Reply 960 of 1214, by Falcosoft
- l33t
MattRocks wrote on 2026-01-25, 19:20:I am feeling a bit numb right now because the summary of all online complaints about Vista audio collapses to users simply misco […]
Joseph_Joestar wrote on 2026-01-25, 14:43:Falcosoft wrote on 2026-01-25, 14:10:As I said already I have only Audigy and Audigy2 ZS cards. I have found absolutely no evidence for such 2 faced behavior. The only relevant kernel drivers are ctaud2k.sys and ha10kx2k.sys. There is no trace of cthda.sys at all.
For reference, there is no cthda.sys on my Win10 system with an X-Fi Titanium Fatal1ty Professional (SB0886) either.
I am feeling a bit numb right now because the summary of all online complaints about Vista audio collapses to users simply misconfiguring their systems!
If you continue running the NT6 EAX test with hardware mixing, and in the middle of that test you play a Windows audio sound - does the Windows audio simply play on top of the EAX audio as it would on NT5?
The NT6 WASAPI cannot see anything of the OpenAL kernel-stream, so if that test works then NT5 style sound card mixing is fully functional on NT6. Does that rewrite history?
Yes, of course. Other audio/Windows sounds play on top of the OpenAL EAX audio. Test video:
https://youtu.be/SwoiDzsF27M
