
Reply 172 of 258, by DustyShinigami
wierd_w wrote on 2026-01-26, 17:15:
Not come across loadfix before. I tried it as LOADFIX CALL=D:\DOS\ACCLAIM\TRILOGY\TRILOGY.EXE and LOADFIX D:\DOS\ACCLAIM\TRILOGY\TRILOGY.EXE. I'm guessing CALL can't be used in this case, but even removing it, I get a Bad command or file name.
OS: Windows 98 SE
Reply 173 of 258, by DaveDDS
DustyShinigami wrote on 2026-01-26, 12:13:
Ahh, okay. But is it written like...? […]
SET EK1MLOAD=FALSE
Or...?
FYI - then '%'s around a name in a .BAT file causes that name to be replaced with it's environment value.
So.. "set" needs the actual environment variable name, NOT it's content (if it exists) = no '%'s
set FOO=Some-Stuff
echo FOO -> prints "FOO"
echo %FOO% -> prints "Some-Stuff"
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 174 of 258, by Harry Potter
Do you have LOADFIX? I think it's a third-party program and doesn't come with DOS.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 175 of 258, by DustyShinigami
Harry Potter wrote on 2026-01-26, 17:44:
Ah. That’ll be why then. I thought it was a part of DOS. 😅 I’ll grab that now. Thanks.
OS: Windows 98 SE
Reply 176 of 258, by DustyShinigami
DaveDDS wrote on 2026-01-26, 17:43:
FYI - then '%'s around a name in a .BAT file causes that name to be replaced with it's environment value. […]
SET EK1MLOAD=FALSE
Or...?
set FOO=Some-Stuff
Gotcha. It’s a container.
OS: Windows 98 SE
Reply 178 of 258, by DustyShinigami
wierd_w wrote on 2026-01-26, 17:52:
It's from the freedos project. It will work with dos 6.22 as well.
https://help.fdos.org/en/hhstndrd/command/loadfix.htm
Do I need to download and install FreeDOS to get it?
OS: Windows 98 SE
Reply 179 of 258, by wierd_w
DustyShinigami wrote on 2026-01-26, 18:08:
No. You can get it individually. The FreeDOS one is apparently baked into FreeCOM command interpreter, but it's existed as vintage software forever.
It's actually a stock component of DOS 5, and can be found in various flavors from numerous vendors. They all do the same thing.
For example, vintage adverts and documentation reference it.
https://archive.org/stream/dosworld021199505/ … 995-05_djvu.txt
A version from Novell can be found here, for example.
https://files.mpoli.fi/unpacked/hardware/net/ … /3x/300pt1.exe/
The dos 5 utility can be found on disk 3 of the set, and expanded with the EXPAND utility. It's a .COM file.
https://www.betaarchive.com/wiki/index.php/Mi … B_Archive/71823
This script suggests it can be found (compressed) on disk 2 of the dos 6.22 disk set.
https://gist.github.com/jepebe/4011bb9d0b0dfa … 8ff026675eb275b
