First post, by toshiba_t1000
I'm trying to determine what would be a good pci video card for late dos. Specifically, stuff like tomb raider, command and conquer, quake, daggerfall, etc., the more demanding stuff. The system has a pentium mmx at 200mhz, and I'm planning on using an awe64 (ideally an awe32, but those are soooo expensive, so probably just a 64).
Primarily, I'm looking for cards that are:
* suitable for all or most such late games with good performance
* not insanely expensive to acquire
With respect to period correctness, I'm not worried *too* much --- as long as it's period correct enough to not have any issues working with the games, I'm not concerned --- though I am trying to avoid the very late stuff really only ever intended for windows, for precisely that compatibitlity reason
Cards I've seen include:
* s3 trio64
* ark2000pv
* s3 verge (and maybe some other verge cards?)
* tnt2 m64
* voodoo 3
* voodoo banshee
but the reason I'm asking this question is, I'm really not sure how these compare to each other, and looking online, it's really hard to find any reasonably definitive answers. Thus, I'd really appreciate any input as to these cards or any others.
If I've missed anything, apologies, wrt. video cards I'm not the most knowledgeable. thank you!
Reply 1 of 14, by theelf
S3 Virge
Solid dos support
univbe support
solid win3x suport
some s3 accelerared games like tomb raider
what else? ah tip, found 2 or better 4mb ones
Reply 3 of 14, by Matth79
Not expensive, that rules out VooDoo, TNT2, not sure how that fares as a DOS card as it's a 3D Windows card, don't know the ARK, S3 Virge - the notorious 3D decelerator, but solid in software mode, Trio 64, another solid base. Cirrus CL54xx in PCI would also be a contender, or maybe an ATI Rage that supports CIF
Reply 4 of 14, by leileilol
Not a Voodoo 3 / Banshee for 15bpp support concerns (unless you really, really don't care about the Probe/Acclaim joints as some do).
S3's compatibility and VBE is the most decent out of these (ironed out further with S3VBE20), and the cards themselves are very common, but there's also the variable of most cards having a brightness problem. S3+Voodoo2 cards were a popular pair in 98, and if "late dos" also means Bethesda, you'd be good on that.
Also when there's advice of "just use univbe/scitech display doctor" the support of hardware in that stops before mid-1998 so there's that to think about.
Reply 5 of 14, by jmarsh
S3 Trio64V2 if you want a card with native VBE2.0 support (in the bios) rather than worrying about having to use utilities (which you won't get with the virge).
Reply 6 of 14, by theelf
jmarsh wrote on Yesterday, 20:28:
Dont understand what you say about virge..?¿ most virge have 2.0 in bios, if not, there is a native vesa 2.0 driver that work fine in virge card, and of course univbe that give you 3.0. And if OP motherboard have a triton chipset, you can upload whatever bios you want using software
Reply 7 of 14, by jmarsh
theelf wrote on Yesterday, 20:56:
Show me any VBE2 bios for the Virge (86C325).
Reply 8 of 14, by theelf
jmarsh wrote on Yesterday, 21:16:
------------------------------------------------------------------------------- ----------------------- S3 VBE/Core 2.0 Versio […]
----------------------- S3 VBE/Core 2.0 Version 3.18 -----------------------
This is the documentation for S3 VBE/Core 2.0. S3 VBE/Core 2.0 is
Copyright (c) 1994,97 Dietmar Meschede. All rights reserved.
Contents
1. Overview
2. Installation
3. Low resolution video modes
4. Known problems
5. The S3 VBE 2.0 package
6. Copyright, legal disclaimer and terms of use
7. The author
1. Overview
VESA VBE/Core 2.0 is an extension of the VESA VBE 1.2 standard
(VBE = Video BIOS Extension).
S3 VBE/Core 2.0 is a MS-DOS TSR program, which installs a VESA VBE/Core 2.0
for S3 graphics cards with a VESA VBE 1.2.
S3 VBE/Core 2.0 supports the following S3 graphics chips:
Vision864, Vision868, Vision964, Vision968, Trio32, Trio64, Trio64V+,
Trio64UV+, Trio64V2/DX, Trio64V2/GX, ViRGE, ViRGE/VX, ViRGE/DX, ViRGE/GX.
or you talk about bios to flash? i have some virge cards that have 2.0 in bios
Reply 9 of 14, by jmarsh
I literally said "show me a BIOS", not a utility/TSR.
Reply 10 of 14, by theelf
jmarsh wrote on Yesterday, 22:51:
I already have flashed in my cards, i need to dump to upload the ones i have in my cards
Here is one i keep in my hard disk, is for virge and have vesa 2.0
The attachment s3virge-v201.zip is no longer available
here they talk about bios with vesa 2 S3 ViRGE BIOS RAM timings
Reply 11 of 14, by jmarsh
From the file you uploaded: "S3 86C375/86C385 Video BIOS. Version 2.01.07_508"
That's not for a Virge (86C325), it's for a Virge DX. Same goes for the thread you linked, it's all about the Virge DX.
Reply 12 of 14, by theelf
jmarsh wrote on Yesterday, 23:32:
I said virge, i recommend virge card, and give you a virge bios. Don’t be a pain man
Reply 13 of 14, by jmarsh
theelf wrote on Yesterday, 23:42:
Virge is 86C325. It has no VBE2.0 BIOS ROM. Trio64V2 does. Virge DX does.
Don't recommend a Virge to someone who wants native VBE2 support.
Reply 14 of 14, by theelf
jmarsh wrote on 44 minutes ago:
I recommend you not a virge, but a tila
