Reply 460 of 501, by jamonyorke
+1 expressing interest in this project, and getting one unit from dreamblaster shop when it's finally available 😀
Yeah i hope so.
Its been a long time now.
i got picogus for a friend, and now can do comparision between both.
They Sound different.
May if i find time i make a Video.
Just bumbing this thread, since it's a new year 😀. I hope that dreamblaster will find some time to start working on a new batch 😀.
ouch yes i should !
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Please dooo! Thanks Serdaco.
Hi! Does the current revision decode one of the 8bit ports, like 0E0h i suggested? I'd be keen on creating a new pack of patches that works on 0E0h. I also don't mind creating an additional pack for the OUT 0C0h method, provided that there's already a TSR that hooks the interrupt, so i can test everything.
carlostex wrote on 2025-02-25, 15:10:Hi! Does the current revision decode one of the 8bit ports, like 0E0h i suggested? I'd be keen on creating a new pack of patches that works on 0E0h. I also don't mind creating an additional pack for the OUT 0C0h method, provided that there's already a TSR that hooks the interrupt, so i can test everything.
Mind you there is no "current revision". Dreamblaster has indicated they have little time to make a new batch, and though we're all cheering them on, there's no guarantee there will ever be a new ISA card with this sound chip. I'm not sure what the "old" revision decoded. C0 should be safe for PC/XT class machines (AT has DMA2 there), E0 could be safe.
JAL
jal wrote on 2025-02-26, 08:44:Mind you there is no "current revision". Dreamblaster has indicated they have little time to make a new batch, and though we're all cheering them on, there's no guarantee there will ever be a new ISA card with this sound chip. I'm not sure what the "old" revision decoded. C0 should be safe for PC/XT class machines (AT has DMA2 there), E0 could be safe.
JAL
Thanks for the clarification!
carlostex wrote on 2025-02-26, 17:45:jal wrote on 2025-02-26, 08:44:Mind you there is no "current revision". Dreamblaster has indicated they have little time to make a new batch, and though we're all cheering them on, there's no guarantee there will ever be a new ISA card with this sound chip. I'm not sure what the "old" revision decoded. C0 should be safe for PC/XT class machines (AT has DMA2 there), E0 could be safe.
JAL
I’m running a new batch now, so feel free to drop me a PM if anyone is interested. This helps me estimate the quantity.
The price will cover only my expenses, as this is a hobby project and I’m not making any profit from it.
matze79 wrote on 2026-01-12, 16:25:carlostex wrote on 2025-02-26, 17:45:jal wrote on 2025-02-26, 08:44:Mind you there is no "current revision". Dreamblaster has indicated they have little time to make a new batch, and though we're all cheering them on, there's no guarantee there will ever be a new ISA card with this sound chip. I'm not sure what the "old" revision decoded. C0 should be safe for PC/XT class machines (AT has DMA2 there), E0 could be safe.
JAL
Can you tell which revision this will be? I have a couple of your older ones...
it will be almost the revision in post #1 here in the thread.
With some minor changes.
matze79 wrote on 2026-01-12, 18:32:it will be almost the revision in post #1 here in the thread. With some minor changes.
I'm very happy a new batch will finally arrive! Thanks a lot for finding the time and motiviation 😀.
JAL
I just realized that I can make some improvements.
I had issues with the Eagle-imported KiCad files and also with different KiCad versions. For example, I couldn’t replace a part and update it on the PCB without losing all the net connections.
Since some parts at JLCPCB are no longer available to order, I also need to reorganize a few components.
So I decided to redraw most of the Card. This will cause a slight delay, but now that I have more experience than when I designed the card the first time, I can improve it further.
Cool, keep us posted!
matze79 wrote on 2026-02-22, 10:21:So I decided to redraw most of the Card. This will cause a slight delay, but now that I have more experience than when I designed the card the first time, I can improve it further.
This is great!! Take your time.
JAL
I would be intrested in one.. seems I do not post enough to be able to send PM's 🙁 I noticed a bit late so hopefully can still get in on one.
Thanks
Still some time going on.
i currently reroute the whole Card to get rid of old Autodesk Conversion Problems 😀
Progess ~70%
If I can help you anyhow, feel free to contact me 😀
matze79 wrote on 2026-02-25, 17:36:Still some time going on.
Progess ~70%
Great... maybe by then I will have enough posts to PM and reply to your PM 😀
Thanks
i try to get it keystone bracket compliant.
Also changed address decoder to dip switch.
current WIP:
