Reply 58140 of 58884, by Ozzuneoj
bestemor wrote on 2026-01-29, 17:30:
Sorry for stupid question, but... what is so great about a Roland RAP10 ?
(genuinly curious)
I remember almost buying one many many years ago, while looking into Roland sound cards, but could not find a worthwhile usecase for its limited capabilities, so I left it alone.
Basically, it is a Roland SC-7 wavetable synth on a sound card, combined with Roland-specific (not sound blaster compatible) digital audio. A fair amount of games in the early to mid 90s specifically supported it, but from a practical standpoint it makes more sense to just use a more common (and compatible) card alongside an external Roland MIDI module to get similar or better music quality.
As for why I want one, I'll just copy and paste what I posted a while back when I tried to explain my interest in the RAP-10...
I've been keeping an eye out for a Roland RAP-10 for a while and they have so far eluded me. And it isn't exactly a practical thing... I have six or seven Roland modules that have the same or better MIDI samples. I think for me I just remember messing with the sound setup in DOS games in the late 90s under Windows 98 and in my totally uneducated mind when I selected "Roland RAP-10" as the music device it always sounded 100 times better, so I figured that device must have been really special. In reality, it was just the GM soft synth on whatever sound card I was using at the time being used rather than some kind of poor FM emulation if I selected a Sound Blaster or other similar device. Still, it created a kind of mystique around the RAP-10 for me. Totally illogical now that I know what I know and have so many alternatives, but I still want one in my collection.
Reply 58141 of 58884, by Shponglefan
(genuinly curious)
As a RAP-10 owner... honestly not much.
It has a genuine Roland sample set, so it's good for General MIDI playback. However, there is limited support for its digital audio capabilities and it doesn't even have an intelligent mode capable MPU-401 interface.
A Roland SCC-1 along side a Sound Blaster compatible card is a much better option than a Roland RAP-10.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 58142 of 58884, by Shponglefan
Ozzuneoj wrote on 2026-01-29, 17:43:
This sounds like one of those situations where the wanting is better than the having.
I've had a lot of similar situations over a lot of hardware, where once I actually acquire the thing it ends up being disappointing.
Reply 58143 of 58884, by Ozzuneoj
Shponglefan wrote on 2026-01-29, 17:59:
Of course, that's a big part of collecting.
Stamp and coin collectors dream of getting certain things even though they literally do nothing. At least these can be used for something if we choose. 😁
I found an SCC-1 last year and I have several Roland modules, so no, a RAP-10 isn't a practical addition to the retro hardware arsenal by any means.
I wouldn't have anything to be disappointed about because I have realistic expectations of what it is good at, what I would use it for and how much I would actually use it. This is also why I do not pay the ultra premium prices for these things.
Reply 58144 of 58884, by zapbuzz
tried and tried to install a Realtek RTL8139D PCI Network card on windows millennium here it is cost $2.00 so not a big loss I'll keep it for an XP system instead. Google AI said its good for WinMe but maybe that's an earlier revision.
Reply 58145 of 58884, by zapbuzz
ordered this for my retro pc 3COM 3C905C-TXM apparently windows 98 and newer have built in drivers so we shall see but if it doesn't work on millennium i go back to 98SE!
Reply 58146 of 58884, by zapbuzz
Reply 58147 of 58884, by Yoghoo
zapbuzz wrote on 2026-01-30, 09:30:
The RTL8139D network card should work in Windows ME. It works perfectly fine here with Windows 95, 98 and 98SE. Maybe try another PCI slot?
Reply 58148 of 58884, by zapbuzz
Yoghoo wrote on 2026-01-30, 09:37:
tried them all no good
Reply 58149 of 58884, by dormcat
zapbuzz wrote on 2026-01-30, 09:40:
The package look like having a CD-ROM driver disc inside; if so, try that driver first, followed by the universal driver by Realtek.
Reply 58150 of 58884, by zapbuzz
dormcat wrote on 2026-01-30, 11:17:
tried same error
Reply 58151 of 58884, by framebuffer
NeilKnows wrote on 2026-01-28, 22:09:
Looks like a cool (if monstrous) case...Is that dual ATX power supplies?
Ozzuneoj wrote on 2026-01-29, 00:46:
That thing is crazy. […]
I am a bit confused about the power supply situation though. It looks like two PSUs on the back, but one big one on the inside. And why do they have handles?
Ohhhh... is it like a hot-swap redundant power supply thing? Never seen anything like it personally.
EDIT: Yep! That's what it is. It can utilize both power supplies at the same time, but it will run on just one if there is a failure of some kind. And if that happens, the other can be hot-swapped out without shutting the system down apparently.
https://phred.org/~alex/pictures/servers/forsale/
Yes it has a (hot?) swappable dual PSU, pretty much like servers
I still have to test them, they are probably at least 25 years old at this point and as much as dual PSU is cool, if I had the option I'd picked the normal version with single one, so I can easily use a modern PSU and not worrying about it
Windows 98 and SAMBA | Quake CPU Benchmarks | GeForce2: GTS vs MX400
Reply 58152 of 58884, by pan069
Does any other PCI card work correctly, like a sound card or graphics card or something? I.e. if not, the system could a general PCI issues.
Reply 58153 of 58884, by AndrettiGTO
Just bought an AST-3G Plus II EGA card for one of my IBM systems. Wanted 256k memory vs. my current IBM adapters 64k. Was an EBang "AS-Is, Untested" item but decided to take a chance as it was reasonably priced.
On boot up it looks great but as soon as the screen scrolls it corrupts the previous and newly displayed text. Will try to sort it out 😒
It's all fun and games 'till someone loses an eyeball
Reply 58154 of 58884, by Shagittarius
If it was a c64 I'd say corrupted character memory, or failing. Dunno...
Reply 58155 of 58884, by Shagittarius
If it was a c64 I'd say corrupppted character rrormyyyy, or failing. Dunno...
Reply 58156 of 58884, by Ozzuneoj
AndrettiGTO wrote on 2026-01-31, 02:10:
First thing I would do is use a magnifier to inspect every solder joint on the back. Especially the legs of the memory chips. It has some scuffs and scratches on it, so it could have been tossed around at some point.
Reply 58157 of 58884, by pan069
Reseat the BIOS and run a memory tester on the video memory. MT (Empty?) memory is not known for its great chip quality.
Reply 58158 of 58884, by AndrettiGTO
Ozzuneoj wrote on 2026-01-31, 03:12:
Microsoft Diagnostics didn’t see any RAM issues and visually passed the graphics tests. Of course, buggy CheckIt flagged all sorts of memory. Didn’t feel it was ROM issue as the random characters were all valid extended ASCII.
With my magnifier glasses, started straightening a bunch of badly folded pins that extended to other traces. THEN I SAW A SMALL DEEP SCRATCH!
OMG, I was suddenly filled with real hope! Added four bodge wires and wow, it works great. Such a relief as I didn’t want to sink more money into this.
Everything in this lovable hobby is getting so expensive.
Reply 58159 of 58884, by OMORES
I just did a quick test on this Matrox G400 DualHead. It works, even in this… let's call it a ménage à trois setup.
What If a Modern GPU Had 1990s Bandwidth?
