Reply 58360 of 58399, by nuno14272
beautiful..
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 58362 of 58399, by Minutemanqvs
These Blue PCBs are really nice! Congrats.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 58363 of 58399, by Unknown_K
schmatzler wrote on 2026-02-25, 13:12:
And it was not properly wiped, leaving behind a fully preserved OS/2 install with presentations, spreadsheets, Word documents and ancient software, frozen in time somewhere around 1999.
The attachment FBI_OPEN_UP.jpg is no longer available
Please don't arrest me. 😀
Any chemistry programs in there or just office apps?
Reply 58364 of 58399, by BetaC
I finally have a version of intel's great embarrassment. Well, beyond the most recent ones. And the government bailout. Actually, intel seems to not be doing too well...
Anyways, Itanium.
The attachment IMG_0849.jpg is no longer available
It's a 9540, so nothing too spectacular. But it's still a nice addition to my CPU collection.
Reply 58365 of 58399, by PcBytes
Got this for my KG7-RAID. XT flashed X850Pro. Unfortunately doesn't do XTPE.
Reply 58366 of 58399, by Minutemanqvs
BetaC wrote on 2026-02-25, 18:20:
I finally have a version of intel's great embarrassment. Well, beyond the most recent ones. And the government bailout. Actually […]
Anyways, Itanium.
I had a few of them in my collection but I have never seen a running Itanium system sadly.
Reply 58367 of 58399, by giantenemycat
In your humbled and crumbled opinions, would it be worth the 3-4 hour round trip to pick these up? Compaq Portable II and IBM 5153 monitor...for £75.
Reply 58368 of 58399, by Nexxen
giantenemycat wrote on 2026-02-25, 22:17:
Yes, if you plan correctly in order to do some sight seeing and a good meal in between.
Make it the cherry on top of your journey.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 58369 of 58399, by Ozzuneoj
They look pretty rough, but... as long as it isn't expensive or dangerous for you to travel that distance right now I don't think it's a bad deal if the monitor isn't totally dead or worn out. I'm not that familiar with the Portable II but they seem to be fairly valuable, so even if it is all a bust and nothing works and you don't have the time\experience to fix it all then they are at the very least worth this much as-is to someone who knows how to do the repairs.
Make sure to ask ahead of time if they have anything else if you're making the trip. 😀
Reply 58370 of 58399, by Twisted Six
Anyways, Itanium.
Nice. Back in the Win2k days there was a version for Itanium processors...and I always wanted to tinker with one with win2k.....unfortunately the project never took off.
If you tolerate this, then your children will be next.
Reply 58371 of 58399, by giantenemycat
Ozzuneoj wrote on 2026-02-25, 22:27:
Apparently it's all working...we'll see about that. But yeah, still worth having even as a curio if not. Already asked if they had any other vintage computer bits, and they showed me a DMG Gameboy 🤣 (I suppose similar vintage, but not quite what I'm interested in). From what I can gather from their other listings, their grandad recently passed away. So must have been his as well, and everything must go.
Reply 58372 of 58399, by Angus.Young
Lots of nice stuff still apparently stored away and slowly popping up... Guess I need to look locally... never know what you might find..
Reply 58373 of 58399, by Munx
Minutemanqvs wrote on 2026-02-25, 20:12:
Anyways, Itanium.
It's hard to even find a video with an Itanium system running.
My builds!
The Underdog - The budget K6
Reply 58374 of 58399, by PD2JK
I bought a Voodoo3.
The attachment 20260226_121148499.JPG is no longer available
After opening up, I see the board needs new caps. And the power supply is definitely going to be tossed out. I remember these exhaust hot air while doing almost nothing. They weigh as much as your generic phone charger...
The attachment 20260226_162039280.JPG is no longer available
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 58375 of 58399, by giantenemycat
PD2JK wrote on 2026-02-26, 15:37:
I bought a Voodoo3. […]
I bought a Voodoo3.
Very nice. Is that a Bora?
Reply 58376 of 58399, by PD2JK
giantenemycat wrote on 2026-02-26, 16:55:
I bought a Voodoo3.
Correct! BoraPro2 I believe, or MS-6168 VER2. I tried modifying one to 16MB once, without success. I'm not sure if I retry it in the future...
Reply 58377 of 58399, by Arkadiusz
Mandrew wrote on 2026-02-25, 10:10:
Probably the same as my PA-WTEGA PCchips clone, someone already mapped it. […]
Arkadiusz wrote on 2026-02-25, 09:06:
Did you find the documentation for the jumpers and DIP switches on the third card? And what's the card's name?
Dipswitch 1-4 select the card video output mode:
0-1-0-0: MDA Mode (main)
1-0-0-1: CGA 40x25 (main)
1-0-0-0: CGA 80x25 (main)
0-1-1-1: EGA 200 lines (main)
0-1-1-0: EGA 350 lines (main)
1-1-1-1: CGA 40x25 (secondary)
1-1-1-0: CGA 80x25 (secondary)
1-1-0-1: EGA 200 lines (secondary)
1-1-0-0: EGA 350 lines (secondary)
Dipswitch 5 selects the IO address:
0: I/O address range in 3xx (default)
1: I/O address range in 2xx
0 means switch open, 1 means closed.
Thank you very much!
Reply 58378 of 58399, by MattRocks
After many of us vulnerably exposed ourselves - what actually is in giantenemycat’s mystery box? You can't start a story and not finish it.. 😉
Reply 58379 of 58399, by schmatzler
Flare400 wrote on 2026-02-23, 15:43:
Thank you, I was able to downgrade the BIOS to Version 1.09 (KYET36WW), but I am still having the same problem.
I checked my A22p now and it's running BIOS 1.07, so I guess I also messed that one up. 1.07 is the attached file - please try that out and tell me if it works.
This should really be the correct downgrade, because I posted about that in 2020 on the German Thinkpad forum, but must've had the wrong version in my head when transferring it into the accompanying wiki.
Sorry for the hassle. 😁
