First post, by RayeR
Hi, anybody here who own this MB?
Abit AB-FU3 386 ISA - http://theretroweb.com/motherboards/s/abit-ab-fu3
I need JEDEC dump of prog. logic U6 PAL16L8.
I found that mine has completly damaged (floating) output pins 12-19 and I cannod dump it in programmer.
Due to this the MB fails with FPU when any program tries to use it. Probably because BUSY# signal is not routed from FPU to CPU. I wonder the MB boots without the chip. Maybe some similar MB could be also used, should be based on Chips F82C351/355/356 chipset...
At least I tried to reverse-engineer the PAL16L8 pin mapping:
1 - FPU K1 - PEREQ
2 - FPU K2 - BUSY#
3 - FPU L2 - ERROR#
4 - CPU E14 - ADS#
5 - F82C356 77 - NMI
6 - FPU L10 - RESETIN
7 - CPU C9 - RESET
8 - F82C351 149 - REFRESH#
9 - WTL3167 M12 - INTR
10 - GND
11 - WTL3167 M2 - PRES#
12 - CPU - BUSY#
13 - probably NC
14 - probably NC
15 - probably NC
16 - CPU A8 - ERROR#
17 - probably NC
18 - F82C356 138 - IRQ13
19 - CPU C8 - PEREQ
20 - VCC
pins 12-19 are dead, chip doesn't excessive heat or any signs of damage. It looks to me like broken bonding wires from silicon inside?
Reply 1 of 2, by Anonymous Coward
I have this board, but I’m travelling and can’t dump the PAL. You can try feipoa, he has one too.
Reply 2 of 2, by RayeR
Feipoa kindly tried to make the PAL dump for me but his programmer didn't support exact PAL type and JEDEC file content shown not valid. Please anybody else with this MB could help?
