First post, by cydvog
hi, back in days i remember using a tool which you can select cpu like - pentium mmx to pentium 3 - for slowing down cpu for games . cant find this software now 🙁 anyone remember ? thanks
any one ? thanks 😀
You are probably thinking of Mo'Slo Deluxe
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
no this one is not 😐 thanks anyway for input
still cant find thanks for helps.
Have a look at DosFreak's list in the Deep Thought sub-forum: List of Slowdown Utilities
That sounds like you're thinking of CPUKiller or maybe Mo'Slo. I remember using those back in the day too! If you're on a modern system and trying to get old games to behave, you might also want to check out Throttle or just use DOSBox - it has the cycles setting (Ctrl+F11/F12) which is basically the modern way to do exactly what those old tools did.
For a program to auto adjust the speed like that, it would have had to do a continuous benchmark of some sort and automatically adjust the speed till it got as close as it could to the pre-defined benchmark score.
Do you remember about what year it came out or when you used it?
