First post, by DustyShinigami
- l33t
A sequel to this thread about the floppy boot sounds - A question about floppy drive boot-up sounds - but this time I'm trying to find out what, or how, you get that retro tell-tale beep sound, usually after the floppy boot seek? I'm guessing it's the power-on self test...? Or POST? Or is that beep something totally different? The only option I can see in my BIOS is for the memory test at the very beginning and that's labelled Quick Power On Self Test. My test build does that beep, but it doesn't happen with my main setup/motherboard.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
