Worth saving this mobo?
First post, by Cythyel
Got my hands on a PC Chips 915i VIP mobo, but it has 2 major flaws...
The attachment 1000000708.jpg is no longer available
1st is the missing bios chip, tho thats rather easy to get
2nd... fake cache, tag chip and missing jumper pins
The attachment 1000000709.jpg is no longer available
The attachment 1000000710.jpg is no longer available
The traces are there, so it should be possible for real cache chips to work in it.
Big question is... worth getting a bios chip and real cache with tag for it? or just bios and put a 133mhz cpu into it to mitigate the fake cache caused performance drop?
Reply 1 of 13, by Horun
Cythyel wrote on 2026-01-31, 17:41:
Got my hands on a PC Chips 915i VIP mobo, but it has 2 major flaws... 1st is the missing bios chip, tho thats rather easy to get […]
Just get a BIOS. The amount of work to replace the cache AND verify the BIOS you use does actually support a real cache... is a lot of work that may not gain much performance.
Some of the pc chips BIOS for the fake cache boards have the cache reported hard-coded but do not actually support a real cache,
Reply 2 of 13, by Locutus
It’s definitely worth saving this board — Socket 3 boards are getting harder and harder to find.
As for the fake cache, I’d personally leave it as a curiosity (I don’t own any boards with just dummy cache housings).
If you’re thinking about desoldering it, the real question is whether you have the right tools and experience — this isn’t the best board to practice on.
Reply 3 of 13, by Cythyel
Horun wrote on 2026-01-31, 19:36:
I was thinking the same 1st. Getting a BIOS chip, put the program onto it from TheRetroWeb, then try my luck. Tho sourcing the chip itself doesnt look easy either, shipping to my country costs more than the chip itself...
Locutus wrote on 2026-01-31, 19:41:
This is the 4th board i have on hand now 😁
As for soldering, its not an issue, got desoldering gun and a gordak soldering station. Altho due to age, i wont do any smd soldering anymore, but such small pins arent an issue 😀
Reply 4 of 13, by Unknown_K
The good news is that board was sold under a different brand with real cache chips and jumpers:
https://theretroweb.com/motherboards/s/pcchips-m915i
AMI 486dx ISA bios AC4246866 is the bios if you can find it.
Unless you know how to solder and have a desoldering gun with pump I would not bother adding cache chips because you might screw up the traces and render the board unusable. The board would probably be worth more down the road as an example of fake cache anyway.
Reply 5 of 13, by Ozzuneoj
Any Socket 3 board that comes with a coin cell rather than a corroded Varta or a dead (possibly soldered) Dallas is worth keeping.
Reply 6 of 13, by Cythyel
Unknown_K wrote on 2026-01-31, 20:57:
The good news is that board was sold under a different brand with real cache chips and jumpers: […]
thats the one i bookmarked too, if you check the 3rd pic there, its almost 1:1 the one i have
and i do have a desoldering gun and a gordak soldering station, so replacing the fake with real chips wouldnt be a problem, sourcing the cache chips and the tag chip would be an issue ^^"
Ozzuneoj wrote on 2026-01-31, 21:37:
guess im gonna try and get a 32pin bios chip for it and see how it goes
in the worst case, i make it run with a 5x86 133mhz cpu to mitigate the fake cache to some extent
tho it having IDE connectors and VLB as well is a nice pairing, no need to use controller card
Reply 7 of 13, by Shponglefan
If you're confident in desoldering, then replacing the fake cache with sockets for real cache is worth it. You might need to add some jumpers depending on how the board is wired up for cache.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 8 of 13, by Cythyel
Shponglefan wrote on 2026-01-31, 22:36:
i will consider that after getting a bios chip for it and actually booting up the mobo
tried looking up a 32pin chip, but i either find a 586/686 or older 28pin ones 😒
once the mobo boots up, i will look into sourcing real cache chips
Reply 9 of 13, by Cythyel
hmm... im gonna need a AM27C010-155DC 12.75V bios chip for this mobo
i came across 150DC 5V ones too, same AMD manufactured ones, and also STMicro 155DC ones
should i stick to the original AMD AM27C010-155DC 12.75V one? or the 150DC would be fine too? 5ns difference shouldnt matter much
Reply 10 of 13, by Locutus
It will be fine with faster 150ns one.
Reply 11 of 13, by Cythyel
finally had time to test this mobo after getting a bios for it... and its alive!!!
The attachment IMG_20260318_113737.jpg is no longer available
The attachment IMG_20260318_113742.jpg is no longer available
only tested it with a DX 40mhz, but should work with 5x86 133mhz too
Reply 12 of 13, by jakethompson1
If you get the Am5x86-133 working with internal cache in write-back mode, that plus the cache being 16KB will certainly help.
You might also experiment with running it at 3 x 50 MHz, in which case the external cache would have to be slowed down anyway.
Reply 13 of 13, by Cythyel
jakethompson1 wrote on 2026-03-18, 23:45:
im not fond of oc-ing such old hardware, sadly missjumpered an 5ali61 mobo and killed a k6-2 450 once
so i will just try to run the chip at 133mhz and see what happens
