Reply 20 of 22, by NeoG_
ruthan wrote on 2025-12-18, 16:47:
I also found video about serial port keyboard, there is even PS/2 adapter for it: https://www.youtube.com/watch?v=Pto9zsK_rIw H […]
Here is product page, this company even produce Fallout like Wrist keyboard:
https://www.l3sys.com/
This is not a serial port keyboard adapter that you are thinking of - It converts RS232 terminal commands into a virtual AT keyboard commands for a host computer. It requires the host computer have a standard AT keyboard port and the source side is another computer running a terminal program.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 21 of 22, by ruthan
NeoG_ wrote on 2026-02-05, 01:45:
These are server keyboards, but i read about people claiming using just serial ports keyboards..
Check this post, check if you still think that it will not work, i read some people claims that they were using it.. I dont remember exact details, but some where from 1980s and it just needed special dost driver to make it happen and nothing about any server was mentioned, it would be in that age for sure..
Re: Addon PCI /PCI-E PS/2 Mouse +Keyboard cards - experience - its genuine PS/2 replacement or new HW SW emulation / f
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 22 of 22, by rasz_pl
Windows is no problem, you can even have a driver pretend your joypad is a keyboard. From Win98 up you can install USB card and use usb keyboard. Afaik Win95 osr2 "supports" USB but with no drivers, not even for keyboard.
Its raw DOS/BIOS that is impossible. BIOS would need modding per motherboard, DOS a not so compatible hack like SBEMU.
Serial keyboards were never a thing in PCs, if you manage to find one it will be for industrial automation or some custom product.
>I dont like impossible response
How about running a car on water, surely there must be a way! 😀
