First post, by atar
Trying to restore a Toshiba T1950CT laptop. Bought a replacement belt on German EBay, and it kind of works for a few floppies, but at some point the belt slips of a pulley. It feels like a belt is maybe 1-2 mms too long, but this is unlikely because the guys sell quite a lot of this belts and I see no complaints.
Have cleared the motor and the pulleys multiple times, doesn't seem to help. Actually the old one hasn't have sicked to anything.
After fitting the belt it works really good some minutes, maybe one hour, and then slips off, the drive starts making weird noises and dramatically increasing the read errors rate. Then, after re-fitting it's ok again till it slips off the next time. The cherry on a top is that this drive is really at the bottom of T1950CT, I literally have to disassemble the whole laptop to get to the floppy drive.
So, the questions:
- am I doing something obviously wrong?
- has anyone successfully replaced the belt in Citizen V9DA-71B?
- Can V9DA be replaced with a more reliable maybe even beltless drive? It seems that not all 26 pin drives have the same pinout.
