Dual millennium build
First post, by vvbee
OS1: Windows Me
OS2: Windows 2000
MB: Gigabyte GA-MA78GM-S2H
CPU: AMD Athlon II 160u
GPU1: 3dfx Voodoo Rush (OS1)
GPU2: Matrox P690 (OS2)
RAM: 512 MB DDR2
Sound: USB dongle + SBEMUL
The two rejects Windows Me and Voodoo Rush are working together, while on the professional side there's Windows 2000 and Matrox P690. The P690 is one of the few DX8 GPUs for PCIe, making this a DX3/DX8 build.
The motherboard has no direct support for either OS but DMA works in both (SATA SSD via an IDE adapter) and drivers for the integrated ethernet are available.
USB sound ideally guarantees minimum driver stability issues in Me. Microsoft's SBEMUL driver brings some sound to DOS games - works in Redguard, not in Screamer 2.
All components are passively cooled. One silent case fan circulates air.
There are various alternative sets of GPUs you could use. For example Radeon X series + Chinese Rage XL. The X series has better compatibility than the P690, but I already have a build with high compatibility and full MSAA for all of these games, so no real need. The P690 is more interesting in this sense, also from memory it has higher quality 16-bit dithering, though no fog. Could also do an AGP/PCI equivalent build with a suitable (more expensive) AM2 motherboard, the P650 in that case would perform about the same but have more driver options including Matrox's fragment AA.
Reply 1 of 2, by vvbee
vvbee wrote on 2026-02-06, 02:00:
3DMark 99's bilinear image quality test in 16 bits, P690/G550/FX 1500/X1300:
The attachment 99-p690-g550-fx1500-x1300.png is no longer available
Thief 2's wall in 16 bits, P690/G550/FX 1500/X1300:
The attachment thief2-p690-g550-fx1500-x1300.png is no longer available
The P690 and G550 have more or less identical dithering and are the highest quality. The Quadro FX 1500 is close but not quite. The Radeon X1300 is the noisiest and easily looks noisy to the eye. The X300 is the same. You could argue the P690 has somewhat more microbanding up close than the FX 1500, but in practice it doesn't come across that way.
On the other hand the FX 1500 has the best brightness compensation.
Reply 2 of 2, by vvbee
An issue the P690 has is that in some games certain objects act as if they ignore the depth buffer and get drawn over everything else. One of these is Gothic 2, where forcing Z rather than W buffering via the INI has no effect either.
It looked to have something to do with depth biasing so I had AI write a DX wrapper that disables it, which worked. Doesn't result in depth fighting so presumably no biasing is needed for this card in this game.
The attachment p690-gothic-2-bias-fix.jpg is no longer available
A downside with wrappers is you need to match versions with DX.
