First post, by jjspartan0
The attachment 20260212_074517.jpg is no longer available
The card is a combo modem sound card in particular Aztech Labs I38-MMSN841 Sound Card Modem 16 bit. I switched it from EEPROM to software and any detection and installation of drivers through windows either don't function or it crashes immediately with a general protection fault. I only have one PC with 16-bit ISA to test it in. I recapped the board and now it doesn't crash when installing drivers most of the time.
I've bought a new voltage regulator and will install it to rule out a hardware fault.
Before anyone asks I did make sure all the resources it was trying to use were free. I also use contact cleaner on the slot and edge connector.
All the drivers on this site seem to be for other models if anyone can help I would appreciate it.
Reply 1 of 12, by PD2JK
What happens in pure DOS and run Unisound?
Any FM (OPL) music in any particular game?
Digital sound?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 12, by jjspartan0
You know I haven't even thought of checking to see how that works. I'm at work right now but when I get home I'll check it. I don't know how it'll react because I know I didn't install DOS drivers myself.
I won't be home until midnight so I probably won't be able to report back until sometime tomorrow. It's currently 5pm where I am now.
Reply 3 of 12, by wierd_w
If push comes to shove:
Use Unisound to initialize and configure the hardware before windows starts.
Force windows to install the generic soundblaster 16 audio driver.
Force windows to install the 'Standard [speed] modem on [COM port]' driver.
Aztech DID provide windows drivers, but that's not explicitly necessary. At the end of the day, it's a clone of a soundblaster 16, with an integrated modem.
The integrated modem uses a Rockwell chipset, which means this is a real UART based modem. As long as it gets an IRQ and an IO address (and windows sees it as a com port), the 'generic modem' dtiver will work fine
Reply 4 of 12, by jjspartan0
Where can I find unisound. I'm not very experienced with older computers. I mean I've gotten several working but this is the first time I've ran into a problem I couldn't solve on my own.
I tend to do everything inside of Windows because I'm not experienced in doing things in pure DOS.
Reply 6 of 12, by jjspartan0
Thanks. I do remember when I set it up in windows it did install generic soundblaster clone drivers. Once it was done it had resource conflicts.
I fixed that and it had me restart then it said the hardware was not detected or the drivers weren't working. I update the drivers and it said the better driver was the sound galaxy Washington driver. I let it install it and got a blue screen of death.
Upon reboot it hanged on normal startup. Removing the drivers in safe mode let me back but of course the card still didn't work.
Reply 7 of 12, by jjspartan0
*back in
Reply 8 of 12, by wierd_w
Just back on topic-- This appears to be your card.
https://www.dosdays.co.uk/topics/Manufacturer … diotel_2000.php
It was commonly found inside Packard Bell computers. For the audio side, the Washington 16 drivers will probably work.
https://www.dosdays.co.uk/topics/Manufacturer … hp#Washington16
For the modem side-- again, as long as windows sees a COM port, just slap "Standard Modem" on the com port windows detects.
Reply 9 of 12, by jjspartan0
Yeah the Washington drivers will attempt to install but cause a blue screen. Any suggestions? I'm putting this in a Compaq Presario 5185. I don't know if that helps. The Bios is ridiculously cut back too.
Reply 10 of 12, by wierd_w
From what I am reading, this particular aztech card emulates an SB Pro 2.0, not an SB16.
I'd try the win95 soundblaster pro drivers, with overriden/manual resource assignments.
Reply 11 of 12, by jjspartan0
It's worth a try.
Reply 12 of 12, by PC Hoarder Patrol
There's a PB page on the WinDrivers archive that points to this file, if you want to try...
The attachment 2316fd951.zip is no longer available
