DOS Questions
Reply 200 of 258, by DustyShinigami
Ah. Managed to figure it out. Not just for the SB16, but also CDBQ. 😁
SET CDBQ=C:\DOSPRO\CDBQ
SET CPUSPD=C:\DOSPRO\CPU\CPUSPD
SET ALIEN=D:\DOS\ACCLAIM\TRILOGY
REM Skip executing SB commands already loaded
IF %SBLOAD% == TRUE GOTO CDSPD
CALL C:\GOODIES\SCRIPTS\SBLOAD.BAT
:CDSPD
REM Skip executing CDBQ commands already loaded
IF %CDSPD% == TRUE GOTO FINAL
F:
DIR/W
D:
%CDBQ%\CDBQ /P2 /DM /S1200
SET CDSPD=TRUE
:FINAL
%CPUSPD%\CPUSPD c2d
%ALIEN%\NOVERT.COM
CALL %ALIEN%\TRILOGY.EXE
%ALIEN%\NOVERT.COM /U
%CPUSPD%\CPUSPD c2e
SET BLASTER=A220 I5 D1 H5 P330 T4
SET SB=C:\PROGRA~1\CREATIVE\SBLIVE\DOSDRV
%SB%\SBEGO.COM
%SB%\SBEMIXER /MA:255 /VO:255 /MI:255 /MT:255
SET SBLOAD=TRUE
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 201 of 258, by DustyShinigami
I appear to have run into another snag. This time with Little Big Adventure. Again. I suspected I may have some new issues to deal with this time round. I didn't realise the game had redbook audio as well as MIDI music. So, that means I need to use the SB16. And for that - EMS mode. The game apparently doesn't like it. What's weird though is that it will load the first time, but if I quit and try to load it again, it goes through all the audio loading, but then just stops. I have no choice but to reboot. I've yet to try loading the game in normal DOS mode without any drivers or EMS. At least, I think I've yet to try. I might well have done and it just refused to get passed the Adeline splash screen due to not being able to set up the audio.
I did try using UMBPCI instead, but the SB16 just won't initialise without EMS. The next thing to try will be replacing DOS4GW with DOS32A and see if that helps.
OS: Windows 98 SE
Reply 202 of 258, by NeoG_
This thread is making me realise how much better it is to have non-PnP sound cards.. No init apps or TSRs that depend on certain memory configurations
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 203 of 258, by DaveDDS
NeoG_ wrote on 2026-01-29, 07:32:
Yep... This is the reason I still have about 1/2 dozen SBpros and SB16s kicking around .
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 204 of 258, by DustyShinigami
I was debating on getting a Sound Blaster 16 or a Pro 2. Maybe I still should.
OS: Windows 98 SE
Reply 205 of 258, by DaveDDS
DustyShinigami wrote on 2026-01-29, 09:33:
I've had good luck with both - "most everything" old works with them, and I've written a fair bit of code to interface to and control them directly as well.
... definitely my "favorite" sound cards! (butI I've never really looked-at/gotten-to-know much else)
Reply 206 of 258, by DustyShinigami
DaveDDS wrote on 2026-01-29, 09:49:
I think I will get one at some point. If anything, it'll be good to have as a backup for if/when the Yamaha does pack up.
Regarding the matter at hand though, I've just realised... Because of all of these different configurations, depending on the situation/game, it does cause a lot of confusion. But actually, I should just take the CD audio cable out of my SB and put it into the Yamaha. >_< It's only the S/PDIF cable that needs to be in the SB to daisy-chain the two cards and use redbook audio when I'm in Windows.
That should solve the problem regarding loading a game, like LBA, without EMS mode, but whether the game allows me to reload it after quitting, I'll have to see.
OS: Windows 98 SE
Reply 207 of 258, by NeoG_
If the CD drive has analog and digital output, you can run the analog cable to the yamaha and the digital cable to the SB Live. They will typically output from both at the same time.
Reply 208 of 258, by DustyShinigami
NeoG_ wrote on 2026-01-29, 11:40:
I don't believe it has digital, just analog and S/PDIF.
OS: Windows 98 SE
Reply 210 of 258, by DustyShinigami
wierd_w wrote on 2026-01-29, 12:05:
S/pdif is digital.
https://en.wikipedia.org/wiki/S/PDIF
'Sony/Phillips Digital Interface'
The attachment Homer-Simpson-Doh.jpg is no longer available
Of course. I mean, the clue is in the name of it. ^^; For some reason I didn't think it was. Probably due to the confusion of still using VxD drivers instead of WDM. I thought it was the latter that could only do digital.
OS: Windows 98 SE
Reply 211 of 258, by DustyShinigami
Is there something I'm missing here...? I've connected the CD audio cable to my Yamaha, but for some reason, the CD music is too quiet. Even if the volume slider is at max on the CD drive, and even if I've cranked the volume to full in a chosen mixer. Both with Unisound and SetYMF, the CD audio is cranked to full, but it still sounds too quiet. This is in Quake and LBA. Of course, if I crank the master volume up, eardrums explode due to the SFX being affected, too. With Unisound, I've tried putting Master and CD to 99 and wavetable/SFX volume as low as 10. At which point I get no SFX at all. If I crank it up even a little, to say, 15 - mega loud!
With SetYMF, it looks as though it's using the SB's Mixer, which is quiet when I played a track from the CD. Muting it there has muted it in the game, too. But it doesn't appear to use the upper volume controls, which sound right. Is this expected if not using digital...? That it will revert to using the SB's mixer and therefore be much quieter? This is definitely not an issue I've run into in the past.
OS: Windows 98 SE
Reply 212 of 258, by wierd_w
Are there any jumpers for the preamp on the card?
Reply 213 of 258, by DustyShinigami
wierd_w wrote on 2026-01-29, 20:56:
Ooh. I'm not sure. I'll check... The only jumpers I can see are here, but I'm not sure what they do.
The attachment IMG_5314[1].JPG is no longer available
OS: Windows 98 SE
Reply 214 of 258, by wierd_w
At least for genuine soundblaster cards, there are jumpers to set the preamp volume.
I'll look for your yamaha.
To save me from reading 11 pages, can you tell me *which* yamaha this is?
For SoundBlaster cards, Phil has this up.
https://www.philscomputerlab.com/uploads/3/7/ … audio_cards.pdf
In which the amplifier jumpers are listed.
The preamp is an option for old unamplified speakers, and makes the card output speaker level signals, instead of line-level signals.
Reply 215 of 258, by DustyShinigami
wierd_w wrote on 2026-01-29, 21:21:
At least for genuine soundblaster cards, there are jumpers to set the preamp volume. […]
I see. It’s the Yamaha YMF719E-S
OS: Windows 98 SE
Reply 216 of 258, by wierd_w
DustyShinigami wrote on 2026-01-29, 21:37:
The images are dead, but YES, those are the preamp.
YMF719E-S jumper settings
(And or)
Yamaha YMF-719 issues
Like them, I'd disable the preamp, so the internally generated sounds are at the same level as the redbook audio.
Reply 217 of 258, by DustyShinigami
wierd_w wrote on 2026-01-29, 21:39:
The images are dead, but YES, those are the preamp. […]
Awesome. Thank you. 😀 Is that for both jumpers?
OS: Windows 98 SE
Reply 218 of 258, by wierd_w
According to Tiido (who knows their stuff), putting JP1 and JP2 in the 2-3 position disables the onboard amp.
Reply 219 of 258, by DustyShinigami
Great. Thanks. I'll report back on the results. 😀
OS: Windows 98 SE
