Reply 140 of 155, by Gurbymurble
oh yes! I got it. Wow I didn't see the start of this thread. I started at the suntek part that was linked to from another site. I see a lot of trying things was done to find settings.
Good starting points for us. And that software will help a lot!
Reply 141 of 155, by MarmotaArmy
Thanks a lot Predator , It's working now!
I had some trouble figuring it out but eventually I could understand (I believe) the logic behind it
Here is the testext result
The attachment 20260121_195801.jpg is no longer available
After a while.... I understood that this is showing the 2 megs memory expansion immediately after the base memory (512k detected by the Olivetti)
Then I applied the SW1 settings as you posted:
SW1: OFF OFF ON OFF OFF OFF OFF OFF
And success , It took 128K for shadow ram and another 128K to expand base memory to 640
The attachment 20260121_203020.jpg is no longer available
The attachment 20260121_202540.jpg is no longer available
Now, for testing purposes the first game that I played on my first PC (an AEG olympia with 286 and 1mb ram)
The attachment 20260121_205252.jpg is no longer available
A final question, if I want to use EMS, apart from setting the DIPs 5 and 6 on SW2 , which drivers is recommended ? (I guess EMM386 is no option since this is a 286 system)
Reply 142 of 155, by Marco
May I ask how the performance is? Do you notice any dramatic speed decrease?
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 143 of 155, by MarmotaArmy
Marco wrote on 2026-01-22, 13:15:
I can't tell, I just got this PC and I'm just testing it for now. It's a 286 running at 8mhz so slow is a feature
Reply 144 of 155, by Predator99
Very good thanks for the feedback. Think you also understood how it works 😁
So with your current config the RAM-card fills the gap between 512kb - 640 kb and then again at 1024MB?
Therefore when you run testext with the current config the last 00000000 block will change to FFFFFFFF? Can you try it? Run testext 3000, its finished faster then 😉
Reply 145 of 155, by MarmotaArmy
Predator99 wrote on 2026-01-22, 13:29:
No problem I'll give it a try tonight.
About EMS drivers , any recomendations? , You used a RMS.SYS driver but I can't find it.
Reply 146 of 155, by MarmotaArmy
It indeed changed to FFFFFFFF
here are the results
The attachment 20260122_195233.jpg is no longer available
The attachment 20260122_195310.jpg is no longer available
The attachment 20260122_201001.jpg is no longer available
Please, could you point me to where i can find the RMS.sys driver or to another that can work with this card? I would like to leave some EMS space to try commander keen or maybe wolf3d in a tiny box.
Reply 147 of 155, by Gurbymurble
Here are the settings that worked for me for 1 and 2 megs installed. Machines are IBM AT with 512k ram.
Reply 148 of 155, by Predator99
Next card: PE-5060-C with extension board PE-5061-C
The attachment PE-5060-C-F.jpg is no longer available
The attachment PE-5060-C-B.jpg is no longer available
The attachment PE-5061-A-f.jpg is no longer available
The attachment PE-5061-A-b.jpg is no longer available
Reply 149 of 155, by Predator99
There seems to be something wrong with this card. I tested in 2 different 286 boards.
The main board has 3 banks with 512 kb each.
In testext, bank 2 and 3 are shown with correct size. However, for bank 1 only 384 kb are shown. Additionally there is a gap of 384 kb between bank 1 and bank 2.
When selecting another starting adress, the whole pattern moves. The size of the gap stays the same.
Any idea what could be the reason for this..?
The attachment testx.jpg is no longer available
The attachment Bank.jpg is no longer available
EDIT: spotted a small damage...will check later
The attachment dmg.jpg is no longer available
Reply 150 of 155, by Predator99
Traces are all OK...I have no idea what can be wrong.
I didnt find anthing about the manufacturer "PE". Here is an offer for another "PE-200" RAM card with a label "80 data". Seems to be the same manufacturer:
https://www.recycledgoods.com/80-data-control … er-card-pe-200/
Also found an overview of EMS cards here
https://www.atarimagazines.com/compute/issue1 … sion_Boards.php
Interesting also this link for "MOVE'EM CONFIGURATION GUIDE". There are the names of EMS drivers for several card. I.e. for the CEI
Computer Elektronik Infosys Ramflex - he EMS driver provided with the Ramflex board is called IMM4.SYS
Qualitas Move'em: This software is included inside 386MAX v 6.0 installation disk.
https://github.com/user-attachments/files/243 … 75/EMSGUIDE.TXT
Reply 151 of 155, by Predator99
I didnt give up with PE-5060-C that early and tried some other DIP combinations...and I noticed when switching DIP1 the gap in the card-RAM disappears!
So why is there a gap of 384 kB when DIP1 is set to "ON"...yes, its a configuration for PCs with less than 640kb RAM. It fills the area up to the 640kb. Then there is a gap of 384 kB for the ROM space. Then it continues at 1024 kB.…
The card is not damaged and 100% OK 😀
So with DIP 1 set to "off" it was rather easy to get the other settings....
DIP 1:
ON: Backfill / OFF: No Backfill
DIP 2-4: starting adress kb
OFF OFF OFF: x.0 k (000 )
ON OFF OFF: x.128 k (100)
OFF ON OFF: x.256 k (010)
ON ON OFF: x.384 k (110)
ON OFF ON: x.640 k (101)
OFF ON ON: x.768 k (011)
ON ON ON: x.896 k (111)
DIP 5-8: starting adress mb - 0=OFF, 1=ON
0000 1.x m
1000 2.x m
0100 3.x m
1100 4.x m
0010 5.x m
1010 6.x m
0110 7.x m
1110 8.x m
0001 9.x m
1001 10.x m
0101 11.x m
1101 12.x m
0011 13.x m
1011 14.x m
0111 15.x m
1111 16.x m
So for a starting adress of 1.384 MB in a 286 with 1 MB onboard the setting needs to be...
OFF ON ON OFF - OFF OFF OFF OFF
There is no DIP left and I assume the jumpers relate to the I/O ports. Therefore this card can only do XMS but no EMS.
Reply 152 of 155, by Predator99
Next card is the DFI MF-3000. Some jumper setting are here, but not very complete.
https://theretroweb.com/expansioncards/s/dfi-mf-3000
Will try to add some data later.
The attachment MF3000-F.jpg is no longer available
The attachment MF3000-B.jpg is no longer available
The attachment MF3001-F.jpg is no longer available
The attachment MF3001-B.jpg is no longer available
The attachment DFI.jpg is no longer available
Reply 153 of 155, by Predator99
I have some difficulties with the MF-3000. There are some deep scratches on the backside. as far as I can see I have fixed the broken traces, but the result is still not OK. I am not sure if there still a broken trace, a damaged IC or RAM or wrong DIP setting.
At least it seems the starting adress configuration on DIP1 corresponds exactly to the DFI AT-Rambank, so the missing ones at theretroweb can be added easily.
The attachment 3000.jpg is no longer available
The attachment 3000-2.jpg is no longer available
Reply 154 of 155, by Predator99
wierd_w wrote on 2025-02-16, 04:40:
It might be possible to figure it out by seeing which pins on the card edge are actually connected to stuff. The most sensible […]
It might be possible to figure it out by seeing which pins on the card edge are actually connected to stuff. The most sensible way to trigger the ems window move is a write to an IO port. Seeing what is actually connected to the right pins for that can help figure that out.
A BASIC program can do the IO write, and do PEEKs to see if a window swap happened.
In fact, one COULD just exhaustively test the whole adapter region with peeks and pokes, after testing an IO port write.
Something like...
For TestAddr=C000 to EF00 Step 64k
For TestIoAddr=0 to 65535
For IoTestByte=0 to 255
Poke (TestAddr,"AA")
OUT TestIoAddr, IoTestByte
If NOT Peek (TestAddr) = "AA" Then
Print "Found EMS page op at Address: ", TestAddr, ", with IO byte ", IoTestByte, " at IO Address", TestIoAddr
Else
Endif
Next
Next
Next
granted, this doesnt verify that there's RAM there first, but you should get the idea.
Naturally, you should exclude well known port addresses (220, 230, 250, 330, etc...) as well.
Just saying a relatively simple program can find out this info.
Thats not a bad idea. I again played with my CEI cards. They have lot of DIPs. For most of them I didnt understand so far what they do.
I have found a program that scans the I/O ports in realtime: IOVIEW
With the PC powered on and IOVIEW running, I played with the unknown DIPs. And for some DIPs the I/O ports or the data returned changed. So with this method its possible to figure out the I/O base and how its set.
I tried some drivers from other EMS-cards but as expected they didnt work. At least for this complicated card its almost impossible to find the settings without the software.
See also here for my search for the CEI drivers:
Company: CEI Computer Elektronik Infosys of America - Driver needed for RAMFLEX memory card
The attachment IOVIEW.ZIP is no longer available
The attachment IOVIEW.jpg is no longer available
Reply 155 of 155, by weedeewee
Predator99 wrote on 2026-03-21, 09:33:
Just an FYI,
There's also a program called IOSPY which is included on the disk that comes with the book The Undocumented PC
and is available for download.
IOSPY - A TSR to monitor specific I/O port status on screen while
other programs are running. Supports monitoring multiple I/O ports
at the same time, alerts on value changes, and many other options.
Do not ask Why !
