tomcattech wrote on 2026-02-14, 21:20:Yep, I see it...
Is there any easy way to test it without an oscope? […]
PD2JK wrote on 2026-02-14, 19:24:
I had this issue once when the RTC XTAL was dead.
Yours is being protected/surrounded by some black plastic.
Yep, I see it...
I thought we were onto something (CPU support due to the MB being misidentified) but still no go.
I had a P4 2.8 in it (which the PERL supports, but the D850 does not), so I put a P4 1.6 \ 256 in it (which the D850 supports via CPU-Upgrade)
I've learned a good lesson here: Never assume what is in the box even when you are told something else. (Especially in EBay)
Specs:
P4 1.6\256
Got 512 MB RAM in 2 out of the 4 slots with spacers in the last 2 slots:
2x 256 MB sticks (Samsung MR16R1628DF0-CM8)
Pwr: Bestec: ATX-250-12Z
Vid: AGP GeForce2 MX 32
I have a feeling we've put more man hours into this than the last guy who pulled it... 🤣
Hey, if it's possible to get it running, we'll try to help. 😀
And yeah, as a general rule one must always assume that an open box computer component (or car part, or anything else like that) contains the OLD one, not the one that came in the box... otherwise, why would someone break the seal and open the box? Maybe just to check it before putting it on the shelf? It does happen, and I have gotten legitimate open-box items, but it is definitely less common, so you absolutely have to verify it yourself. Never assume a brand new unused item is in the box, even if a seller says it is.
Personally, I wouldn't have noticed based on the pics in this thread that this board didn't match because I am not that experienced with P4 stuff and would take your word for it that it was an 865PERL... and yet, I look at old computer stuff constantly. One can imagine that a seller that says "yeah, it's in there." but isn't a retro computing enthusiast likely has no idea whether it is the correct board or not.
One thing that stands out to me though from your list of specs is the Bestec power supply. A lot of their PSUs are notorious for having bad capacitors. I don't think they are inherently terrible power supplies, they are just victims of the cap plague like a lot of other units from that time period. I know you said it is working, but have you tried this board with some different power supplies? Preferably something that has been inspected for swollen or leaky caps, or that was made within the last 15 years.
