First post, by DustyShinigami
I'm struggling to work out how I can back up some of my game CDs that have copy protection. I'm using Alcohol 120% and some of the options don't work, sadly. Or I'm not sure what the right presets should be. One good example is the first disc of The Settlers 3. I got hold of ProtectionID and that says it has PE Crypt 1.0...? After the lengthy scan, I'm guessing that's what it is. If I try the Securom or StarForce, it'll get to around 60% whereby it reports reading errors. I also tried copying and pasting the files from the disc to my HDD to make an image from that, but it didn't work. It got to about 95% before it struggled to go any further.
Also, those different presets, like Securom, can only be made using MD5/F or cdd...? But if a game has redbook audio, don't they definitely need to be CUE/BIN files? And if so, how can this be achieved?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 37, by TheMLGladiator
Read errors are normal for many types of CD copy protection. Just compare the number of read errors to the number on redump.org and you should be good. Securom disks will need MDS/MDF. It contains everything a CUE/BIN set has in addition to some extra stuff.
Reply 2 of 37, by DustyShinigami
TheMLGladiator wrote on 2026-02-01, 15:35:
Hmm. I tried just the regular Securom and the files as MDF, but again, it got to 60%, came up with a disc read error, and cancelled the operation itself.
🙁 Looking on redump.org, it doesn't appear to list any errors at all.
http://redump.org/disc/78471/
OS: Windows 98 SE
Reply 3 of 37, by wierd_w
This image is lifted from the alcohol 120% electronic user's manual. I hope fair use qualifies.
The attachment Screenshot_20260201-101238_Firefox.png is no longer available
Note that on the image creation dialog window, 'skip read errors' exists.
It exists for this reason.
You can find said manual here.
https://support.alcohol-soft.com/documentatio … user-manual.pdf
In the event that these are *actual data defects*, and not copy ptotection factory-made bad blocks, I would advise the slowest read speed possible, AND, holding the disc up to a light to check for pinpricks in the top surface of the disc.
Reply 4 of 37, by DustyShinigami
wierd_w wrote on 2026-02-01, 16:16:
This image is lifted from the alcohol 120% electronic user's manual. I hope fair use qualifies. […]
Yeah, that's usually ticked anyway for me. Especially after choosing one of the presets. It makes no difference though. It gets stuck at 60.5% every time with read error after read error. I checked the disc and it's immaculate, too.
The attachment IMG_5317[1].JPG is no longer available
OS: Windows 98 SE
Reply 5 of 37, by leileilol
Personally I don't trust alcohol to not fuck with the redbook so it's been CloneCD/DVD for me with my game discs (bin/cue/ccd/sub). Very protected games tend to be more post-redbook though
Debian's fucked
Reply 6 of 37, by DustyShinigami
I've given up at this point. Nothing I've tried works. And I can't even do it on my main PC with ImgBurn and copying/pasting the files directly off the disc. 🙁
OS: Windows 98 SE
Reply 7 of 37, by TheMLGladiator
leileilol wrote on 2026-02-01, 16:37:
Alcohol doesn't handle multi-bin sets correctly either. I'll have to give CloneCD a shot sometime.
Reply 8 of 37, by DustyShinigami
I'll give CloneCD/DVD a try next. 😀
OS: Windows 98 SE
Reply 9 of 37, by NeoG_
If you are using Alcohol 120% Retro Edition on windows 98, it is missing a few features so I wouldn't count on it as a ripping and virtual drive option for copy protected discs. Most importantly it doesn't allow you to rip to or mount disc formats with subchannel data (e.g. mds/mdf and ccd/cue/sub). Those disc formats are typically required to enable copy protection emulation.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 10 of 37, by DustyShinigami
NeoG_ wrote on 2026-02-01, 21:48:
Ahhhh. I see. Yeah, I'm using Retro Edition for 98. I didn't realise it was missing features. Thanks for the heads-up. 😀 Apart from trying CloneCD, which I'll do next, is there a version of Alcohol that's recommended?
OS: Windows 98 SE
Reply 11 of 37, by NeoG_
DustyShinigami wrote on 2026-02-01, 22:12:
Since I'm on a K6/2+ I don't have a lot of power to spare, I opted to use unprotected disc images and patched executables to reduce the CD emulation overhead. I make the images on a modern computer in bin/cue format.
So unfortunately I don't have a good solution for you off the top of my head
Reply 12 of 37, by DustyShinigami
Okay, thanks anyway. I'm about to try CloneCD. I don't know/think there's a version for Windows 98, although I'm happy to be proven wrong. So if it works, I'll use it on my main rig for dealing with any awkward discs.
EDIT: Hmm. It's got to that same point again, at 60%, and is struggling to go any further. 🙁 Though it is trying to write some dummy sectors, so we'll see.
OS: Windows 98 SE
Reply 13 of 37, by Shagittarius
I've used everything from CloneCD to Alcohol 120% to Blindwrite...Blindwrite being the most technical...I find that sometimes I have to make multiple attempts to figure out which one will work properly to make an image. I had the most success with using old versions of Alcohol and the current version of CloneCD, though sometimes they still need to be used in conjunction with the copy protection emulation in the Daemon Tools if mounting the iso.
You could try using CLONYXXL to help you determine the type of copy protection before attempting to use an appropriate ripper. There might be other programs similar to that out there that could help too.
There's no magic bullet that I've found and you have to do some work to get into a rhythm, so be prepared to dedicate some time to this venture. Go down the rabbit hole but stop before you buy rare and expensive CD-ROM variants that can supposedly read copy writed discs much better than the rest...unless you've got the money...
Reply 14 of 37, by Ozzuneoj
Shagittarius wrote on 2026-02-02, 00:05:
... you've piqued my interest. I have a lot of optical drives and it would be nice to know if some were "special". Where would someone find a list of such drives? A quick google search did not turn anything up.
By chance I ended up with a drive about 10 years ago that was one of the unicorns that could read Wii discs. Pretty sure it came out of some random Dell tower I was given. That was an interesting find, and it actually did read the couple of Wii discs I tested. Pretty neat, heh.
Reply 15 of 37, by DustyShinigami
Thanks for the suggestions. I'll look into those if all else fails. So far, at least, it's put together an image of the disc. I just need to test it out. 😀
OS: Windows 98 SE
Reply 16 of 37, by Shagittarius
Ozzuneoj wrote on 2026-02-02, 00:11:
Here's a great read about a particular scheme, it also recommends the best drive is the Plextor PlexWriter Premium (1) (not Premium 2).
https://gbatemp.net/threads/creating-ba ... emium%202).
The attachment Plexwriter_Premium.jpg is no longer available
Reply 17 of 37, by DustyShinigami
Update on the situation. CDClone managed to complete the image and that allowed me to mount it with a virtual CD drive on my main system, and then from there, I was able to put a new image together of my choosing with ImgBurn. 😀 So thanks for the suggestions, everyone! Of course, I still need to test the image out a bit later, but hopefully it should be fine.
OS: Windows 98 SE
Reply 18 of 37, by Shagittarius
Unfortunately just completing the burn isn't a real test. Try to launch a protected game with it to make sure. There will be a lot of games that will work fine after using those tools, but not all.
Reply 19 of 37, by wierd_w
Actual use is the only lithmus test that's valId. Yup.
