NHL Championship 2000
First post, by iLoveThe80s
Hello all
I wasn't sure where to turn to and figured I try my luck here with all of you knowledgeable people
I'm having this odd issue where I cannot install NHL Championship 2000 on my Windows 7 (home edition, 64bit)
The odd thing is that just last year I was able to install and play no issues whatsoever
The reason I uninstalled it from my main computer is because I wanted to see if it would run on my Windows 98 SE gaming rig
Well, it does but horribly. Even though it has a ATI Mobility Radeon 7000 GPU
I figured I reinstall it again on my main computer and hence my problem. It randomly decided to not work
I have attached an image of the error I'm getting
I do have the original CD and tried installing it like that and I also extracted all of it's content from the CD on to a folder I created on my desktop and tried installing it like that as well
Alas, neither worked. I don't think I deleted/uninstalled anything by accident either
Specs:
ASUS Z170-AR
i5 6600 (non K)
16GB RAM
1TB SSD
MSI GTX 1660 Super Ventus XS OC (6GB)
Thank you everyone in advance
Reply 1 of 3, by BEEN_Nath_58
Looks like a 16bit InstallShield. Consider trying OTVDM
Reply 2 of 3, by iLoveThe80s
Thank you so much!!
It worked!
It threw a random Microsoft Visual C++ error when running the game for the first time but after the second and beyond it disappeared
Thank you again =)
Reply 3 of 3, by h4root
NIce Aper , you got an old AGP rig I can test this Voodoo 5 5500 agp I picked up? I only have a working AGP 8x 3.0 rig it won't fit on voltage differences
