First post, by FlynnTinkers
Have been searching around on these but figured I could make a thread with my photos, in case anyone else has one of these units or is curious.
I am hoping to use two of these on a couple old builds (Socket 3, Socket 7) solely for legacy I/O usage. I had been using a bench Tier A ATX power supply from 2019 with an AT adapter to test a cache of old hardware without any issues, until I tried the Socket 7 board with a VGA card in the last ISA slot. Power-on fried a tiny break in the +12V rail, and cooked off the silkscreen in three or four little via runs on the rail. Patched it, tried a different VGA card in the first ISA slot; no issue. Moved it to the last slot, same phenomenon. Got a separate socket 7 junk board + different ISA VGA card, and was able to reproduce on the second to last ISA slot of this one; burned a tiny hole in the +12V via. I assume modern ATX PSUs are unsafe in some applications with AT hardware (massive transient swings?) since +12V wasn't designed for heavy duty on AT board, but this is just conjecture.
The units are:
  • Holly 235W
  • Solar Power 300W
  • Packard Bell PB150C
Attached photos. I am not quite skilled enough yet to be able to spot quality features (EMI filter, overcurrent protection), and I fear the worst given the reputation AT power supplies have. Just curious if anyone can spot an immediate red or green flag with any of these. They'll be powering a Socket 7 that theoretically could 130W maximum , and a 486 VLB below that.
Reply 1 of 5, by TheMobRules
Just speculation on my part, but as modern ATX power supplies can deliver large amounts of current on the 12V rail, it may take a bit longer for the short circuit protection to kick in compared to an older unit, thus giving it more time to fry traces on older boards.
As for the 3 AT units, keep in mind that there are usually not many variations when it comes to design, most of them use the same tried & tested architecture. So you should focus on component and build quality.
Now, from those the Packard Bell one is clearly the best: well built, they didn't skimp on "optional" components like the EMI filter, good quality Japanese caps. Don't be mislead by the apparent lower power rating, if anything it's probably underrated and can do a few watts more... in any case it's more than enough for any normal AT build unless you plan to stack multiple mechanical hard drives.
Of the other two, I'd use the Holly unit but if it's going to power something you consider valuable I would probably refurbish it with new capacitors and proper safety rated X/Y caps on the line filter. The transformer is on the small-ish side, but it's probably OK for up to about 150W.
The "Solar Power" is the most dubious, anemic primary side caps, small transformer, almost non-existent line filter and "2 diodes on a bracket" for the 12V rectification. You could probably make something decent out of it but I don't think it's worth it, you can probably get a nice old Delta or Astec unit for the same money that you'd have to spend on components.
Reply 2 of 5, by FlynnTinkers
Thanks! That helped me get my bearings. The Holly tested eerily dead-on, right down the line accurate on all rails (hooked up 3 bad old Conner HDDs to get the engines firing). The Packard Bell is ~11.5 on the 12V rails, so not sure if that would affect drive operation. Not going to bother with the Solar.
Reply 3 of 5, by Horun
TheMobRules wrote on 2026-01-27, 03:48:
Agree and well built ! It just needs a fan.
Reply 4 of 5, by TheMobRules
FlynnTinkers wrote on 2026-01-27, 17:09:
11.5V should still be OK, but if you only used hard drives to test the PSU, try it with a more "realistic" configuration (such as MB+CPU+1HDD), that will provide a more balanced load which may result in voltages closer to the nominal values.
In any case, that PSU also has a trimmer resistor that you can adjust with a screwdriver (use a plastic one and be careful if you do it with the unit on!) to fine tune the voltage. Keep in mind that it will probably affect both the 5V and 12V rails, so be sure to measure both after adjusting.
Reply 5 of 5, by Matth79
Group regulated, so if you only test load the 12V, it will sag and the +5V will rise
