First post, by Deffnator
Dege, can you check NFS most wanted 2005?
WIth and without reshade + the x360 shaders, the game is giving black screens with the UI being the only visible thing on the menu
Reply 1 of 5, by Dege
Deffnator wrote on 2026-02-22, 14:05:
I did a quick try on the vanilla game and it worked. (2.86.5)
What is that x360 shaders thing?
Reply 2 of 5, by RetroGamer4Ever
The X360 Shaders Thing: https://nfsmods.xyz/mod/1200
It's graphics assets ported from the 360 game files to make the PC version appear like the console version.
Reply 3 of 5, by Deffnator
RetroGamer4Ever wrote on Yesterday, 14:19:
I tested again with default settings, is working, but it seems that there are shadow and some transparency issues with trees with the animated walls during races
Reply 4 of 5, by Dege
Thanks!
I gave it a quick go with Easy Install but it just worked.
But I couldn't test a lot of locations, maybe a screenshot would help.
Reply 5 of 5, by Deffnator
Dege wrote on Yesterday, 19:19:
Thanks!
here's some, showing the transparency issues, i didn't use MSAA for MW AA is quite good paired with reshade smaa.
The attachment speed 2026-02-23 15-03-34_931.jpg is no longer available
The attachment speed 2026-02-23 15-03-20_223.jpg is no longer available
