First post, by cucgod
hi guys,
i have a weird issue i currently dont understand. maybe someone can explain it to me 😀
i have 3 working 486 machines.
2 VLB based ones (FIC 486-GIO-VT2 and a currently unknown one)
1 PCI (Luckystar LS-486)
i also have a good and working zip100 LPT device. now to my problem:
when i connect the zip drive (powered on) to the PCI 486, i can power up the machine just fine.
now connecting it to any of my VLB 486, i press the AT switch on the case and nothing happens. its just dead.
disconnecting the ZIP drive or turning if off -> the pc power comes up as expected.
the zip drive works on any newer machine i have (p1,k6,p2) without problems... what is the issue here and is there a way to fix it?
the zip drive is my goto bootstrap sw source to get everything up & running 😀
thanks for any hints
