Reply 30860 of 30886, by Shponglefan
- l33t
Had another Roland sound module on the bench today, this time an SC-55 mkII.
It had the usual nasty glue under the 2200uF capacitor. The glue had turned conductive, although it was measuring in the mega ohms so I don't think it was causing any shorts.
I removed the cap and cleaned off the glue all the same. The capacitor tested at 1898 uF, a little on the lower side. Unfortunately I didn't have any 16V 2200uF capacitors on hand, so I opted to put it back for now. I'll order some caps and replace it next time I have this unit open.
The other issue are the buttons. The power/standby button was completely non-responsive as were the key shift buttons. Some of the other buttons were intermittent but mostly usable.
I opted to disassemble both the power switch and one of the key shift buttons and clean the metal contact inside. They were quite corroded.
Roland uses switches with only two pins instead of the more standard 4 pin versions. I'm going to look into buying a supply of these if I can find compatible switches. Straight replacement is probably the easier option than disassembly and cleaning.
Most of the switches measured at about 50 Ω up to 1000 Ω. Usable but not ideal. Whereas the two I polished now measure only 0.5 Ω.
