First post, by DaveDDS
- Oldbie
Not sure where is best place to post - it kinda involves hardware/construction, and vintage stuff...
I've been fooling around with an "easy" way to "do things" in my house while I am away - often travelling in another country.
---Originally, I had a dedicated "server" which ran 24hours, with a homebuilt UPS that would gracefully shut it down if power faild for more than 5 mins, waited till power was stable for 30 mins before starting it back up.
I used ANYDESK to connect to it remotely and from there I could view my local cameras, and with some software I created to operate an X10 "CM11" interface to turn power on/off to various things (like basement lights for camera, and pump dehumidifier tanks during summer)
But... the lawn tractor battery in my UPS gave up the ghost (after >10 years) and I would need to get a new system (and figure out how to interface/control it) as ANYDESK isn't supporting Win7 now.
---In the last year I've been using some "internet" cameras which have a local "base" - with these I can "look around"... But how to "do stuff".
Turns out the cameras have "night vision" which I can turn on/off remotely. Not really good enough - but it's via IR LED which can be detected with simple IR sensors - so I can point the camera at a particular sensor and toggle "night vision" ON/OFF to generate a pulse.
I could use this pulse to power-on a system (with a timer to power-off, and it could re-trigger the timer as I'm using it) - It could then monitor several sensors, count/time pulses, and provide visal feedback to confirm/perform various events.
What system to use: It has to be able to accept power-ON/OFF to quickly startup, and not trash itself when powered off.
--The one I'd most like to use is a small DOS system I have which boots from a CF card, and has VGA output so I could easily provide vidual feedback... I currently use this via a remote switch to power ON/OFF, and have DOS setup to not cache - I use this as a remote DDLINK server in my basement, and have not any problems relating to power on/off.
But.. It started life as a AASTRA phone system and has almosts no IO. It has PS2 keyboard,mouse jacks, VGA, Network, USBs and AC97 audio. There are NO expansion slots - without a serial port I can't directly control the X10 CM11.
Q? What's available for DOS-USB and how can I ID the USB chip within?
--Another option: A P4 mainpard that I have. I think I can use a GoTek to make it boot from USB flash - It does have on-board serial and parallel port, so I could interface to sensors and CM11 - This is probably the easiest..
--Another I'm considering: I have parts to put together a dedicated 6809 based SBC - with 48k battery backed up RAM (lots for code), and 8-serial ports... No obvious display, but I would put on some parallel I/O, both to monitor sensors and drive a few LEDs. Workable but a fair but more up-front effort.
Anyone else interested in this kind of thing?
Any other/easier ways to implement general "remote control" over the net?
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
