Dream Slot-2 Xeon Build
First post, by SWZSSR
1. The Beginning - Finding a Motherboard & CPUs
Hey all
I recently got the urge to build a Slot 2 Xeon build.
Had a look on ebay without luck and decided to make a post over at the Aus Vintage facebook group. My friend in interstate reached out and said he knew where one was..
He later contacted me and confirmed its still there inside a Nortel Networks Contivity Extranet Switch 4500. After some time he got a hold of it & dismantled the motherboard, cpus, ram, cards from it and sent some photos.
Lucky score! Intel MS440GX MarlinSpike with matched Pentium 2 450mhz/512k Xeons.
The attachment Messenger_creation_B3530752-1A4E-4A31-A0D8-1730124415DC.jpeg is no longer available
The attachment Messenger_creation_DB4BAC48-1D84-4991-BE49-3AF28C877BDC.jpeg is no longer available
The attachment Messenger_creation_5680E979-F39E-4742-BB62-8AF55CF6BE5E.jpeg is no longer available
The parts are currently on the way to me. Next post will be a bang/smoke test & build plans.
Keep you updated
LS486/5x86@180/Banshee/SoundscapeElite/DOS6.22
5TH/Dual233MMX/MGA2164W/Voodoo2/AWE64Gold/NT4.0&W9X
P5A(1.6)/K6-3+550/Ti500/EWS64XL/W9X
CUV266D/Dual1.4TUAL/HD4670AGP/XONAR/XP
780iFTW/QX9650/3x8800U/VISTAx64
Z87/4790K/TITANX/AuzBravura/XPx86
Reply 1 of 4, by Intel486dx33
If you had a dual CPU computer workstations back in 1990s and Running WinNT you where elite
Very reliable computers.
Reply 2 of 4, by SWZSSR
UPDATE - Motherboard Arrival & Smoke Test
The motherboard has arrived, packed very well.
The attachment box.jpg is no longer available
List of what I received.
1x Intel MS440GX (MarlinSpike)
2x Pentium 2 Xeon 450/512/100
4x 256MB PC-100 CL2 ECC Modules
Board
The attachment Board.jpeg is no longer available
CPUs with Cooling System\Mounting
The attachment CPUS.jpeg is no longer available
Onto testing it. Used my trusty Enermax PSU with 35amp 5V Rail & 6pin Aux
Posted first shot!
The attachment Test1.jpeg is no longer available
Will deal with the bios password next
The attachment Test2.jpeg is no longer available
All good so far. I will clear the bios password and look at flashing the latest P20 Bios
Stay Tuned
Reply 3 of 4, by SWZSSR
Next Step: The Case
The MS440GX is a large form factor, EATX with a special 4 hole CPU mounting bracket that needs to screw into the motherboard tray. I could just use nuts and washers on the rear of the board but I don't want the board to warp in that area.. I'm a perfectionist and this has to be done properly.
The attachment mounting.jpg is no longer available
After doing a LOT of research only a few cases actually had support for this.
Inwin Q500 \ Q500N
Industrial 4U Rack Cases
Addtronics 7896A
I have recently spotted a complete Inwin Q500N on Ebay. I'm going to make an offer and see if I can secure it.
Reply 4 of 4, by Gold Leader-B747
Hey nice build there SWZSSR, good to see you here as well, you could give that system a pair of Intel Pentium !!! Xeon 900Mhz 2MB's, that is if it's Bios & VRM's would allow that, keep this place posted on it's progress, looks tempting!
The Addtronics 7896A Server Tower as well as the 6896A Entry Level Server Tower both support that feature btw, I can confirm that as I have these two cases myself including the original Manual.
K7 T-Bird 700 Slot A | K7 Pro | 768MB SDR| V3 3500 TV
P3/E 850 Slot 1 | EP-BX3 | 512MB SDR | G400 MAX | V2-12MB SLI
Dual P3/EB 1000 S370 | ABiT VP6 | 2GB SDR | Radeon 8500 AGP 64MB
AXP 2200+ S462 | EP-8K7A+ | 2GB DDR | P512 AGP 256MB | V5 PCI Mac
