Reply 20 of 52, by Yftul
Mike_ wrote on 2026-02-15, 19:17:
Also, rio444's project is not open source as far as I know. I'm planning to publish this once its ready and I figure out what licensing scheme to use and so on.
https://github.com/Yftul/ps-2-mouse-to-isa-replica
Кто хочет ищет средства, кто не хочет - причины.
Reply 21 of 52, by Mike_
maxtherabbit wrote on 2026-02-24, 14:16:
They types of KVM people generally use which give these sorts of issues are the "active" ones which emulate a mouse being connected even when switched away.
If the cheap KVM you got is just a passive switch it won't really help
Actually it's not a passive switch, although it was very cheap. I think I also managed to reproduce the issue.
When using KVM switch, data transition happens very close to the falling edge of the clock, which can cause errors with current implementation. This is different from behaviour of mouse itself, where data transition happens in the middle of the high period of clock cycle.
The attachment kvm_switch.jpg is no longer available
The attachment mouse.jpg is no longer available
I guess many PS/2 hosts read data in the middle of the low period or something, even though *technically* according to spec data line should be stable at least 5µs before falling edge of clock...
Yftul wrote on 2026-02-24, 14:38:
Oh, I wasn't aware that an open source replica existed. Good to know.
Btw, did you run into similar issues with KVM switches?
Reply 22 of 52, by Yftul
Mike_ wrote on 2026-02-24, 18:29:
Unfortunately, my hardware setup is quite limited. I haven't tried running KVM on this board, so I focused on making a version with full USB mouse support.
Reply 23 of 52, by Mike_
I think I managed to fix this. It was caused by much tighter timings in PS/2 start condition rather than data line not being correct value at falling clock edge, even though input setup time of 3µs is not within spec. The issue was that if microcontroller was handling some other interrupt while USI's start condition detector raised interrupt flag, it would not get to that interrupt until SCL was already down. So the counter would miss one clock edge, messing up the entire thing... I still think that it's probably safer to instead sample data at rising edge, as that seems to be quite far from data transition with any of the devices I have measured.
Btw, I wonder if other adapter implementations are using bit banging instead of utilizing Universal Serial Interface (or USI) module found in some ATtinys? I'd imagine that this would be a real pain in the ass to do without some hardware support, such as start condition interrupts...
Reply 24 of 52, by aVd
Hi, @Mike_,
Very good project, but I have one question: Does the card work with passive USB-to-PS/2 adapter?
what comes around goes around
Reply 25 of 52, by Mike_
aVd wrote on 2026-02-26, 08:01:
Hi, @Mike_,
Do you mean a passive PS/2 female to USB-A male adapter? Yes, it does, I even tested this with a PS/2 only -mouse. I just used an USB-A connector, as I thought it would be more common to use an USB mouse with PS/2 support, than an vintage PS/2 mouse.
Reply 26 of 52, by aVd
Mike_ wrote on 2026-02-26, 08:52:
Yes, exactly.
Thanks for you quick answer! So, maybe in a further release you can add a through holes for female PS/2 mouse connector and a jumper-selector for activating USB or PS/2 connector. I see, that there's enough "free space" on the current revision board for such a handy addition.
Reply 27 of 52, by Mike_
aVd wrote on 2026-02-26, 08:58:
Hmm, why not. It probably doesn't even need a jumper for selection, as you could simply have traces go to both connectors and when assembling you could just populate one you need. Or both, you'd just need to not use them at the same time. It shouldn't break anything, but it wouldn't work.
Reply 28 of 52, by aVd
Mike_ wrote on 2026-02-26, 09:19:
... you could simply have traces go to both connectors and when assembling you could just populate one you need. Or both, you'd just need to not use them at the same time.
Yeah, that's the point.
And that's why I suggested the additional jumper 😉
Reply 29 of 52, by Mike_
aVd wrote on 2026-02-26, 09:43:
Yeah, that's the point. […]
I don't understand the point. It's easier to just unplug mouse from one of the connectors than it is to open the case and switch jumper. Besides using a jumper to select which connector is used would require additional support chips, as ATtiny's USI module is hardwired to certain pins. Ie. it's not possible to change it with software.
Reply 30 of 52, by aVd
Mike_ wrote on 2026-02-26, 10:50:
Wouldn't a +5V jumper-selector on the USB and PS/S traces do the job? USB and PS/2 mice don't work without +5V power supply, nothing software involved here.
Reply 31 of 52, by Mike_
aVd wrote on 2026-02-26, 11:38:
I guess it would probably work, as PS/2 is open drain, ie. it works with pullup resistors. But I don't see the use case here. Why would you want to open the case and fiddle with jumpers instead of just plugging out the mouse you are not using at the moment?
Reply 32 of 52, by akimmet
If you can get this adapter smoothly working with a KVM, that would be awesome. I would definitely want to build one then.
I would prefer a ps/2 port over a USB port that isn't actually USB. While nearly harmless in this circumstance. I have seen what happens when someone uses inappropriate connectors, and cables are mixed up.
Reply 33 of 52, by aVd
Mike_ wrote on 2026-02-26, 15:03:
L-shaped jumper or mini switch near the edge of the PCB + suitable hole in backplate:
The attachment PCB_edge_to_backplate.jpg is no longer available
Reply 34 of 52, by maxtherabbit
Personally I'd say skip the jumper / switch. Just have two footprints and only populate one
Reply 35 of 52, by aVd
maxtherabbit wrote on 2026-02-27, 02:44:
If there are through holes for jumper/switch, you can always use a soldered bridge-wire to one of the populated connectors (USB or PS/2) as non-switchable solution.
Reply 36 of 52, by Mike_
I think I will go with this.
akimmet wrote on 2026-02-27, 00:17:
So far it seems to work well with the KVM switch I bought. Of course more testing with other KVMs would be needed to be sure, so it would be nice if somebody else wants to try it out.
Vcc and ground are at same pins as with real USB and there are series resistors for SCL and SDA, so it shouldn't break anything. Most likely the USB device would just think that it's plugged to a charging port or something, but I guess I could test this...
Reply 37 of 52, by Mike_
Anyways, here's the code and PCB files of this converter: https://github.com/mniemela/PS2toSerial
I'll probably do version 2 of the PCB a bit later, in case somebody wants to try building this or just suggest improvements. I also have a couple of assembled version 1s that I can send to somebody in EU for cost of parts and postage. In particular it would be useful to test this more with KVM switches, as they have been problematic with other similar projects.
Reply 38 of 52, by Mike_
Big thanks to NeoG_ who helped by testing and debugging this with his KVM switch! 😀 It turned out that some KVM switches ignore host's commands to set sample rate, instead continuing at default 100 samples/second. This is a problem in 1200 baud serial mode as the converter receives packets faster than it can send them, and as a result it has to drop some of them. This causes erratic mouse movement, but it can be solved by using 9600 baud mode which does require modified mouse drivers. Another issue was that the KVM switch seemingly decided to reset itself randomly, and as such it would stop sending more packets until told to do so by the host (converter in this case).
If I understood correctly, it now works correctly with his KVM switch.
Reply 39 of 52, by maxtherabbit
I thought there was some logitech mode which always ran at 4800 or 9600 baud anyway which most of the drivers already supported
