Reply 20 of 44, by jakethompson1
Roman555 wrote on 2021-10-27, 19:01:
P.P.S. What will the Patcher do if the string *BBSS* is added into the BIOS manually ? 😀
The issue is, this BIOS is plain and uncompressed, i.e. it predates all these patching utilities. It isn't divided up into separate compressed sections with names like the later Award BIOSes are.
If the issue is the stray wrmsr instruction like I said, I suspect that using a hex editor to change the bytes at 0x19515 from 0x0f 0x30 to 0x90 0x90, and the checksum at 0x1ffff from 0x2a to 0x0b, and then reflash, that it would work. But, we haven't heard back from the OP about the post code or any further testing.
Reply 21 of 44, by Sphere478
Try talking to Jan
The attachment jan.jpg is no longer available
He has modded many bioses for k6 support
Sphere's PCB projects.
Reply 22 of 44, by majestyk
I wonder if Jan is still active in this field.
He has some BIOSes as "work in progress" for a long time now.
Reply 23 of 44, by Sphere478
majestyk wrote on 2021-10-28, 06:24:
I talked to him a few months back.
Reply 24 of 44, by rmay635703
Likely not his fault.
That’s the fault of folks like me getting a bios for a special motherboard then not responding for a decade because said board developed difficult to repair issues and the bios test went by the wayside
Reply 25 of 44, by Repo Man11
He recently created an account here, though I can't recall his handle at the moment.
Reply 26 of 44, by majestyk
That´s good news! Jan contributed a lot to the Socket 7 / K6+ community.
I´m sure he also has a day job to do (as myself) so he has to look after these projects in his spare time.
Reply 27 of 44, by zyga64
@Sphere478
I think Jan's email shouldn't be published here in non-obfuscated form.
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
I5 3470s /8G /GTX750Ti /HDA
Reply 28 of 44, by majestyk
It´s at the bottom of Jan´s website, so I think at least it´s not his private email address.
Reply 29 of 44, by Repo Man11
Here he is: Re: Intel shuttle socket 7 motherboard ?
Reply 30 of 44, by Chkcpu
Okay, you are calling on me to join this thread and I’m happy to share my views on this Biostar socket 5 BIOS issue.
Yes, I recently joined this fine community and find you all very knowledgeable in a wide range of retro PC subjects. I hope I can contribute with my specific knowledge of the Award v4.50/v4.51 BIOSes.
I started patching BIOSes for better CPU support in 1997 when my 486 rig wouldn’t run an Am5x86-133, and I’ve mainly patched socket 3 and socket 7 Award BIOSes since.
I’ve only once tried to patch a socket 5 Award BIOS. This was for the Edom MP039 board, that runs on the same OPTi Python (546/822) chipset as the Biostar from the OP.
At the time, I found that patching this BIOS for proper AMD K6 support was not feasible. No MMX or AMD support, not even for the AMD K5 and therefore a lot of support functions for non-Intel CPUs where missing.
However, I find jakethompson1’s idea very appealing. Just remove any offending code for the K6-2, like the Write to MSR 2, so the AMD can at least boot. We have good utilities now that can fix any AMD CPU registers programming from DOS or Windows and optimize performance.
I will start analyzing the 08/31/94-OPTI-546-822-2A5UMB01-00 BIOS for the 1500PCT series and report back what I find.
@jheronimus, can you confirm this is the BIOS you are using? And please let us know at what POST code the BIOS hangs when using the K6-2. This will greatly help in finding the culprit. 😉
Kind regards,
Jan.
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 31 of 44, by jheronimus
Chkcpu wrote on 2021-10-28, 19:33:
I will start analyzing the 08/31/94-OPTI-546-822-2A5UMB01-00 BIOS for the 1500PCT series and report back what I find. @jheronimu […]
Kind regards,
Jan.
Hi, Jan! Great to see you here.
Yes, I'm using that BIOS.
The POST code is just C0.
MR BIOS catalog
Unicore catalog
Reply 32 of 44, by Stiletto
zyga64 wrote on 2021-10-28, 18:12:
@Sphere478
majestyk wrote on 2021-10-28, 18:34:
Well... I fixed it anyways. 😀
do the Fandango!" - Queen
Stiletto
Reply 33 of 44, by jheronimus
jakethompson1 wrote on 2021-10-28, 00:45:
So this actually worked:
The attachment SS7VLB.png is no longer available
I guess I am now a proud owner of a Super Socket 5 VLB system? Ran Quake 1.08 timedemo to test for stability and got 45.1FPS, just insane. K6INIT gives some error messages (and Quake crashes), going to investigate further.
MR BIOS catalog
Unicore catalog
Reply 34 of 44, by Chkcpu
Okay jheronimus, this is great news!
Patching out the WRMSR did the trick and jakethompson1’s analysis and fix were spot on. 😀
I didn’t complete my BIOS analysis yet, but so far this write to MSR 2 is the only offending instruction for the K6-2 I’ve found. So I think you are good to go with this patch.
In later socket 7 Award BIOSes, I still see this write to MSR 2 for the Pentium (MMX), but then there is extra code to bypass this WRMSR when the CPU is non-Intel.
Another curious thing about this early uncompressed Award socket 5 BIOS is that it is just a 486 BIOS with some Pentium and chipset support added. So the 486 detection routines are still present and the CPUID instruction that jakethompson1 found is only used to distinguish the i486DX2 from the i486DX2 WB Enhanced! 😉
@jheronimus, can you tell us what the BIOS boot screens now shows as CPU model and speed when booting the K6-2/400? Just curious.
Jan.
Reply 35 of 44, by maxtherabbit
jheronimus wrote on 2021-10-30, 02:49:
So this actually worked: […]
Cool!
Reply 36 of 44, by jheronimus
Chkcpu wrote on 2021-10-30, 14:11:
Jan.
My AMD was actually configured for 266 originally, and the BIOS screen said Pentium 100. But when I switched to 400 it now says Pentium 16 😀
MR BIOS catalog
Unicore catalog
Reply 38 of 44, by Beerfloat
Any chance this kind of replacing K6-problematic instructions with NOPs and adjusting the checksum would work on something like the G7-ZG AMI BIOS for the TMC PCI54PV?
It boots with Pentium MMX but both K6-2 and K6-3 on Evergreen and Powerleap interposers just hang (with BIOS POST card code D2D3).
Same question for the Spring Circle SF586 VIP3A-ZS1 AWARD 4.50PG BIOS, really.
I am less concerned about CPU detection and setting all registers correctly than about simply getting it to boot. Can always run k6init after.
Reply 39 of 44, by jakethompson1
Beerfloat wrote on Yesterday, 02:09:
Unfortunately, between D3 and D4 a ton is going on. This is where the BIOS turns on the RAM, initializes the chipset, and switches to executing the BIOS from shadow RAM rather than ROM. The compressed portion at 5000h also appears to be something that amideco can't handle (but since you don't see D4, I'm not sure it ever executes anyway). There are a few 0f 30s in the uncompressed part, but they look like false positives and not actual wrmsr instructions. So it's difficult without knowing where it gets stuck. Rather than straightforward like Award, perhaps something in the CPU detection code was set and doesn't break right away, only causing failure between D3 and D4.
edit: there is MHz detection code between D3 and D4. Perhaps it runs too fast and there is overflow or divide by zero--you could experiment with as slow bus speed and multiplier as possible.
That one is quite similar to jheronimus' one.
At offset 17F3Eh there is 0F 30 (wrmsr). Change it to 90 90 (nop nop) and I expect you'd have to change the checksum at 1FFFFh to 22h.
