First post, by gag2000
Hi everyone,
I have an old game called Asphalt Duell
https://www.pcgamingwiki.com/wiki/Asphalt_Duell
I would really like to play it together with my son. Unfortunately, this game does not have a proper installation process – it runs directly from the CD-ROM. In my case, I am using an ISO image of the original CD.
I wanted to improve the game using dgVoodoo2, mainly to be able to run it in fullscreen mode and with better scaling. Sadly, this does not work as expected. As soon as I copy the game to my hard drive (so I can place the dgVoodoo files into the game folder) and try to start it, the game tells me to insert the CD, even though the ISO image is still mounted.
There is an English version of the game called Mini Car Racing, but that version only supports split-screen multiplayer instead of LAN. The good thing is that it runs without the CD check, but split-screen is not ideal because two players have to share one keyboard.
I already tried some guides that explain how to modify the EXE to bypass the CD check, but since I don’t have much experience with this, I couldn’t get it to work.
I have also tried to compare the executable files of Asphalt Duell and Mini Car Racing, hoping to find differences related to the CD check, but I couldn’t identify anything obvious. I have attached both executables in case someone more experienced might be able to spot something I missed.
Just to be clear: I am not looking to start any discussion about warez, cracks, or hacks. I own the game and simply want to enjoy this classic from earlier days together with my son, using the best possible settings and experience available today thanks to dgVoodoo2.
So I wanted to ask here:
Does anyone have an idea how I could get Asphalt Duell running with dgVoodoo2, ideally without the CD check problem?
Any help would be greatly appreciated. Thanks in advance!
Reply 1 of 11, by Hoping
If it works with a simple ISO file, then it does not have a copy protection. Maybe you can try to edit the ISO file and add the dgvoodoo files.
Reply 2 of 11, by dr_st
Let me try to understand this first - when you mount the ISO and run from the mounted ISO - the game starts fine?
If so, it means the EXE checks the directory it's running from and behaves differently depending on the outcome.
The above suggestion - injecting the dgVoodoo files into a CD image may work in this case.
Reply 3 of 11, by gag2000
I didn’t try the simplest approach at first, but that worked perfectly. I simply edited the ISO with AnyBurn and added the dgVoodoo2 files, and now everything works.
The only remaining issue is that it always wants to start in compatibility mode.
If there is no copy protection, is there an easier way to make it run without loading the ISO? If that’s possible, I’d like to start it directly from the hard drive. Are there any tricks for that?
If there’s no possibility, that’s also okay, because the main problem has been resolved.
Thanks for the replies.
Reply 4 of 11, by Hoping
Maybe running it from the root folder of the HDD, maybe like @dr_st suggested, it only checks that. But I do not think so. If you have more than one partition in your HDD, using a different partition instead of C:\ will do the trick.
Reply 5 of 11, by gag2000
It doesn’t work directly from C, nor from a USB drive with the same drive letter as the mounted ISO, and it also doesn’t work with a virtual VHD. Thanks anyway for the help, but I’m glad it works with the dgVoodoo files directly on the ISO.
Reply 6 of 11, by gag2000
Now that I know how it works, I created a batch file with a workaround. I’m only posting this in case someone else runs into the same error and is interested in a solution that doesn’t keep the ISO mounted all the time.
The script mounts the ISO, finds the drive letter, locates AsphaltDuell.exe inside the ISO, and starts it. Once AsphaltDuell.exe is closed, the ISO is ejected:
@echo off
net session >nul 2>&1
if %errorLevel% neq 0 (
powershell -Command "Start-Process '%~f0' -Verb RunAs"
exit
set "ISO=C:\Program Files (x86)\AEON Design\Asphalt Duell\Asphaltduell.iso"
powershell -Command "Mount-DiskImage -ImagePath '%ISO%'"
set "DRIVE="
for /f "usebackq tokens=*" %%I in (`powershell -Command "(Get-DiskImage -ImagePath '%ISO%' | Get-Volume).DriveLetter"`) do set "DRIVE=%%I"
if "%DRIVE%"=="" (
echo Error!
pause
exit /b 1
if not "%DRIVE:~-1%"==":" set "DRIVE=%DRIVE%:"
pushd "%DRIVE%\"
start "" "AsphaltDuell.exe"
popd
:WAIT
tasklist /FI "IMAGENAME eq AsphaltDuell.exe" | find /i "AsphaltDuell.exe" >nul
if not errorlevel 1 (
timeout /t 2 >nul
goto WAIT
powershell -Command "Dismount-DiskImage -ImagePath '%ISO%'"
Reply 7 of 11, by davidmorom
If your executable size is 512,000 bytes and the CRC32 is 0x940AE655, you can apply the following patch to remove the CD check, so you will be able to run the game from any folder on your hard drive. You only need the patched executable and the file "datfile.dat", the other files on the disk are needless.
Search for differences
1. D:\David\Desktop\AsphaltDuell.exe: 512.000 bytes
2. D:\David\Desktop\AsphaltDuell.nocd.exe: 512.000 bytes
Offsets: hexadec.
25D84: 74 -> EB
1 differences found.
The game calls the Windows function GetDriveTypeA to check if the path where the game resides is a CD-ROM. The result of the call is compared to 0x05, the value assigned to CD-ROM drives, and if the value is correct the program skips a block of code that shows the error message box and closes the game. This patch modify the jump to always skip this block of code, regardless of the comparison result, so the game can continue.
I hope this is useful for you.
Reply 9 of 11, by dr_st
davidmorom wrote on 2026-02-10, 08:34:
Very cool. Do you mind if I add it to my list of no-CD patches, while crediting you for the discovery?
Reply 10 of 11, by davidmorom
dr_st wrote on Today, 12:53:
That would be great, please, feel free to do it!
