C&C Red Alert for Free
First post, by DosFreak
http://www.ea.com/redalert/news-detail.jsp?id=62
Today, August 31st, 2008 marks the 13th anniversary of the storied Command & Conquer franchise, which has sold over 25 million copies to date. And to celebrate this milestone and this October's highly anticipated return to the world of Red Alert with Red Alert 3, we are giving away one of the original games that started it all, Command & Conquer Red Alert, for FREE.
And because we are also offering Red Alert 2 for free for those who pre-order Red Alert 3 before October 27th, C&C fans...YOU can walk away with Red Alert, Red Alert 2 and Red Alert 3 - all for the price of Red Alert 3 ($49.99 standard edition, $64.99 Premier Edition).
It appears to be the original version so the usual tricks will have to be done to get it to work on 2000/XP/Vista.
Make your games work offline
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
I have been playing around with C&C: RA today. With a few tweaks, it installs and appears to run pretty well in DOSBox. I am attaching the config-file I use. As usual, you will have to adjust the mount points used.
Edit: 2008-09-01 - New version of the configuration file.
_________________
Reply 2 of 7, by olemogamer
I downloaded and un-zipped the iso's from EA's website. Each iso came with a patch for XP in it's folder. Has anyone tried these patches yet on XP? I really won't have time to install this game until the weekend to find out myself.
Reply 3 of 7, by MiniMax
Rank Moderator
Moderator
olemogamer - if you look at the config file I provide, you will see that it automatically applies the 108PE patch. But I have only tested it in DOSBox, I have not tried running the game directly in Windows XP.
_________________
Reply 5 of 7, by leileilol
Nope, it's the 1999 EA Classics re-release.
Oddly the re-release version has no IPX support and has troubles with XP out of the box whereas the original 1996 Virgin release has no issues in XP. I'm speaking from the Win32 executables of course.
The re-release's dos version can't seem to run under DOSBox, at least for me 🙁 I know the 1996 Virgin release did.
Reply 7 of 7, by MiniMax
Rank Moderator
Moderator
leileilol - see if the config I provided above will help you. It worked for me.
_________________
