Test and troubleshoot PC@LIVE motherboards
Reply 1060 of 1120, by PC@LIVE
With the AZZA P4M2-MVB and P4 2400/400 motherboard, I did some benches, and the results do not seem bad at all, if compared to a DFI with Celeron D 2.66 GHz, but later we will see to make a direct comparison with the same CPU, so as to understand if it changes a lot with the simple transition from Celeron to P4, I think there is a certain difference, because in the past I had changed a P4 2000 with a Celeron 2600, and it seemed slower to me, despite the greater frequency.
I start with Phil's benches, for a couple it was not possible to see the results, one definitely due to the CPU speed, and the other instead could be the monitor (?), apart from this, here's what I got:
2) 615.3 3) 612.3 4) 127.6
5) 382.3 6) 57.3
A) 553.26 b) 139.09 c) 259.4 e) 122.8
K) 565.5 m) 505 n) 1603.17
In addition to these, I ran other DOS programs, including QTPRO obtaining:
CPU Bench Mark 518777 Dhrystones
262721K Whetstones
Compative about 48,000 MHz XBenchSpeed
And also those of NSSI 060
CPU Perf. Index: 836444 Dhrystones/s (839562, 16 bit code)
FPU Perf. Index: 212302 KWhetstones/s (212729, Real mode).
Phil's scores of the DFI NB78-BL, are these:
2) 441.5 3) 523.7 4) 90.3 5)284.8
6) 46.3 a) 461.05 b) 103.16 c) 216.7
E) 60.3 m) 463 n) 1108.15
All inferior to the AZZA, sometimes the gap is clear, as in n), but I consider the integrated video card, a disadvantage compared to the ATI 9250 AGP of the DFI, so some could be even ️ better.
It remains to replace the TC23 SACON 3300uF 6.3V, for complete recovery, then you should decide the amount of memory, and whether to use an AGP VGA instead of the integrated one.
After replacing the swollen electrolytic capacitor, I would have to upgrade the memory, and the disk to use, to load Windows XP (probably), from there then I can run other bench programs, such as CPU-Z Sandra BMX etc...
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 1061 of 1120, by PC@LIVE
Well now that I'm done with the AZZA, I'm going to an ASUS motherboard with something in common, namely the support of DDR RAM and P4/400 CPUs, the rest differs, but anyway they are the same kind of PC.
What is ASUS?
A P4B266 REV.2.01, with Socket 478 and DDR RAM slot, probably the first with this type of memory, previously used with Intel chipsets, RDRAMs and later SDRAMs, the latter were not the best with the P4, and I think it was a fallback solution while waiting to be able to use the DDR.
Here we have three DDR sockets, in total so we can get to 3 GB of RAM, more realistically 2 GB would still be enough.
Given the ATX format (a classic), we have plenty of PCI slots, well six plus an AGP and a CNR, if we wanted to fill them all, I remind you that in the ATX cases the maximum number of cards is seven, so it is evident that a PCI and the CNR are shared.
The CPU supplied with the motherboard is a P4 SL5ZU 2.2GHz/512/400/1.5V, the chipset is Intel 845, to the motherboard I added a 64 MB DDR AGP 8X GF4 MX440 video card, in the future I can always change it, if I need something better.
In this motherboard, there is integrated audio, with C-Media CMI8738/PCI chip, I think it can go, except for special or professional needs, in which case it is possible to disable it and use a special PCI sound card.
There is no integrated LAN, and this given the number of available PCI slots, should not be a problem, in fact it could be an advantage, because they are usually 10/100M, while a special PCI LAN card, could be 1000M, then if we want, we can add a USB Wi-Fi, in one of the ports available in the shield.
Returning to the motherboard, despite several attempts I failed to make the IDE CF adapter work with CF memory card, sometimes it happens that it does not work in some motherboards, so I think I will try to connect a HD and a CD player, to load Windows.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1062 of 1120, by PC@LIVE
Not happy with the results obtained recently, I definitively put away the ASROCK ConRoeXFire, because before the adjustment of the PIN, it is definitively (?) KO put, I tried everything I could, and no post code is displayed (— —)!
Now I have the doubt whether the PIN repair was successful or not, in short I don't know what happened, but the card went from displaying some codes, to not displaying any, plus while before it beeped without RAM, now no beep!
This thing, in the past has happened with other motherboards, initially working and after a few starts, completely KO, despite the tensions being normal.
So having a free seat, I'm going to an LGA 775 motherboard, with the typical appearance of an ASUS, but which is actually an HP Benicia, or ASUS IPIBL-LB REV. 1.01, with Intel G33 Bearlake chipset, uATX format, Intel Pentium Dual Core E2160 1.8GHz SLA8Z CPU, AMI v5.35 BIOS of 12/16/08, and integrated audio, video and LAN.
The one I own, is a bit bare version, in the PCB you notice many empty places, and ditto in the shield, overall it has a couple of positive things, and one minus, the minus is the lack of a 40PIN IDE port, to connect the drives, there are only SATA ports (N.4), the positive things are the support for Intel CPUs with FSB 1333, and the presence of four DDR2 RAM banks (667 or 800).
If it is necessary to install a better video card than the integrated one (Intel GMA 3100), there is a PCI-E 16X slot, or alternatively for other cards there are two PCI-E 1X and one PCI.
The original PC is an HP dx2400, which I obviously don't own, having only the motherboard, however I tried it and it works, at least it seems so, then later I would have to connect a disk and a CD player, to install Windows, and some bench and diagnostic programs.
At startup it shows an error message, but suggests pressing F2 to continue, maybe it has remained stored, because there is a low CR2032 battery, so any changes to the BIOS are not stored.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1063 of 1120, by Minutemanqvs
I'm hijacking your thread as it looks like it's the mainboard repair thread 😁
A couple of months ago I got a dead MSI KT7 Pro2 board (https://theretroweb.com/motherboards/s/msi-ms-6330-ver-1.0c) that had badly leaking caps.
After replacing the caps with new ones (Panasonic)I'm finally at the moment where I feel confident to power it up. I started by verifying that:
- There is no short between the power rails (ATX connector)
- Check if the VRM Mosfets are not shorted (good)
So I plugged a Duron 700 in the board, added my POST card and shorted the "Power" switch and...nothing. Absolutely no sign of life.
With my multimeter I can see 3.3V on the power switch, so at least it's coming to the right place. On the other side, on the ATX connector I can measure PS_ON at 4.7V which is also fine.
When I short the power switch, PS_ON stays at 4.7V instead of going to 0 as it should. So some component that acts between the power switch and the ATX PS_ON does not cooperate.
So next step, force a power on by shorting PS_ON to GND: the board starts and the POST card displays codes. The board itself has diagnostic LEDs and it shows 0010: Initializing Keyboard Controller (in the user manual)
So, any idea on what could cause the issue? I fear it's the southbridge as I see no other chip which could handle the power management.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 1064 of 1120, by PC@LIVE
Minutemanqvs wrote on 2026-02-19, 20:25:
I'm hijacking your thread as it looks like it's the mainboard repair thread :D […]
Ciao 👋
No problem friend, if I can help you I'll gladly do it, I don't think I have a motherboard like yours, but I have a very similar one that is a Turbo, unfortunately I haven't fixed it yet, even though it's been several years.
Maybe 🤔 it's as you suggest, an SB problem, but if it was, I think it can be diagnosed, I don't know if after a few minutes that it's on, it stays cold or gets hot (?), if it stays cold it could be the missing power supply, which you should understand where it comes from, maybe a pdf of the SB with the pinout, could suggest which track to follow.
One thing I would check, when you turned it on (forcing it), are the voltages on the Mosfet PINs, if it's not too complicated, write everything down and publish the Mosfet and PIN voltages here.
By following these steps, we can exclude what works from the troubleshooting, and seeing that it shows codes, it seems that the BIOS works, and the CPU should also be good, eventually if you have the possibility to use a working motherboard, you can check the components.
I don't know if you've already tried, what I suggested, possibly don't take into account, what you've already done.
So good work, and update me on the tests you run.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1065 of 1120, by PC@LIVE
Looking better, I would have a couple of things to suggest, first put a CR2032 battery and try to start (normally), some boards like the i81X do not work if the battery is empty, so this one could also behave in the same way, if you are interested there is a video of Tony359, in which it repairs the circuit of this battery in a short time discharged.
For the second problem, of the indications of the 4 LEDs, yes I think it is correct, since the keyboard is not connected, you should try to connect one, and see if it continues, in case then complete the start, it is clear that the SB works.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1066 of 1120, by PC@LIVE
I would continue with the tests on the ASUS HP IPIBL-LB, but not having a 40PIN IDE port on board, I can't run the usual Bench and start DOS, even if the PC is very powerful compared to the single-core ones, with DOS I believe that the CPU is used at half the potential, or maybe even less, I don't think that the various instructions like SSE or similar, are used when the SW is running.
As a replacement for a SATA disk, you could use a memory card via IDE-SATA adapter, I had a couple, but after a certain period of time in which they worked, they stopped working, at the moment I'm not going to get more, rather I prefer to look for a SATA-CF adapter later, or an ISA-CF card or as a further alternative, I could use a bootable USB pendrive of tiny size (today), enough to hold what I need to run the usual bench.
Going back to the motherboards, I have a motherboard very similar to the IPIBL-LB, also ASUS HP, but this is an IPIBL-LA REV. 1.03 (HP Berkley - GL8E), basically I think it's the first version of this type of motherboard, and most of the components are the same, there are small differences, and especially here the equipment is clearly superior, almost complete I would say.
As a CPU I would have, a Pentium D 820 2.8GHz/2M/800 SL8CP, it's the only PC with Pentium D that I have, but this is a Pentium D of the 8XX series, I think the 9XX series is more common, in any case I don't know if it's the CPU originally used on that PC, however it could be interesting, give it some bench, just to understand if there is enough difference with other similar CPUs.
Before trying it, I have to replace a swollen electrolytic capacitor, it's an 820 uF 6.3V, I have some new replacements, I hope it's the only one to ask for a replacement, because I wouldn't want others, despite being visually fine, actually not to be.
This work of replacing the swollen electrolytic capacitor, I will see to do it over the weekend, then I would be planning a recap of the ASUS P2B-F, I think there is some electrolytic capacitor that prevents starting, certainly everything will be clearer when the work is finished, although the chances that it will work, will be clear when I check the capacitors removed, one or more out of tolerance, they could increase the chances that it will work again.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1067 of 1120, by Minutemanqvs
PC@LIVE wrote on 2026-02-20, 10:52:
I tried with a battery this morning and things actually worsened (not because of the battery). The POST card now displays nothing. All the voltages seem to be ok on the POST card but no code is executed. On the board, the cPU fan spins. 🙁
What I can feel is that the SC1155CSW DC-DC controller near the VRM Mosfets is burning hot already a few seconds after the force power-on. User "nali" on this forum had the same issue and this caused his board to fail. These chips are easy and cheap to find, so it's still an option to replace it...but I wonder if it has something to do with my initial problem or if it's a second one.
So, measuring the Mosfet which are by pair. I set my multimeter to diode mode. The CPU has been removed at this point.
Q9 and Q12 (the upper ones on the picture):
- Drain (tab soldered to the mainboard) to Source (right leg): 0.4V drop on each Mosfet. As it's not 0V I conclude that there is no short here.
- Gate (left leg) to Source (right leg): 0.64V, so no short either.
Q10 and Q13 (the lower ones on the picture):
- Drain (tab soldered to the mainboard) to Source (right leg): 0.05V drop on each Mosfet (they are in parallel). This looks more suspicious so I went to continuitiy mode: 30 Ohm.
- Gate (left leg) to Source (right leg): 0.62V, so no short.
I don't have enough experience to conclude if there is a problem with Q10, Q13 or the SC1155CSW...
Reply 1068 of 1120, by Minutemanqvs
Adding some info, i measured some pins on the SC1155CSW (https://www.alldatasheet.com/datasheet-pdf/pd … /SC1155CSW.html).
Ground to Pin 12 (DRVGND): 0.13 Ohm, so ground is not floating
Ground to Pin 13 (LOWDR): 683 kOhm
Ground to Pin 14 (DRV): 6.6 MOhm
Ground to Pin 15 (VIN12): 15 kOhm
Ground to Pin 17 (HIGHDR): 880 kOhm
So nothing seems shorted here.
Reply 1069 of 1120, by PC@LIVE
Minutemanqvs wrote on 2026-02-21, 09:49:
I tried with a battery this morning and things actually worsened (not because of the battery). The POST card now displays nothin […]
Minutemanqvs wrote on 2026-02-21, 10:16:
Adding some info, i measured some pins on the SC1155CSW (https://www.alldatasheet.com/datasheet-pdf/pd … /SC1155CSW.html). […]
Ciao 👋
So, in fact it could be another problem that of the lack of post card codes, or if it is a consequence of forcing the start(?).
Unfortunately in these conditions, I did not see the normal voltages in those Mosfet, instead before it was possible that they were there, since the CPU showed some start signs, there was also the possibility of noting all the codes prior to the lock, it was enough to press the button on the post card, now it is possible that the chip that heats up, has failed (?) Or there is something around or in the circuit, but even before, maybe you would have made progress if you had turned on the motherboard with the RAM installed.
In conclusion I would say that you have to start over, try CPU and RAM if you can in another motherboard, if they work later you put them in the motherboard, I don't know if you checked the PowerGood pin (ATX power supply), this could say if there is a problem, but now I think there is for sure, while before maybe not.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1070 of 1120, by Minutemanqvs
Thanks for your feedback. Indeed it's complicated to know what the root cause really is, or if some other things have broken since the initial situation.
Meanwhile I tested CPU + RAM on another board and they fortunately still work.
I will sit on this board for a couple of days to think about what I can do or just call it a loss and use it for spare parts. It's not like I absolutely want it, I have plenty of other S462 boards.
Reply 1071 of 1120, by PC@LIVE
Minutemanqvs wrote on 2026-02-21, 11:15:
But you know it depends, it could still be repaired, even if now the chances are much lower.
But of course now solving the problem, it requires a greater effort, and so I don't know if you have time to dedicate to it or not.
However, if you decide to continue with the repair attempt, if I can help you no problem, if you want I can recover one of my motherboards, and look for one with the most similar circuit possible, if it works I could tell you the Mosfet voltages.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1072 of 1120, by PC@LIVE
Following your instructions 🧭, I checked through datasheet the voltage regulator chip 😬, it seems to be very common in PC P3 and Athlon, well it seems that the initial problem, of failure to start, could be connected in some way to this IC, so the subsequent problem, could be due to the definitive breakage of this IC, or something connected to it.
I tell you that the problem could be another, but in my opinion, it's probably him who broke 😑, looking at the pdf file, I extracted an image, where you can see the individual PINs to what they are connected to, I don't know if you are equipped for removal and verification, that is, you have specific tools, but most are quite easy to verify, using a simple multimeter with diode test or in OHm 🕉.
Also from that image you can understand which PINs to check, clearly if you make suspicious readings, you could be close to identifying the problem.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1073 of 1120, by Minutemanqvs
PC@LIVE wrote on 2026-02-21, 15:33:
Following your instructions 🧭, I checked through datasheet the voltage regulator chip 😬, it seems to be very common in PC P3 and […]
I will have a look at it tomorrow, I have a hot air gun since 4 days so it's absolutely time to do dangerous things to an innocent PCB! These components seem to be available easily on aliexpress for 2-3€ so it might be worth trying to replace it if I measure something suspicious. I'm doing this mostly for the fun of reviving the board, not that I really need it. And I also have a good coworker/friend equipped for micro-soldering under a microscope if everything goes wrong 😉
Reply 1074 of 1120, by PC@LIVE
A motherboard to be repaired, which I occasionally review, is this LuckyStar 6ABX2V VER: 1.2, typical iBX Slot1 motherboard in ATX format, I performed some repairs, but I was never able to make it work, everything seems ok, but in conclusion I had reached the point where I could no longer do anything, because the SB seemed very suspicious.
However, this does not mean that there can be anything else, but from the repairs carried out, in particular a Slot1 PIN touched the one next to it, and this problem was solved, the voltages returned to normal, but no post code appeared, so today trying to understand the operation of the VRM circuit, I ended up looking at the back of the PCB, including some scratched tracks, some had been repaired, others instead did not need anything, the scratch was there but it did not break the trace.
A further problem he had was that two of the (three) FAN sockets were missing +12V, for convenience without being able to understand where the problem was, I made a small bridge in the back of the PCB, and now all three work, unfortunately this did not solve any other problems, the motherboard starts but no code is visible in the display of the ISA-PCI post card.
The main problem, it seems to be missing in the 3.3V PCI slot, in reality it could be normal, I checked in the RAM sockets and I found them, but looking at the LEDs of the post card (inserted in the PCI slot), you can see all the right ones on, so in practice CLK IRDY FRAME and RESET, this would indicate a first problem, the RESET one should turn on and then turn off, here instead it stays on, and in this case I think it is impossible for the motherboard to start.
I would have looked for a datasheet of the SB (Intel FW82371EB SL2MY), to see which PINs control the ignition, because there is another problem, once turned on, if you hold down for a few seconds, it does not turn off!
In short, just out of curiosity I made some measurements on SMDs, an N-channel Mosfet and four NPN transistors, I have to interpret the results, and I should also do some checks, just to understand, if they are working, unfortunately being tiny, I can't remove them to test them off the circuit.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1075 of 1120, by PC@LIVE
I have among the motherboards scrap, a board that I re-evaluated today, because it has no particular damage, the most serious thing is the lack in the back of NB and SB of some SMD, and another problem that can be solved, is the lack of various electrolytic capacitors of the VRM, a failed attempt to replace them, because they were probably swollen, visually there is to add the heatsink to the Chipset SiS (NB), plus the BIOS chip, which I had removed some time ago, but which I kept, along with others from some unusable motherboards.
Let's see what it is about:
ASUS P4SDX, Socket 478 SiS chipset ATX format, with four DDR RAM, one AGP slot plus six PCI, plus integrated audio and LAN.
Honestly, I can't say if it's a cheap model of the 478 motherboard, but the equipment is not poor, so I think it's a mid-range model, which should still provide a certain level of performance.
The first job to complete is to free the holes from the tin, to be able to insert the new electrolytic capacitors, but I think it is essential to find SMDs to weld instead of the missing ones in the back of the PCB.
Recovering the BIOS chip, would not be a problem at all, even if having put it aside, I will only have to read the content, to make sure that it is just that, and at least initially I do not think it is necessary to update it, eventually if necessary I can recover from TRW the latest version available.
Today I will try to start the work, I don't know how long it will take to complete it, but finding the missing SMD, the board would be almost ready, in short it's a job that I failed years ago, but today having more experience, I can do without too much difficulty with the tools 🛠 that I have.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1076 of 1120, by PC@LIVE
Minutemanqvs wrote on 2026-02-21, 16:05:
Interesting 🧐
Keep me updated on the progress and work you will do, I would like you to be able to fix it, I will cheer for you.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1077 of 1120, by PC@LIVE
On the ASUS P4SDX REV. 1.12, I finished in a very short time and without any effort, the work of freeing the holes of the electrolytic capacitors, and above all it was not necessary to use the tin sucker, of course the electrolytic capacitors had already been removed, by those who had tried to replace them, obviously the problems he had, made him desist and abandoned the idea of completing the work of removal and replacement, in total he removed four of six (total), I think because they were swollen (probably), the other two I will not replace them, before re-solder the four substitutes, I will try to test the two original ones, which anyway Unlike other similar motherboards, they are Rubycon, so much better than OST or similar.
Looking at the MB manual, I found out that it is for 400 and 533 CPUs, so there is no support for CPUs with FSB 800, and from what I understand, it does not support CPUs with HT, or rather if used maybe there is no support, and you lose the performance advantage.
Now, therefore, I would simply have to find and recover some SMDs, from a scrap motherboard, to put them in place of the missing ones in the back of the PCB.
I think this could be the most difficult part today, especially because I have no idea of the capacity of those missing capacitors, and then I hope they are all capacitors, because if one were for example an inductor, it would be a big problem, unfortunately I don't have another same motherboard, to see what's missing and what it is, unfortunately on the back of the PCB I can't find any written indication to understand what it is (?).
The only thing I could do is look for another motherboard, with the same chipset, to see if I can find a similar circuit in the back, maybe I have a Gigabyte Titan 533, maybe that could be helpful, to compare the back of the two ICs (NB + SB).
For today I think I have completed the work, with this motherboard, and having already done almost half of the work, it allows me to devote time to other motherboards, one for example in which I have the same problem of the holes occcluded by the tin, is an Intel 478, today I do not know if I will have time to try to clear the holes, but in the next few days, I think and hope to be able to complete that work.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1078 of 1120, by PC@LIVE
Since I still have a few minutes, I can do a quick job on another motherboard, always S.478 though, I was looking for an Intel motherboard, at the moment I can't find it, but I found another motherboard that needed a job, always at the holes of the electrolytic capacitors, here as we will see the situation is to be evaluated, because they did a rough job, probably using drill bits, a little too big (in diameter), then at a certain point they couldn't free the hole, and it was necessary to remove the excess tin.
I performed these simple jobs, at best with the equipment I have, finally after cleaning, the result is not terrible, but after re-soldering the new ones, you have to check well, that there are no shorts between the + and - poles, but I would also check without the capacitors.
The replacement attempt was made to replace the bulging ones, unfortunately missing, I don't know the original values, but thanks to an image taken from the internet, I can clearly see that they are all three, from 3300uF 6.3V, so a very common type in MB.
For this card, I will limit myself to replacing the three missing ones, if I wish I could change two more of the same ones in the VRM area, but eventually I can replace them later.
So let's see briefly which card it is:
A Biostar P4M80-M4 VER: 7.0, uATX S.478 format, with two DDR RAM sockets, an AGP slot, three PCI and a CNR. We find as usual integrated audio and LAN, here there is also integrated video, a convenience if the PC is used only for 2D applications, because it does not require the use of a special AGP video card, which can still be installed if necessary.
As soon as I finish with the welds of the new electrolytic capacitors, I will be able to test if this motherboard works, it would be nice, even if I don't expect who knows what performance, given the VIA chipset, but we can say this after running the usual bench.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1079 of 1120, by PC@LIVE
Taking stock of the situation for a moment, of the latest S.478 motherboards, I accidentally discovered that the ASUS P4SDX, is the first with SiS chipset to support dual channel for DDR memories.
This favored performance, I don't know to what extent, but it required at least a pair of RAMs (identical), in fact I think it's one of the first 478 motherboards to have four DDR RAM banks.
Today this doesn't seem important, but at that time, the P4 533 was the top range, there were not yet ️ the P4 800 or the HT, so later, the 533 became an intermediate CPU, and later became (if I'm not mistaken) the economic version of the P4.
In the meantime, I looked for the BIOS chip, and I think I found it, to be on the safe side I should check it on the programmer, and about the BIOS, it seems that the latest version (or the latest), allow the use of DDR 400 RAM at their actual speed (200 MHz), so they would work asynchronously, that is CPU 133 and RAM 200, regarding the overclocking I can't say if this motherboard, has for the CPU frequencies higher than 667, that is, it is prepared for the use of CPU FSB 800, but I don't think it should be possible at least the 667, that from what I read, the P4 667 were out, but they were Replaced by those from 800.
Another important detail is that I have removed all the jumpers, and therefore I would have to get a dozen, to put them back, fortunately in the manual there are all the indications for each individual jumper, I exclude that you can try the card without any jumper, or only with some.
The card I have is the normal version, there is also the same motherboard in Deluxe version, which should have a more complete equipment, as far as I'm concerned anyway, the equipment of this motherboard in normal version, is more than enough, and if you are not satisfied with what is available, you can always opt for special PCI cards, since we have six available.
For today I should start with the welding of the new electrolytic capacitors, I think I can, without too many difficulties, beyond this motherboard, there is the BIOSTAR, and another motherboard that I wrote about not long ago, we will talk about this one shortly.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
