First post, by AvocadoLongfall
I ordered this socket 7 board with atx support from Ebay and once it came delivered to my doorstep, i gently took it out and noticed this
https://theretroweb.com/motherboards/s/gigaby … 586tx3-rev-1-0x
Reply 1 of 5, by rasz_pl
yes it fell on the ground, yes its rusted because its pulled from the skip. Does it work tho? 😀
Crushed edge wont hurt anything, but fall itself could have cracked BGA joints. Test both in warm and cold conditions.
Reply 2 of 5, by AvocadoLongfall
Bga joints? Where? I am currently waiting for my atx switch cable to come. Then I will be able to test it. Soon it will arrive.
Reply 4 of 5, by Babasha
I think everything will be ok.
Need help? Begin with photo and model of your hardware 😉
Reply 5 of 5, by cyclone3d
You can just short the power switch header pins momentarily with a screwdriver or something instead of waiting for the switch to arrive. I regularly use my pocket knife or a screwdriver.
It is probably fine.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
