First post, by RafaelBR
Hi everyone.
I'm trying to bring back a 386 motherboard and I need some tips on what else I can check... Please.
https://theretroweb.com/motherboards/s/ecs-wh386sx
What I've already done:
- I can read the BIOS correctly using a programmer.
- I removed a capacitor at the power input that was "suspicious".
- I resoldered some of the north and south bridge connections.
- I tried turning it on without the cache ICs.
- I tried turning it on without the keyboard IC.
- I tried with other memory modules.
- I tried with a video card.
In the first test when I got this board, I noticed the IRDY LED blinking weakly, then steadying, and the board starting normally. I connected the keyboard and quickly shorted the reset jumper, and it wouldn't start anymore.
There is no signal from the speaker.
Thank you for your time and knowledge.
